What did you do to your C5 today?
Old Apr 5, 2018 | 08:04 PM
  #881
WetMountainMan's Avatar
WetMountainMan
Originally Posted by golfnutts
Installed a Dash cover to cut down on the glare for my future 4000 mile trip in 3 weeks.
Sounds like a good idea, mine really produces a glare. What did you use?
Old Apr 6, 2018 | 08:45 AM
  #882
Fcar 98's Avatar
Fcar 98
Finally was able to get it out of the garage and drive it. Roads are still full of pot holes. Had to be very careful.
Old Apr 6, 2018 | 09:26 AM
  #883
jost6453's Avatar
jost6453
Originally Posted by WetMountainMan
A test really. Not sure how filtered that air is. I know air is being pulled through there and it's entering the TB. With oil under the valve covers and on the rockers, I wanted to see, with the suction and the presence of oil being splashed around, if any is sucked up through that line. If I find none in a couple of thousand miles, I'll put a solid line in again. I don't see that it hurts to find out.
Please report back what you learn. I thought the flow was the other direction, .... from the TB into the valve cover area and then vented out trough the PVC circuit into the intake. But I'm usually wrong. Just ask my wife!
Old Apr 6, 2018 | 01:20 PM
  #884
slopoke17's Avatar
slopoke17
I know how you feel, it's April 6th and we're getting snow in Western MA.
Old Apr 6, 2018 | 01:50 PM
  #885
WetMountainMan
Took a look at it - still there - LOL, then checked the intake manifold number to see if I have an L6 head and manifold - and I do. (2002 Base Vert)
Old Apr 6, 2018 | 03:59 PM
  #886
bradmaunsell's Avatar
bradmaunsell
Default Love putting around in my Corvette
It's pretty nice here in Naples Florida today - 86 and sunny.
Just took my C5 on errands to hardware store and auto-zone to pick a few things.
Got another month before we go back north to Vermont - taking Corvette back and swinging through Nashville for a few days.
​​​​​​​Getting old isn't all bad.
Old Apr 6, 2018 | 04:41 PM
  #887
cwf04vette's Avatar
cwf04vette
Originally Posted by cwf04vette
Found out my battery was shot. It has been on a tender but it won't turn the car over. So, the search begins for a new battery.
Replaced the battery and she started right up. Got an Interstate with 5 yr warranty. Now I have to wait for Mother Nature to cooperate.
Old Apr 7, 2018 | 10:08 PM
  #888
FOGeologist's Avatar
FOGeologist
Changed the transmission fluid from some kind of red synthetic back to Dex III, but the one with the friction modifier - GM part no. 88900399. The garage that reconned my car before selling it to me added a quart of a synthetic (it's probably Redline, B/C that's what was put into the motor). I don't think they knew about the paper blocker issue in the trannies before 2000. When the oil came down into the pan, it had clouds of shiny metal in it; it looked like candy apple burgundy paint with loads of metal flakes in it. Shifting is graunch-free now and seems smoother.
Also adjusted the emergency brakes. Lots of meat left, just put a few clicks into the mechanism after spraying the whole affair with brake-cleaner, and the e-brake doesn't pull up quite all the way anymore, and the car stays planted on my sloped driveway.
Lastly, I removed the center console to adjust the shifter. I discovered the PO put in some sort of blue-anodized short-shift kit into the car. I pulled it out and lubed it up with some white lithium spray grease, and pinned the shift shaft while I loosened, then re-torqued the box and shaft to spec.
Shifting is much, much more direct and accurate now, and I think my reverse-gear popout problem is either licked or reduced. I suspect I will have to pull the tranny down and do the reverse gear switcheroo and replace the fork pads at some point in the future.
Old Apr 8, 2018 | 12:40 AM
  #889
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Dusted it off, drove it and wound up at a car show for autism. Had a great time. Video will be posted in a day or 2.
Old Apr 8, 2018 | 03:16 AM
  #890
golfnutts's Avatar
golfnutts
Ordered from Amazon from West coast corvettes for 49.99. Black with C5 emblem in the middle. Fits perfect with HUD. Cut the Glare by 90% and I have a 2003 A/E so the shale color dash really had a bad glare when driving.
Old Apr 8, 2018 | 01:02 PM
  #891
2_hotty's Avatar
2_hotty
I installed this:
To get this stance:
Old Apr 8, 2018 | 03:28 PM
  #892
mstromquist
Nice, let us know how you like them. I'm still going to get a set but not sure which brand or when yet. Looks great.
Old Apr 8, 2018 | 05:01 PM
  #893
Ramets's Avatar
Ramets
Just finished with my Carbon fiber wrap of the top. I'll be doing the mirrors next.
Old Apr 8, 2018 | 05:27 PM
  #894
sloopdawg's Avatar
sloopdawg
love the bird man !!!
Old Apr 8, 2018 | 08:54 PM
  #895
whalepirot's Avatar
whalepirot
Top down, early morn drive! (The car needed it!)
Old Apr 8, 2018 | 08:58 PM
  #896
pjdbm's Avatar
pjdbm
Installed Brakemotive rotors & brakes with SS pad covers
Old Apr 8, 2018 | 09:04 PM
  #897
Dixie Sasquatch's Avatar
Dixie Sasquatch
Brass headlight gear kit
To What did you do to your C5 today?
Old Apr 8, 2018 | 10:06 PM
  #898
WetMountainMan
Inspected my sway bar links - all seem good.
Old Apr 9, 2018 | 11:47 AM
  #899
ZeroToSixty's Avatar
ZeroToSixty
2 piece, wet-suit grade, Neoprene Seat covers,..........they really help with support and grippiness with the seats.
Old Apr 9, 2018 | 11:52 AM
  #900
chasboy's Avatar
chasboy
Oldtimer
are they from Wet Okole?
