Dyno numbers / times for a LPE 219 383ci?
My roomate decided tpo go w/ the LPE 219 cam for his '86 coupe.
See his mods here ---> '86 Z51 coupe built 700R w/ 2400 stall 350 + .060 400crank ported and polished LPE Super Ram P/P base intake 1000cfm TB Ported GM irom 2.02 valve heads 1 5/8 long tube headers 3.75 rear end custom programed chip What numbers are you guys getting?? What about 1/4 mile times? I figure he's good for 425-450hpBHP and 475/500BTQ and low 12's/high 11's on 315 drag radials. |
Very Close setup to what I was running back in the late 90's. I was getting 375 rwhp and 11.90's in the 1/4.
Your estiamte sounds good :cheers: Dennis |
You were getting those #'s with stock ported heads?
Almost the same setup that I'm running now..
I have no cage so I have to hit the brakes at the 1000' Mark. I went 11.82@100.02 MPH. With tire spin. This year I would Imagin now that I can run it all the way out. I should be in the 11.5-6 Range. New rule for roll cages are 11.49 this year. :yesnod: |
383 with SR intake, AFR 190 heads, and 219 cam I was making 360 RWHP and 411 RWTQ. I ran 11.80's @118 consistently on street tires with a 6spd. This was in a 90 Coupe.
Lingenfelter shows dyno graphs for a SR/383/219 in his book, with ported 113 heads, gets about 440hp on the engine dyno, I forget the torque number.
I guess if those Iron heads flowed just as well, he's in that neighborhood. |
Corey, looks like he's got mid-11s pegged!
So what are the flow numbers on ported 113s? AFR 190s? Instead of names and brands, lets talk numbers. |
So what are the flow numbers on ported 113s? AFR 190s? Instead of names and brands, lets talk numbers. AFR-195 Comp Package. http://members.aol.com/jsc41098/scan Protopline 180cc http://members.aol.com/jsc41098/flow |
Sweet!
Thank you! |
336rwhp & 363rwtq see sig.
Hey Dennis, Long time no see! |
LPE 219 is the right choice.
Great numbers, according to my info they are out flowing AFR 190's by a little and about 20 more than TFS.
Olman, maybe I missed something, what exactly is out flowing AFR 190's and TFS's?
Thanks. |
You have to be very careful when getting flow numbers. If your having them ported by someone. you should get a baseline flow data off an independant bench - send them out for porting (you should get a sheet from them - take it with a grain of salt), then go back to the same independant bench you used before for REAL comparison). Face it, the porter is not going to show you bad numbers. Olman- I am interested in what heads you have that are outflowing the AFRs listed above, maybe we are assuming you mean outflowing these particular ones. Anyways we did as I described above with our 227cc M2 T1 heads - and they barely broke the 300 barrier @ 307 - and these heads are known to be the best 23* heads on the market. So I am a little hesitant to believe a 19Xcc head could be close. :lurk: |
Thanks. |
I,m refering to the flow numbers published by Chevy Hi Performance.
AFR 190 I E .100 71 65 .200 144 115 .300 208 146 .400 244 176 .500 262 190 .600 261 197 TFS 195 .100 65 70 .200 133 102 .300 188 140 .400 226 164 .500 250 183 .600 No numbers The numbers for the exhaust on the TFS are with pipes. Most of the heads for SBC are listed on the Chev Hi Performance website. I apologize that I misread the the charts posted. :o |
Those #'s seem a little low. This is what the TFS site shows for their 23 degree heads.
NOTE: Tests conducted at 28" of water (pressure). CNC-profiled chambers. Kenny Duttweiler 62cc 23 Degree Airflow Chart 0.100 51 58 0.200 136 98 0.300 191 136 0.400 230 163 0.500 253 177 0.600 254 190 Kenny Duttweiler 64cc with CNC Chambers 23 Degree Airflow Chart 0.100 64 56 0.200 138 105 0.300 198 146 0.400 237 171 0.500 257 186 0.600 258 196 Kenny Duttweiler 72cc with CNC Chambers 23 Degree Airflow Chart 0.100 71 53 0.200 142 99 0.300 196 135 0.400 234 167 0.500 249 186 0.600 249 199 |
My former car had a "bread and butter" Lingenfelter 383. 219 cam, ported and polished super ram, factory d ports "worked" 58mm throttle body 700 R/3.45 d44.
I always had a traction problem..but my car was a 100 percent street car...no shocks for draggin' no sway bars off etc. The best I ran with it on a very worn set of bfg dr's was 11.80@120.2 mph. The car NEVER saw a dyno of any kind(until recently, the new owner had it done.) The scoreboards at the end of the track are the most honest and the only one's I'd need to see. God rest His soul, John Lingenfelter said the same thing"What a car does on the chassis dyno, and what it does on the track can vary greatly" :cheers: |
Originally Posted by Jay 383
The car NEVER saw a dyno of any kind(until recently, the new owner had it done.) :
Any idear what the numbers were? Just curious. Hole-shot |
Careful, what you say aloud in here with respect to dyno and their accuracy. Although I think its funny that Lingenfelter himself would share the same opion of dynos as we do. ;) |
