** New Product, C5 Center Console Insulator **
** This Product fits all C5 Models 1997 thru 2004 **
Are you searching for a low cost and easy method to reduce the temperature inside your center console? Reduce your interior console temperature to a more manageable level by using our easy to install C5 Center Console Insulator.
Installation is just a matter of pressing the Console Insulator into place. Laser cut for a perfect fit. 1/4 inch insulation covered in black felt to match the stock interior console. Experience a noticeable reduction in interior console temperature with an easy to install and inexpensive alternative.
Order on our website at http://www.topflightrepro.com/corvet...products.shtml
moserbe (01-10-2019)
Does this go on the inside of the console (storage area) or on the bottom of the console where it mounts?
If it goes in the storage area, do you pull the stock liner out?
not sure how well it works on the vette, but on my Nova this area was a little heater oven. its funny driving the two cars 40 years apart, cus there's distinct similarities.. wouldnt be surprised if this noticeably helps.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
no installed pics??? Aren't there a bunch of wires and connectors in the way? Inquiring minds want to know!............ Also, might help your sales....
I hear ya but this install takes seconds, remove the spare change and what ever else is in the console, than take the insulator and press it into place, and you're done so simple
