Rear End Redline oil: 75W90 or 75W140
Old 09-11-2008, 08:14 PM
ArcticWhite
ArcticWhite's Avatar
Default Rear End Redline oil: 75W90 or 75W140
I'm going in to do a rear end seal fix. I've got a stock set up rear end, but am pushing 590rwhp through it. Would 75W140 be better than stock weight? I know RPM recommends 75W140, but their rear ends aren't set up like stock.
Car is only street driven, but sometimes gets a workout.
Z0HPLZ (04-24-2018)
Old 04-24-2018, 02:46 AM
Z0HPLZ
Z0HPLZ's Avatar
anyone have any good input on this question?
Old 04-24-2018, 08:53 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
RPM built my c6z diff, it's a c6z case with wavetrac diff, dss shafts, and stock c6z pinion/ring gear... car makes about 850 and they said the 75/90 was fine... I've been using that since I did the swap and haven't had any issues... fwiw I put a little over 700 through the stock c5z trans/diff for a couple years with amsoil atf in the trans and 75/90 in the diff and it never gave me any problems either
Old 04-24-2018, 09:05 AM
ArtClassShank
ArtClassShank's Avatar
I used 75W/90 with no issues. Stock trans/rear.
Old 04-24-2018, 05:51 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Old 04-24-2018, 11:06 PM
Anthony F
Anthony F's Avatar
It's designed and built to use 75w-90, i wouldn't attempt 140.
Old 04-24-2018, 11:28 PM
NSFW
NSFW's Avatar
How much of it for the trans, and how much for the diff?
Old 04-25-2018, 03:49 PM
TastyBacon
TastyBacon's Avatar
I accidentally bought a bottle of each last time I changed the fluid, and I didn't notice until I had already pumped the quart of 75W-140 into the diff. Purists may gasp that I would treat my precious vette this way, but I just pumped the 75W-90 in after it and have been running half-and-half for the last couple years. Been through a track day and lots of street miles since then, no problems. As others have noted, I don't think there's a good reason to run 75W-140, but it doesn't really seem to matter much.
Old 04-25-2018, 04:06 PM
'Shifter
Thoroughly chapped
'Shifter's Avatar
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
75w140 will actually increase diff temp if the tolerances are cut for 75w90. Change it more frequently if you feel the need, but you're better of buying a cooler assy for it...(expensive as all get out though)
To Rear End Redline oil: 75W90 or 75W140
Quick Reply: Rear End Redline oil: 75W90 or 75W140
