Poly Motor Mounts Melted
I was under my car today and noticed a giant red blob hanging down from the engine compartment. I have the Energy Suspension red poly mounts, and it looks like the heat from my headers destroyed them. Is this a common problem with headers? Is there a different brand that doesn't melt?
I probably got these 6 years ago, but I hadn't been driving it much. I'm planning on making this my daily driver again. I really liked the poly compared to the old rubber ones, but I don't want to have to replace them all the time.
I had the same problem with stainless steel block hugger headers that were about 1/2" from the Energy poly motor mounts. I switched to fully length ceramic coated headers that are much further from the motor mounts, and I have not had any motor mount-heat problems since. My engine is better tuned now (including timing), so I can't attribute the solution to either the headers or timing exclusively...both changes probably helped solve the problem.
I'll check my timing, but I don't think I can change the fuel mixture on my 81, I'm pretty sure that's controlled by the computer. I do have the Dynomax ceramic coated headers and they are about 1-1/2 inches from the mounts. If I change to solid mounts would those eventually cause something to crack? The engine I put in there has about 300 hp.
I do remember the engine overheating because I had air in the coolant a while ago, maybe that caused it, I was driving it a lot at that time.
I have seen quite a few threads regarding molten poly mounts in the past...
even with heat shields fitted!
What's wrong with rubber mounts? If you have a lot of torque twist, you can limit the strain on the left mount by using some old hot rodder tricks...
... use a chain bolted low on the chassis to a left side header mount bolt ...
or fit a bolt through left mount plates to limit the extension distance....
both methods work.
Vibration insulation under normal driving, but limited torque twist under full load.
both methods work.
Timing is set correct, I think the poly melted when I had an overheating problem last year, and I just never noticed it. The solid mounts are cheap enough that I'm willing to give them a try.
Mounts Melting
Desiging one now but will need to check out these other suggestion also! Hope this works too expensive to replace
designing
Received 2,127 Likes
I agree. Moroso Solids, ARP bolts, Loctite Blue and never look back. Very, very, slight vibration in the steering wheel, but I can live with that.
Some of the older fellas & gals may remember the notorious, history making GM motor mount failure of the 70's. Thousands sheared apart, usually under acceleration. The recall fix was a steel cable to harness any separation.
Dr. Detroit
Received 3,892 Likes
My friend had those Energy Suspension mounts and they melted....32' Ford with block huggers....went Moroso and called it a day.
Jebby
I run the solid motor mounts also and I have a spreader bar. It eliminates the broken motor mount problem and tightens up the car. I also have my frame solid welded and gusseted, so the the overall difference from stock is stark.
Mike
Mike
on a C3, remember that the body is isolated from the frame: the body has rubber bushings for mounting to the frame. this means that vibration, noise on the frame is not transmitted into the cabin. So in the case of the C3, use of steel motor mounts does not result in a whole lot of engine noise, vibration being heard or felt in the interior of the cabin.
totally different story on uni-body cars, though, where the frame is integrated into the body.
I also put the Moroso steel motor mounts on my 78 with a BBC, and was surprised that there wasn't much noise/vibration difference. That then inspired me to install solid motor mounts on my 1990 Camaro (unibody). Whoa, big difference, totally, like night and day. But I got used to it, and now revel in the experience. Don't need no stereo in the IROC any more. total engine-sound, surround-sound "immersion".
Received 1,126 Likes
The scientist in me would put the remains in the oven and see at what temperature they became mushy!
Also if you replace the mounts with equivalents, you should make sure they have a travel limit.
