Need a new cam for my motor (355 sbc 12:1)
Old Nov 26, 2006 | 09:39 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Default Need a new cam for my motor (355 sbc 12:1)
I was thinking maybe this cam. I have 1.6 rockers and It is going to be a solid roller.
Voodoo Mechanical Roller Camshaft
Lift: .555''/.566'' ( roughly .590/.600 )
Adv. Duration: 261°/267°
Duration @ .050'': 231°/237°
RPM Range: 2500-6500
This brings up another question. Is it easy to convert hydraulic rollers to a solid roller?
Old Nov 26, 2006 | 10:28 PM
Kalway's Avatar
Kalway
Ick, go hydraulic roller. Solid requires too much attention.
Old Nov 26, 2006 | 11:08 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You can run 12:1 CR on the street but you need a cam in the 260-270degs @ .050" to run on pump gas. It will be a little soggy on the bottom end but should really start to scream at 7500 RPM I would pick a cam first then match the compression ratio to the cam unless the shortblock is already built
Old Nov 27, 2006 | 02:29 AM
l88rocket's Avatar
l88rocket
A 12.1 355 is going to be a screamer,it'll need to spin to around 7500 to make peak power,I would suggest Motorhead and pick a cam 1st then compersion.
Good Luck
Old Nov 27, 2006 | 08:24 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Not really! If you run stud girdles or shaft rocker arms, little attention is needed.. I checked my lash after 100 drag strip passes and it was close to perfect!
Old Nov 27, 2006 | 08:27 AM
GrandSportC3
I like my cam. Don't have the part number handy but it is a Comp Cams solid roller cam with .630 lift (.672 with1.6 rockers) and 264/270 degrees .050 duration and 300/308 degrees advertised duration and 106 degres lobe separation! Great Cam!!
Old Nov 27, 2006 | 08:38 PM
Kalway's Avatar
Kalway
Reminds me, good point. If the engine is only intended for off-road use anyways go for it. If it's going to be used on the street, though, I'd go hydraulic just so there's less maintenance.
Old Nov 27, 2006 | 09:05 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I actually go to thinking I want to keep the same cam .550 lift with 1.6 rockers so I don't have to change my springs. Maybe I should just put solid lifters and a cam with more duration so I can go to 7000 rpm. Right now im running a cam with 236* duration @ .50 lift.
Old Nov 27, 2006 | 09:44 PM
MotorHead's Avatar
MotorHead
Do you really have a 12:1 355ci ?
Old Nov 28, 2006 | 04:29 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Nov 28, 2006 | 04:52 AM
Kalway's Avatar
Kalway
12:1 would require some pretty domed pistons or extremely tiny chambers...
Old Nov 28, 2006 | 08:19 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i have a set of heads that are 53.6cc's. that will get you to 12.4 with flat tops.
Old Nov 28, 2006 | 09:42 AM
mandm1200's Avatar
mandm1200
It will take more than that to get at 12.4. That would put a typical engine in the 11-1 ratio. The block would have to zero decked and a thin head gasket (.018") to get up that high.
Old Nov 28, 2006 | 10:33 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
yes you are correct a block decked and a .017 gasket.
Old Nov 28, 2006 | 04:55 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
58cc(maybe less) with decked block and skinny gaskets. Some where close to 12:1. I doesn't run on 93.
Old Nov 28, 2006 | 07:21 PM
BigBlockk's Avatar
BigBlockk
What do you mean (maybe less)? If you're going to be pushing 12/1 compression you better "know" what size they are.
Putting around the backyard isn't too bad but, WOT and 7000 RPM at the top of first gear is NOT the place to find shortcomings in your parts selection.
BigBlockk
Later.....
Old Nov 28, 2006 | 07:29 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Crane cams
Hyd = 114571
Hyd. Roller = 119651
Mech roller = 118611
Mech = 114681
To Need a new cam for my motor (355 sbc 12:1)
Old Nov 28, 2006 | 07:42 PM
Kid Vette's Avatar
Kid Vette
Old Nov 28, 2006 | 09:10 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
BigBlockk
Later.....
Mahle pistons, eagle h beam rods, steel crank(not sure if its forged ),l-98 corvette heads ( I say im not sure if there 58cc becuase he may have milled them down. They are also flowed)
My twin turbo motor is also coming together
Old Nov 28, 2006 | 09:15 PM
Guru_4_hire
Cruise-In V Veteran
You are probably closer to 11.1 --> 11.5
A good hydraulic roller or mechanical cam.
It never hurts to call crane or comp cams and ask them. It is free.
