1971 LT1 roadster find and Qs
#121
Old Pro Solo Guy
[/QUOTE] I’ve had a lot of holly carburetors a part before. But I have never seen any baffling inside like this before?[/QUOTE]
Factory installed on OEM '71-72 Holley for then-new Evaporative emissions regulations. Reduces bowl volume so less grams evaporates after shutdown.
Also came on my over the counter GM 4803 Holley.
I found a quote in an old Holley book. If you want it, PM me and I'll scan it for you.
Just one more example of a so-original car, even including the brass fuel filters.
https://www.corvetteforum.com/forums...lley-part.html
#124
First, as you'll see, you need to undress it!
The video was done on phone, I downloaded it to my computer, put it up on Utube, and then put it in here as a link. You might well be able to load it to Youtube direct from your phone. The forum wouldn't take it direct from my computer, wrong format.
Good luck! I was wondering if the TI ignition was still viable.
#125
C2 of Year Finalist (stock) 2019
i have never heard of the GM heritage site? it has info on the LT1 in general? or mine specifically? what is the web site address? thanks troy
#126
https://www.youtube.com/watch?v=HSUTa1NwFNI
#127
https://www.gmheritagecenter.com/gm-...tion-kits.html
Here is the one for the 1971 Corvette. (it's non-specific to a particular VIN)
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Download it and save it to your computer and it will make a terrific reference guide for your car.
Good luck... GUSTO
20round (06-12-2019)
#128
Troy, you can go here and get the Vehicle Information Kit on just about any Chevrolet made since 1913.
Good luck... GUSTO
Good luck... GUSTO
#129
Old Pro Solo Guy
I found the documentation on the strange Holley bowl stuffers you found. Just one more authentic original piece on that car. Here is an article that mentions that they are original and why:
From a 1976 copy of Holley Carburetors & Manifolds by HP Books & Mike Ulrich & Bill Fisher:
"Evaporative Emissions - In 1970-71, total evaporative emissions allowed from any car were six grams per hot soak. In 1972, that allowance was reduced to two grams per hot soak. It should be noted here that this reduction in allowable evaporative emissions created the need for reducing the bowl capacity of some Holley Carburetors with bowl stuffers."
20round (06-14-2019)
#131
i just bought one of those books..its publication date is 1976.. i could not find one dated 1978? there was one dated 1972 1976 and 1987... thanks again..troy
#132
Old Pro Solo Guy
It was this one. It does say 1976 copyright printed. date - (my bad) but it also says revised 8-78 So i'm not sure what year it is. Carb stuffers on p. 149
#135
no moosie,
i have been busy on the farm. i drove it around, and put about 30 miles on it going too buddys houses showing it off. then i took the top out of it so it could air it out, and i put it in the building.. i start it every few days just too here it ! that things runs pretty good. so it will sit for a few more months until i get the 68 ready for paint.
on another note, i found a 69 427 coupe one owner thats been sitting since 89. the son of the OP has been storing it in his garage and wants it gone.. OP is too old and does not care about the car or have the knowledge too do anything with it .. so i may have too find a hiding spot! ....troy
#136
Killer this is the Earliest known built at 150 and I have the latest known 71 LT1 built at 21783 - Last day of production.
