C6 Parts for Sale/Wanted C6 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Corvette C6 Window Valet
Old 09-14-2010, 09:43 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default Corvette C6 Window Valet
Southern Car Parts is now offering the C5 and C6 Window Valet from Top Down Technologies.
Takes minutes to install, plugs into the OBD port under the steering wheel. No tools required.
$139.99 with free shipping in the US.
Features include.....
C6 Features Include....
1) Remote Control Power Windows Let the windows down as you approach the car. The heat escapes before you get in.No need to get back into the car to let the windows up. Put the top up and walk away. Convertible owners know all too well what this means.Don't leave the windows down just because the car is on a racing trailer. Climb out, raise the windows, secure the car. Tight garages are no longer a problem. It's much easier to get into the car after lowering the windows.
2) The window venting feature allows you to use the remote to leave the windows down about half-an-inch for airflow on hot days. To use this feature, simply issue the remote window up command when both windows are already in the fully up position. The Window Valet for C6 will recognize that the windows are already up and assume that you want to vent the windows. This feature, just like the remote window control, does not require any additional configuration.
3) The "subtle alarm" mode will cause the horn to toot three times whenever someone pulls on an outside door handle while the car is locked. If a valid FOB is detected and the door unlocks because the C6's passive mode is enabled, the horn will not sound. It's a you're busted message to kids trolling for unlocked cars.
3)"Unlock on brake" will unlock the doors whenever the hand brake is set. It will re-lock the doors whenever the brake is released. This feature is only available when the engine is running. It's convenient when dropping off a passenger.
4) The "high speed/tach report" will show the highest speed and the highest RPM recorded by the Window Valet for C6 since it was last cleared. These values are shown directly on the speedometer and tachometer's analog needles. Only mph on a 200mph style gauge is available. To recall the values, press and hold RESET on the Instrument Panel Cluster while tapping unlock six (6) times on the driver's door panel. Speeds up to 100mph will be shown. To show the remainder over 100mph, press the GAUGES button. Press RESET again to exit, or press FUEL to clear the high values and exit.
Order one for your C6 Below...Works on ALL Corvette C6, including the Z06, ZR1, and Grand Sport
Thanks,
Jim
Old 01-18-2011, 10:57 AM
fastter
fastter's Avatar
Just placed my order!
Old 01-20-2011, 06:05 PM
juyanith
juyanith's Avatar
I've been thinking of getting one of these so I can roll the windows down if I'm shutting the rear hatch in my Z06. It just occurred to me that it would be a cool feature if the window valet had an option to automatically open the windows a bit when the hatch was up. I don't know if that's possible, but it would be a nice feature.
Old 01-23-2011, 05:45 PM
southerncarparts
Supporting Vendor
great idea, but not a feature on it......sorry.....
Jim
Old 02-27-2011, 05:34 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
My favorite *extra* feature of the unit. I got so used to it in my 06 vert that when I picked up an 08Z for the track I had to get one just for that cause I kept trying to open the doors when they were locked.
Plus Jim is great to work with.
Old 02-28-2011, 09:33 PM
southerncarparts
Supporting Vendor
Thanks!!!!!
Old 04-02-2011, 10:56 PM
teenVette
teenVette's Avatar
Just placed my order for one
Old 04-03-2011, 12:20 AM
norris_83
norris_83's Avatar
pretty sweet product.. if i wasn't spend every dime on rebuildng my engine and gear, i'd be buying this straight up
Old 04-30-2011, 10:20 PM
wolfpack06
wolfpack06's Avatar
so I can put windows up or down with the car off using my stock fob?
Old 04-30-2011, 10:33 PM
southerncarparts
Supporting Vendor
Yep....without any permanent modifications to the car.....simply plug the Valet into your OBDII port and you are done...
Jim
Old 05-12-2011, 08:55 AM
2snakes
2snakes's Avatar
Stupid question. When you plug this in will it tell your dealer you tried to change your tune ?
Old 05-12-2011, 12:26 PM
BevoZ06
BevoZ06's Avatar
St. Jude Donor '11-'12
Jim,
Does the same device work on the C5 and the C6? Or are they different? I bought one from you for a C5 and I want to move it to my C6.
Thanks.
Old 05-14-2011, 02:44 PM
BevoZ06
BevoZ06's Avatar
TTT. Hoping for answer from Southern Car Parts.
Thanks.
Old 05-15-2011, 03:59 PM
southerncarparts
Supporting Vendor
Originally Posted by BevoZ06
Jim,
Thanks.
No, they do not.....totally different units.....sorry..
Jim
Old 05-15-2011, 06:27 PM
BevoZ06
BevoZ06's Avatar
Jim
OK. Thank you, Jim. I'll be placing an order for one for a C6.
Old 05-30-2011, 06:57 AM
JimsCorvettes
JimsCorvettes's Avatar
Just ordered one as well!
Old 08-08-2011, 09:45 AM
-=ICE=-
-=ICE=-'s Avatar
shipped to Canada ?
To Corvette C6 Window Valet
Old 08-10-2011, 03:06 PM
southerncarparts
Supporting Vendor
Originally Posted by C6 James
shipped to Canada ?
Free domestic shipping. I can use USPS Flat Rate to Canada for about $12.
Thanks,
Dave
Old 08-10-2011, 05:34 PM
thumperZ06
Great State of Utah
thumperZ06's Avatar
St. Jude Donor '12, '14
Default Excellent product
Jim,
just recieved and installed mine..
really slick.
Thanks
ThumperZ06
Old 08-14-2011, 10:30 PM
southerncarparts
Supporting Vendor
Originally Posted by thumperZ06
Jim,
really slick.
Thanks
ThumperZ06
Thanks.....glad you like it!!
Jim
Quick Reply: Corvette C6 Window Valet
