Curb weight C5 vs C6
I've read that the 05 C6 is supposed to be lighter than the C5. the C5, from what I have read, the coupe weighs in at 3221 and the C6 at 3245. Are these the correct numbers for these cars?
Curb weight: C5 coupe 3246 lbs. C6 coupe 3179lbs
2004 Corvette Specifications 2005 C6 Specifications |
Originally Posted by Dave68
...and you could get rid of most of that extra weight by swapping out two OEM things - the cat-back exhaust and the runflats. Getting rid of runflats will reduce your C5's weight by 26+lbs and installing Borla Stingers or a Z06's titanium cat-back will chop off approx. 20 lbs (guestimate) or more.
Or just get a FRC/Z06 and have the lightest.
Dope |
Or leave the wife home and save ??? pounds... :jester
2004 Corvette Specifications 2005 C6 Specifications Gee... I sure hope LiquidD1 doesn't go put all us poor folks in our places for saying we like the heavier C5(with the bigger trunk!!) when we are kidding ourselves and are secretly lusting after the C6... |
I checked the door sticker on my 2003 A4 Coupe this morning and the curb weight is listed as 3663 lb. That's considerablly heavier than what's in the specs.
What you saw on the door was GVRW (Gross Vehicle Weight with passenger and contents). The 2004 Vert says: 3651lbs, and it also says not to exceed 399lbs in passenger and contents, so if you subtract the 399 from the 3651 (for a 2004 vert), the curb weight is 3252.
OK, that's quite possible. I thought it said curb weight. I'll have to check again.
:rofl: :rofl: :rofl: :rofl: |
:iagree: [QUOTE=jrose7004 :cool: :yesnod:
Originally Posted by robvuk
What you're looking at is the maximum load the vehicle is capable of handling with the tires that come with the car. :cheers:
You are all in denial! :rofl: |
Dope and getting rid of the runcraps saves unsprung weight- most important |
Two of me in the car and I exceed the allowable weight limits. Oh no.
