Lenses and Muriatic Acid?
Was watching one of the restore basket cases muscle car shows and one of the "guys" referred to restoring ("cleaning") the existing plastic lenses, in this car the tail lights, with Muriatic Acid.
Since it was a scene with faked employee conflict they really didn't explain or address the use and results of using the acid. Ive never heard of this.
Any low-down on restoring the lenses with Muriatic Acid? Comments, suggestions...
Gooday Mate,
Me -(16 years in the paint/chemical industry and curious)
did some googling on Muriatic Acid (us Aussie's call it Hydrochloric Acid).
Can't tell ya HOW,
BUT what I can tell you is
....This is NASTY stuff...BE CAREFUL.
It's used to clean brickwork.
I'm curious too and I'm sure someone will have more info on how to use this.
Cheers.
Can't tell ya HOW,
Cheers.
Hmm, no chemist here, and never knew muriatic and hydrochloric acid were the same stuff, as pretty common to get at hardware stores and marine/swimming pool places. Works pretty good for cleaning off boat bottoms in a 50% water mix, and doesn't seem to caustic this way, or harming the plastics, as it comes in a plastic bottle. Not sure what you're doing, but maybe worth checking into the Sylvania headlight restore system for late model cars. Their site has a video showing it using several fine grit sandpapers, polishes, followed by a brush on clear coat. They say it's good for restoring tail light lenses, side marker lights, ext.
Received 1,469 Likes
Cruise-In II Veteran
Why gamble? I would not use any type of acid on plastic. Any good quality plastic polish and elbow grease will clean up your lenses.
One lesson learned since 2009.... Don't use too strong of an Acid at the Bikini Car Wash....
It take the Pink right of them Areolas and Pert Nips...
Use 7% solution or less, and them Head Light Caps should be no worse for the wear
Last edited by 03 A/E Coupe; 07-16-2018 at 06:42 AM. Reason: Positive Side Effect, Kills Pubic Crabs
80-Vette (07-26-2018)
Received 3,043 Likes
St. Jude Donor '05
Dont use it on plastic
Get some regular old no 7 rubbing compound and a rag, your plastic lenses will come out like new
no need for those fancy "kits".
Received 3,138 Likes
Original lens from a used vette place
Flitz polishing compound on a dremel type tool with 1/2 soft cotton buffs (bobs) running at a low speed
This plastic is old, I wouldn't use any kind of aggressive chemicals (acids or other cleaners) or every stressed area or already stress cracked spot will suddenly start to show.
M
M
M
M
Moderator
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
M
M
It does look nice, real nice. But i have to say i`d rather boobies be used to polish my taillight lenses
