What's this tire sensor thingy worth?
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
A couple of years ago I bought a pair of used track tires and wheels already mounted. Yesterday I broke them down and one of them has the tire pressure sensor strapped to the inside of the wheel. Is it worth enough to sell to someone who might need it?
Just put new tires on the CE
the right front sensor was broken (cracked)
I though it might be OK for awhile.
it didn't last but a few weeks then came off flooping around inside the tire.
It cost $340 to have it replaced. I called the dealer and it was priced at over $300 just to buy it.
Before it broke, the low tire light was on, after it broke the 'LTPSW service soon' light came on, after it was replaced the low tire light still comes on.
Originally Posted by BetweenVettes
I might be interested in it depending on if it works, what year it is off of (I need '93-96), and which tire it is for.
Originally Posted by Corvette Kid NC
Does it really make a difference what wheel position it's for? I'm asking, I don't know but wouldn't understand why.
Location: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Originally Posted by Hot Rod 90
chris, yes. each is color coded & part-numbered. this is necessary because a different code is set in the DIC attributable to each wheel for immediate identification of a sensor fault at that wheel.
"Factory position-RR" (makes sense since it came off of a RR sawblade)
"GM P/N 10161857"
"Epic P/N 1000 5001"
It's even got a serial# for chrissakes.... I'm not going to post that. If it's stolen, I didn't do it!
Now, is there any way to tell if it's any good? No, my car doesn't have this option.
I need this part - don't expect you still have it?
I see now. It's amazing what you can find out if you read the label....
"GM P/N 10161857"
"GM P/N 10161857"
Bulbs are behind the panel. Unplug the LTPWS
The bulbs are behind the panel.If you take the fuse out you loose your cruise control to. The LTPWS Module is under the dash. I am going to try and just unplug mine from the harness. If it works I will find the hot lead and put a switch in.
I have a spare tire.
