HELP dome dash lights not working. Confused
My radio and a/c lights up and works. But the controls for cd and station changes, a/c selections and the lights rightt of the stering wheel controling fuel,trip, reset,etc. are not lit at night. HELp have checked all fuses under passenger side and beside the battery.
Is there something set that tturns them off or something. Its hard to believe its bulps or something since they are in two different locations.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
z51vett
Thanks for input, Tried that and pushing just turns them on. Also tail lights not on either. Is there a fuse or relay I don,t know about. Jeff
There is a little round glass ball/ sensor on your dash the detects light. It is used to tell your car's computer the current time of day, i.e. Sun light, Dusk or night time. It will (if your lights are turned to Auto) turn interior/ head lights on/ off. I'm not sure if it has it's own fuse? Is it being blocked by anything? Do the light come on when you open your doors? Lastly, is the "Dimmer" switch turned to full brightness?
Landru (02-21-2018)
Received 2,093 Likes
