Build Sheet location?
If someone knows the location of the build sheet for the 2001 C5, I would appreciate a response as to its location and how to retrieve it from the frame. Thanks.
It's located in the frame crossmember behind the front fascia. It's easier to just order one for your car from the Corvette Museum ($25, I think).
:withstupid: |
A friend of mine is having his front facia repaired so we'll see if they find the build sheet. Has anyone here found theirs?
There's a hole on the drivers side of the facia that you can see it through but just try to get to it. Just have to take the facia off. Should be a nice winter task or as said above you can just order one from the Museum. If you're just looking for accessories list, check your glovebox door or the rear compartment covers.
Yep ! Tucked in the front frame crossmember. I got mine !! It was on the left side.
Pops |
Originally Posted by screw991le
Thats cool man, thanks for that link, I wonder if membership is worth it. :toetap:
Yep. They are great folks up there. And do a great job preserving and promoting Corvettes. |
