Help! Car alarm/horn wont stop, can't shut off.
I was at the gym today and my alarm in my Z06 was going off continuously. There was no beep beep beep, it was just beeeeeeeeeeeeeeeeeeeeeeeeeeepppppppppppp forever. Strangly, while the car was idling, if I were to disengage the ebrake handle, it would shut it off, as soon as I engaged the ebrake handle, the alarm would sound again. The fob did nothing either way. When the car was not idling, the alarm was relentless and there was nothing I could do. I have the negative terminal on the battery disconnected for now, thats the only thing I could get to shut it off. Thanks for any help or ideas.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
There is a reason ..................
Quit simple .............. Your car is reacting to the Bucks sucky season ........ 4-12 Yikes "The Buccaneers' defense was among the worst in the league in 2011. Tampa Bay allowed the most points in the league (494), the most yards per play (tied at 6.3), most yards per pass attempt (tied at 7.6), the most rushing yards (2,497) and the most rushing touchdowns (26). They also allowed the second most yards per attempt (5.0), the second most rushing first downs (135), the third most total yards (6,311) and fourth most total first downs (356) of all teams in 2011."
Way wrong
Agree that the battery would be where I would start.
I'm going to let it sit overnight. It's since stopped (battery has been connected for the last few hours). I cant comment on the Bucs, I'm a cheesehead!
NCM Lifetime Member
The horn has a fuse (#2) in the box under the hood, however is is shared with "alternator sense", whatever that is.
Or you could pull the horn micro-relay (#34) in the same fuse box.
NCM Lifetime Member
Sensor that detects any abnormal change in output from the alternator. It will trip a relay to prevent any voltage spike from wasting the computer systems in the car.
NCM Lifetime Member
NCM Lifetime Member
To revive a long dead thread, this crap still happens lol. I washed the engine bay out tonight on my ZR1, left it running while spraying. Drove across town, turned it off and back on. Drove it home... fast forward another hour or so and my car starts losing it's mind. Hopefully what ever is wet will be dry in the morning.
