C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Head Options
Old Oct 25, 2017 | 10:19 PM
JetstreamGS's Avatar
JetstreamGS
Default Head Options
Looking to repair/replace stock heads. What aftermarket head options are available for LS7? What advantages do they provide over getting the stock heads fixed and ported? Any advice/recommendations appreciated. Thanks folks.
Old Oct 25, 2017 | 10:48 PM
MTPZ06's Avatar
MTPZ06
No need to go aftermarket castings, but it certainly can minimize downtime for some folks. What are your goals? Max effort build for 600+ rwhp...mild H/C build...or just address the heads?
Places like AHP though, have stock cores in house set up and ready to go....so no downtime issue there either. Read up on AHP's Moldstar90 (MS90) valve guides...best guide material out there IMO.
Tony Mamo is producing some huge gains with his version of TFS heads, which appear to flow outstanding.
It just depends what you're looking to do...
Old Oct 25, 2017 | 10:52 PM
JetstreamGS
Max effort with a mild cam lol.
Was looking into a Mamo MSD. Tell me more about the Mamo TFS heads please.
Old Oct 25, 2017 | 11:10 PM
MTPZ06's Avatar
MTPZ06
As funny as that sounds...his topend packages (TFS, MSD, Cam) are producing really good power (peak and under the curve) without having to go with some ridiculously large (undriveable) cam. His TFS heads are essentially castings made by TFS to his specs. He is also using roller rockers in his setups, which I like for max effort builds...basically his own flavor of YellaTerra rockers. Custom specs cams based on your goals/wants/needs.
Lots of guys starting to run his stuff...here's a couple:
https://www.corvetteforum.com/forums...ts-are-in.html
https://www.corvetteforum.com/forums...d-install.html
Old Oct 26, 2017 | 02:04 PM
whiteZ's Avatar
whiteZ
AHP for me! Kohle was great to deal with and he explained every detail so that even I could understand :-)
Old Oct 26, 2017 | 02:27 PM
redcycle13's Avatar
redcycle13
Speaking of Mamo heads specifically. They provide greater flow with a smaller port, so the max potential is higher. They also eliminate the factory casting problems altogether vs potentially just resetting the clock on the reworked factory part.
I understand AHP has an excellent reputation for durability and performance with reworked stock castings, and if I had not been after a max effort combo, I would likely have chosen them.
Old Oct 26, 2017 | 06:32 PM
SgtBAXMAN's Avatar
SgtBAXMAN
8th Gear
I like to open track my car (Laguna Seca, Sears Point, Thunderhill), but also use it as a weekend enjoyment/stress reliever. I researched the LS7 head issue extensively, and determined there is a lot of unsupported rhetoric out there. People just relaying what they've heard or read, but with very little actual/specific details. However, that being said, there are enough instances that DO have supported documentation and facts that left me with the realization that its just too much of a crap shoot not to address the heads. Once I came to that realization, the next question was who to get the heads from. For me, American Heritage Performance ("AHP") was the answer. My choice was cemented after going back-and-forth for a week with Kohle (AHP owner, I believe) via email. I told him what my true intentions were with the car (2007 Z06) -- open track events, 1/2 top speed runs and weekend jaunts up & down the coast -- and most importantly, reliability. I usually short-shift (6250 RPM), but on rare occasions, might see 7000 RPM. He took all of that into consideration and gave me his honest opinion about what he would recommend for my application. He did NOT sell me on the highest priced options. I really appreciated him taking the time to respond to my questions, provide solid feedback and generally educate me. I appreciated it so much, I submitted my order! I'd bet if you contact him, tell him your honest goals with your car, he will help guide you to the proper heads for YOUR application -- even if it is not with American Heritage Performance (if, for some reason, his shop could not produce adequate heads for your needs).
Old Oct 26, 2017 | 10:48 PM
bd4airman11's Avatar
bd4airman11
Nothing bad with the stock heads.....just have someone that dose the LS7 head....AHP, MANO, are the best...I fixed the stock heads with 90 guides, BTR stage 3 cam, SS Ferrea valves, NW 102, BTR Ti valve spring set, MSD intake...
Made 572rwhp and 509 in Torque...Now that said, Mano can get more for sure.....but for local guys and I did the work I am happy with the money for HP....This was on a mustang dyno.....Just fix them and your good...............
Old Oct 26, 2017 | 10:57 PM
Navy Blue 210's Avatar
Navy Blue 210
Who is Mano?
Old Oct 26, 2017 | 11:15 PM
REDZED2's Avatar
REDZED2
Originally Posted by Navy Blue 210
Who is Mano?
:rof l:
Old Oct 26, 2017 | 11:27 PM
REDZED2's Avatar
REDZED2
Honestly with zero budget and endless money, Mamo's stuff is all the best or top of the mountain.
Old Oct 27, 2017 | 12:09 AM
bd4airman11
Who is Mano?
Google.....Tony Mano
He is at the top of this stuff....then try AHP....American Heritage Performance....
You have to dig a little.........
Old Oct 27, 2017 | 12:14 AM
MTPZ06's Avatar
MTPZ06
Old Oct 27, 2017 | 12:59 AM
meinersk's Avatar
meinersk
I looked at the fast list and oem engines and I chose GPI gwatney performance inovation...Getting car back soon and will try for 9 sec oem n/a..gpi has number 2 possibly no 1 car on the fast list...I hope to be right there in a few weeks..
Old Oct 27, 2017 | 04:48 AM
REDZED2's Avatar
REDZED2
Sure you will. That's the spirit. SOOO easy!! #1 bud!
Here's a shop that more than you have heard of. They kind of have one or two (sarcasm for those who live under a rock) 9 second Z's NA. RPM.. Race Proven Motorsports. Forum Sponsor. ...but slick *****'s fast times motors in the Ozark Mountains makes sick fast vettes too!!
Old Oct 27, 2017 | 04:49 AM
REDZED2's Avatar
REDZED2
Originally Posted by MTPZ06
Epic fail Meme Mike!!!
Old Oct 27, 2017 | 10:31 AM
TXGS507's Avatar
TXGS507
Mano....? Wasn't he Pacino's side kick in Scarface?
To Head Options
Old Oct 28, 2017 | 03:19 PM
Navy Blue 210
I Know who Tony Mamo is LOL!
He did the MAMOFIED LS3 Heads & MAMOFIED FAST LS3 with Mid Length Runner Intake for my 690 HP Custom 396" Big Bore Engine.
Just poking at you a little after the 2nd MISSPELL in your post,
and providing some humor & publicity at the same time.
Old Oct 28, 2017 | 08:59 PM
bd4airman11
Ya, I get it.....I am not a secretary and I flunked typing....If I would have known how important and how much a keyboard was going to affect us 50 years ago when I was in public school......I would worked harder to get it.............
Old Oct 29, 2017 | 05:51 PM
jayyyw's Avatar
jayyyw
I may be selling my fixed, stock casting heads. They are milled .050", ported by Lingenfelter, Ferrea exhaust valves, and BTR .660 lift springs. Looking to go more aggressive and want to start with fresh castings. Made 600whp with a BTR stage 3 cam and Mamo MSD intake. Heads have, roughly, 6k miles on them. Mostly street driving.
