Help... Air deflector.. how many parts are there to it
Old Oct 31, 2017 | 09:56 PM
jockro's Avatar
jockro
8th Gear
Default Help... Air deflector.. how many parts are there to it
HELP!!! It appears that my air deflector under my frt bumper has broken on the drivers side. It appeared to be a seperate piece when I removed it... Now there is another plastic piece hanging and appears to have a tube attached.. I am freaking out.. Can someone tell me what it is so I can order it.... =) Thanks RAJ
Old Oct 31, 2017 | 09:58 PM
HBsurfer's Avatar
HBsurfer
There are three pieces. No reason to freak out. I think you can buy the whole set for about $100.00
Old Oct 31, 2017 | 10:16 PM
EVRose's Avatar
EVRose
The tube you mentioned is most likely the brake cooler conduit.
Old Oct 31, 2017 | 11:10 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Have a friend look at it, preferably a Boy that doesn't freak out. Even better send a pic of the hanger on Sounds like the beginning of a TR to me.
Old Nov 1, 2017 | 12:23 AM
owc6's Avatar
owc6
Besides being insulting, you didn't actually give much info to the OP. What's a "TR"?
Old Nov 1, 2017 | 12:53 AM
NOWUCME's Avatar
NOWUCME
Hmmm so quick to judge, just my opinion and more than the OP gave us. Profile is a woman that's all we know. Maybe, you might prefer to answer her than call my shots......T.R.O.L.L to me, maybe not, still gave my advice. Didn't see yours.
Maybe you just don't like I told her to have a Boy, preferable one who knows what they are looking at, check it, or send a Pic.....Maybe there is a woman that could do the same......is that to tough to get more info that she needs? Seemed reasonable to me...Just Saying.
Have it your way if you like. I take it you were insulted...
Old Nov 1, 2017 | 09:13 AM
rkj427's Avatar
rkj427
Pro Mechanic
There are (3) separate pieces, the center section will be a softer material and is common to both the base and wide-bodied cars.
The right and left hand outer pieces are different between a base car or a wide-bodied version and all are available separate.
Recommend that if you are looking for OEM parts to contact Gene or Patrick at www.cultragfactoryparts.com forum vendor here with a great reputation.................
welcome to the forum................
Old Nov 1, 2017 | 11:34 AM
jockro's Avatar
jockro
8th Gear
Ok, yes I'm a woman and I am not completely illiterate to cars.. However when I was googling a replacement part it appeared that all I could find were 1 single price... But as a couple of folks has mentioned there are 3... I have an 08 ZHZ.. Wide body? Normal body? I am just trying to fix my car without a huge cost.. Rkj427 thank you for the info as well as you other guys/girls...
Old Nov 1, 2017 | 11:38 AM
jockro's Avatar
jockro
8th Gear
Rkj427... When you say I need to look at OEM parts what exactly am I looking for? Do you know if I have to buy it all or if I can buy the 2 prices (the deflector and the other plastic price with the tube attachwe.. Hence I don't know the names) desperate... I appreciate your help..
Old Nov 1, 2017 | 12:01 PM
rkj427's Avatar
rkj427
Pro Mechanic
you can order them individually, usually the center piece doesn't get replaced, as it is a different material (softer) and it takes more to damage it where it should be replaced.
at work currently but your model is a base car or narrow bodied version................ below is a link to one on Amazon which shows pictures and pricing...............
Amazon Amazon
this one on Amazon costs about as much as the 2 outer pieces would cost from GM................
Old Nov 1, 2017 | 12:10 PM
jockro's Avatar
jockro
8th Gear
https://www.amazon.com/Corvette-Comp.../dp/B00FKSIUMM
Thank you.., I will try and get a pic for you so you can maybe tell me the other part as well.. Your awesome. Thanks
Old Nov 1, 2017 | 12:19 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Or try here...parts 14 and 17...
https://www.cultragfactoryparts.com/...nts-front-scat
Old Nov 1, 2017 | 12:36 PM
rkj427's Avatar
rkj427
Pro Mechanic
Originally Posted by ruxvette
thank you for posting this..................
knew I could count on one of my Corvette brothers to bail me out........................
Old Nov 1, 2017 | 12:39 PM
jockro's Avatar
jockro
8th Gear
ruxvette.. I don't see my parts there...
Old Nov 1, 2017 | 12:47 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
jockro ....
Is the C6 your talking about a Base, Grand Sport or a Z06 model ?
Old Nov 1, 2017 | 12:57 PM
EVRose's Avatar
EVRose
Is this the part you're talking about?
Old Nov 1, 2017 | 01:05 PM
jockro's Avatar
jockro
8th Gear
oh yes.. That is one of them.. And the other is right above it and has a tube attached
To Help... Air deflector.. how many parts are there to it
Old Nov 1, 2017 | 01:09 PM
ruxvette's Avatar
ruxvette
Item number 14 is for the long center piece, item 17 are the corners, left and right...IF you are talking about the center air deflector under the car.
Item 14 Part 21992641
Front Deflector BASE
Item 17 Part 20896059
Lower Deflector, LEFT BASE
Item 17 Part 20896060
Lower Deflector, RIGHT BASE
Old Nov 1, 2017 | 01:20 PM
Turbo6TA's Avatar
Turbo6TA
I thought she might me talking about the front splitter ... that's why I asked if she had a base or wide body car
Old Nov 1, 2017 | 01:25 PM
EVRose's Avatar
EVRose
That IS the piece that has the tube attached. That tube is the air duct for the brake caliper cooler.
