Lifter preload
Old 06-04-2019, 06:12 PM
  #61
bwill03z
CF Senior Member
bwill03z's Avatar
Originally Posted by DetroitPlac View Post
https://youtu.be/gxo_iGD_uMc
Here's my car (excuse the mess, I'm just about to clean it up)...just took this after my drive home. Everything up to temp, Oil hot (200), etc...the fans turn on and mask it a bit at some point. Shot on my phone (pixel 3a), so quality really isn't great...I think the noise is a bit more noticeable in person.
Noise is most prevalent from the bottom, and you can hear it when I go down to the ground.
This is improved over where I started by running less preload and Mobil 1 0w40.
Sounds similar to mine but definitely smoother and quieter
bwill03z is offline
Old 06-04-2019, 06:13 PM
  #62
bwill03z
CF Senior Member
bwill03z's Avatar
Originally Posted by Speedy007 View Post
I agree with Detroit the springs are to heavy for your mods. Down grade to a regular beehive @.600 think it will fix your issue.
What about letís say the PAC 1219 springs?
bwill03z is offline
  #63
Speedy007
CF Senior Member
Speedy007's Avatar
Originally Posted by bwill03z View Post
Very smoothe, minus the belt lol
Thanks ya I had way overfilled the power steering and went it went on the jack stack it leaked out all over my belt shoulda heard when it first happened lol. Sounded like every pulley bearing was shot. Just got in my new o2 meter. The Vc-50 is next.
Speedy007 is offline
Old 06-04-2019, 06:18 PM
  #64
Speedy007
CF Senior Member
Speedy007's Avatar
Part # 12625033 I believe.
Hereís a example of what you prob should have for springs. Notice one is new but if you look up the part # they will be blue color
Old 06-04-2019, 06:38 PM
  #65
bwill03z
CF Senior Member
bwill03z's Avatar
Looks like the PAC 1219 springs are for cams under 230 duration and rated to .625 lift so maybe these would be better for my 228R than the dual .660 springs I have. If I swap to these I may try a different pushrod also to experiment with preload. If I run any longer I would be maxed out on preload so I would prob try a 7.375 pr
bwill03z is offline
Old 06-05-2019, 09:36 AM
  #66
DetroitPlac
CF Senior Member
DetroitPlac's Avatar
Guess it depends HOW quiet you want it. I'm still running heavy dual springs, and less preload on the lifters (with 7.375 PRs) quieted it down enough to be acceptable to me. As you could hear, it still makes some noise though.
Another thing to consider is your intended use of the car. If you're doing a lot of track and high RPM driving, dual springs offer a nice safety net in the event of spring failure.
For a mostly street car, these lighter springs are probably the way to go.
DetroitPlac is offline
Old 06-05-2019, 10:32 AM
  #67
bwill03z
CF Senior Member
bwill03z's Avatar
Well I donít expect a dead silent motor, although that would be nice. These are naturally noisy motors esp with a cam so I donít mind some noise but what mine sounds like right now is unacceptable to me, itís embarrassingly loud and if I donít find some sort of resolution the car will most likely go up for sale. Some ppl might say thatís stupid bit Iím sort of a perfectionist sometimes so it really drives me nuts. I canít enjoy driving the car because all I hear is a loud *** sewing machine. I may just have a not so healthy motor bc even bone stock I thought it was a bit noisy. I Found A video of when my motor was completely stock. Doesnít sound terrible but a little noisy to my ears for completely stock motor.
bwill03z is offline
Old 06-12-2019, 04:09 PM
  #68
DetroitPlac
CF Senior Member
Hey bwill, clear your PMs.
Old 06-12-2019, 04:31 PM
  #69
bwill03z
CF Senior Member
bwill03z's Avatar
Sorry, should be able to send msg now
bwill03z is offline
Old 06-15-2019, 01:43 PM
  #70
turabo87
CF Senior Member
turabo87's Avatar
Bwill, did you ever check your entire exhaust to see if you werenít having direct contact with the tunnel of the car? I just fixed my midpipe today at the muffler shop and my valvetrain noise in the cabin is now gone. No more sewing machine. Worth checking.
New mid pipe segment welded, no more direct contact with the tunnel
turabo87 is offline
Old 06-15-2019, 04:01 PM
  #71
bwill03z
CF Senior Member
bwill03z's Avatar
Glad you got yours fixed! Yes I did check the exhaust and itís not touching the tunnel anywhere unfortunately. I didnít suspect that to be the issue cause you can clearly hear in the cabin that the noise is coming from the motor. I am going to put some shorter pushrods (factory ones actually) in to see if a little less preload makes any difference at all.
bwill03z is offline
Quick Reply: Lifter preload
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
