The Crane Cams Gold Race aluminum roller rockers, anyone had any problem with them on a set of AFR 190CC heads?
For a street application, I much prefer the Comp Cams Pro Magnum ones. They are lighter over the valve, stronger, and made of steel. The aluminum ones will fatigue over time.
Definitly go with the Comp Cams Pro mags. You will also need guideplates, studs and at least hardened pushrods. Good Luck, |
I have them on a set of Edlebrock Performers and haven't had any problems as of yet.
Pfast89,
How many miles do you have on your Roller rockers? Larry |
