Fob Gurus
Old Feb 5, 2017 | 12:41 AM
owc6's Avatar
owc6
Default Fob Gurus
Can someone tell me exactly how the fob works in the slot even with no battery installed? Is it somehow RFID? or some other magic?
Old Feb 5, 2017 | 01:11 AM
LMB-Z's Avatar
LMB-Z
I think that's where the trunk monkey comes into play. I don't know any other way.
https://www.youtube.com/watch?v=-q6RevTK5yY
Old Feb 5, 2017 | 01:22 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Little Gremlins again.
First part is just getting in. Second part is your answer.
https://www.youtube.com/watch?v=fubTi5Hcosw
Old Feb 5, 2017 | 02:26 AM
Bruze's Avatar
Bruze
So far, nobody's answered your question Mrs. Ow.
And it won't be me, but I will be interested in the real answer.
Old Feb 5, 2017 | 04:19 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Electromagnetic Induction
You are inserting the fob into a coil and the coil induces the small amount of power necessary into the fob so it can respond to a query from the car.
You are also placing the fob next to the antenna associated with the Start button to minimize any negative effects from outside RF Interference.
https://en.wikipedia.org/wiki/Electromagnetic_induction
Old Feb 5, 2017 | 08:56 AM
EVRose's Avatar
EVRose
This!
And more specifically this.
Old Feb 5, 2017 | 09:00 AM
Bruze's Avatar
Bruze
Originally Posted by EVRose
This!
Thanks guys! I knew a few peeps here had the right answer.
Old Feb 5, 2017 | 09:26 AM
owc6's Avatar
owc6
This forum is awesome, thanks!
Old Feb 5, 2017 | 01:20 PM
NOWUCME's Avatar
NOWUCME
This!
Just to keep things simple the fob acts as a switch when inserted in the glove box hole. It takes current from a contact in the hole onto the outside of the fob, transfers it to the fob brain, just as a good fob battery would do. Then the fob, not something else, sends out a signal that can be recognized by the car just as if the fob battery were working. Pretty simple, not rocket science,
If you need to see a picture to believe......go to Minute 1.27 of this video. The first video I posted mentions the contact point on the outside of the FOB.
https://www.youtube.com/watch?v=EyEDDY8l9rg
Old Feb 5, 2017 | 01:45 PM
EVRose's Avatar
EVRose
So, how does that theory work with the 05-07 fob? There is no direct metal link between the outside and the inside of the fob. There is a rubber barrier over the buttons and the metal C6 symbol stuck to the outside of the fob has plastic behind it.
Oh, and BTW, in that second video at 1:39, those contacts the guy is pointing to is the positive (or negative, not sure which) contact point on the battery. That metal piece just pops out of the PLASTIC part of the fob. There are no external contacts points.
Old Feb 5, 2017 | 06:02 PM
owc6's Avatar
owc6
There is no metal contact to the inside of the case of the later C6 fob, either. It sounds like the maker of that video made an incorrect assumption, based on the fact that there is metal on both sides of the fob case.
As you can see on the right, there is no contact with the emblem which is above the battery, and on the left, the only contact is with the buttons, not the metal bars between them.
Old Feb 5, 2017 | 06:12 PM
Bruze's Avatar
Bruze
And the mystery continues . . .
Old Feb 5, 2017 | 06:21 PM
EVRose's Avatar
EVRose
It's no mystery. The guys in those videos are wrong.
Old Feb 5, 2017 | 06:26 PM
Bruze's Avatar
Bruze
Lol.
Old Feb 5, 2017 | 07:04 PM
Mad*Max's Avatar
Mad*Max
it's like I can't figure out how my electric toothbrush charges when it is plastic-to-plastic contact...maybe someone can answer that as well (sorry not trying to hijack the thread owc6)
Old Feb 5, 2017 | 07:10 PM
EVRose's Avatar
EVRose
See the link in post #6.
Old Feb 5, 2017 | 07:21 PM
owc6's Avatar
owc6
I'm a learning machine, today!
Electromagnetic induction = F.M.
JK, I think I really do understand how it works.
To Fob Gurus
Old Feb 5, 2017 | 07:24 PM
Bruze's Avatar
Bruze
Yes, I've wondered that too.
Although this had nothing to do with the toothbrush thing, a few years ago I looked up if electricity could be transferred over-the-air wirelessly. Actually it cannot, except in a limited way under laboratory conditions, and wouldn't be practical to actually use anywhere.
So . . .
Old Feb 8, 2017 | 09:42 PM
Mad*Max's Avatar
Mad*Max
read it, still don't understand the physics behind it but that's okay
Old Feb 9, 2017 | 10:07 AM
EVRose's Avatar
EVRose
I don't quite understand it either. I think it IS rocket science.
