C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Time to re-power the race car.. New goals 280mph and 2000ish HP
Old 06-03-2019, 11:58 AM
  #141
MTBSully
MTBSully's Avatar
Beautiful. Hotside all stainless? What are you using to make your pie cuts? Chop saw?
Old 06-03-2019, 12:16 PM
  #142
RecMech
RecMech's Avatar
Originally Posted by chuntington101
Stunning as every. How big are the cross over pipes on yours?
Thanks.. 3" crossovers, 5" downpipe
Old 06-03-2019, 12:22 PM
  #143
RecMech
RecMech's Avatar
Thanks! Yup, all 304 stainless. I may try to vband the downpipe about half way and run aluminum out the fender to save weight.
5" pie cuts are from Stainless Bros (Ticon) and are top level quality. Everything else I am doing on a porta band with a Swag Offroad table and a 12" disc sander.
Old 06-03-2019, 01:06 PM
  #144
chuntington101
chuntington101's Avatar
Are 3 inch not a bit overkill? Or is this to help with heat?
Old 06-03-2019, 01:11 PM
  #145
RecMech
RecMech's Avatar
They are oversize.. I can spray out any lag, and really just want max flow during the long pulls we make. I am sure it will help with heat and who knows maybe a 118mm turbo down the road
Old 06-03-2019, 01:37 PM
  #146
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
Looks just awesome. More pics!
Old 06-10-2019, 11:20 PM
  #147
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Dayum....
Old 06-11-2019, 01:49 PM
  #148
jayyyw
jayyyw's Avatar
Do you remember what setup you used to convert to cable pull throttle body?
Old 06-11-2019, 02:12 PM
  #149
RecMech
RecMech's Avatar
Its being controlled by the ProEFI, so fairly straight forward electrically. TPS is whatever number the Holley TB recommended. The IAC is in place, but probably not needed.
Lokar throttle pedal with a custom arm extension, toe clip, and Lokar cable.
Let me know if you need something specific.
Old 06-11-2019, 04:19 PM
  #150
jayyyw
jayyyw's Avatar
Mainly the pedal and throttle cable setup. I wonder if you can leave the TB plugged in and run a cable TB with the OEM setup.
Old 06-12-2019, 09:16 AM
  #151
RecMech
RecMech's Avatar
I would think you would run into issues trying to match TPS1 and TPS2 along with the pedal position?
Old 06-12-2019, 09:43 AM
  #152
jayyyw
jayyyw's Avatar
Yeah, I forgot about the pedal, lol. I'm considering swapping to the Holley Terminator X. It's been done before but no one has really said what pedal and cable they used.
Old 06-12-2019, 04:00 PM
  #153
RecMech
RecMech's Avatar
I was able to finish weld, prime, and paint the chromoly front structure.. Starting some final assembly and working on the downpipe.
The following 2 users liked this post by RecMech:
niterydr (06-13-2019), schpenxel (06-14-2019)
Old 06-12-2019, 04:41 PM
  #154
jayyyw
jayyyw's Avatar
Everything looks so good! Keep those updates coming..
Old 06-12-2019, 05:02 PM
  #155
Quiky One
Quiky One's Avatar
will that inlet style not be a restriction versus one pipe? I love the design.
Thanks, Jason
Old 06-13-2019, 10:59 AM
  #156
boldtx
boldtx's Avatar
Hell yes can't wait to see how the finished product does.
Old 06-13-2019, 11:23 AM
  #157
RecMech
RecMech's Avatar
Thanks, Jason
I figure the two sides have to merge somewhere... This is far easier to weld than a pipe merge and seems stronger, although it would be nice the see flow numbers.
To Time to re-power the race car.. New goals 280mph and 2000ish HP
Old 06-13-2019, 10:28 PM
  #158
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Thanks, Jason
Compared to where the turbine housing chokes down and hits a compressor wheel. Two 3" pipes going into a 1" hole with a turbine wheel, the inlet is the least of worries about a restriction.
Old 06-24-2019, 03:42 PM
  #159
RecMech
RecMech's Avatar
Some plumbing and wiring running thru the fender. I am going to make the bumper easy to remove for access. I am really trying to keep it clean under the hood yet still functional.
Also relocated a fire nozzle to better cover the turbo. Second hardline is CO2 for the wastegates.
(the zig zag water plumbing to the intercooler will be changed !)
schpenxel (06-24-2019)
Old 07-08-2019, 12:16 PM
  #160
jayyyw
jayyyw's Avatar
Sorry to bother, do you have more pics of your rear mounted radiator setup? Any issues cooling sitting at idle for extended periods (if you even do that)?
Quick Reply: Time to re-power the race car.. New goals 280mph and 2000ish HP
