***NSANEC6 1000HP YSI Corvette build***
Supporting Vendor
Here are some photos of this NSANEC6 corvette as we have been doing some extensive modifications to it throughout the recent weeks.
When it came to us it already had quite a few modifications including a Vortech supercharger.
We started by tearing the old engine out and installing a Fully Forged LSX block 427ci Engine.
Then we moved into the fuel system installing a Custom LMR 1000hp Return style fuel system. This system utilizes an in tank Aeromotive A1000 fuel pump with a Aeromotive pump speed controller.
Then we finished installing the rest of his accessories including the old supercharger system
Here is a start up of it after we got the supercharger system and everything installed
Then we decided that old blower wasnt going to be enough So we upgraded to the YSI.
And here is the Initial dyno results on a VERY mild tune up.
Very nice. What rocker arm setup is that? Looks good.
Pulley sizes?
Pulley sizes?
I know the guy has been through a lot so nice to see it's getting done right. Awesome results through the auto on initial tune.
Thanks buddy. I am actually letting a shop that knows what they are doing take care of me this time....All of the team at LMR and LME have been professional, courteous and given me lots of advice so far.
Chris and Doug also shared some advice with me and when I chose to step up to the YSI Chris helped me out and overnighted the unit to LMR for me. ECS has been great through this ordeal.
Jay, Steven, Josh, Bryan and the guys at LMR/LME agreed to take the mess I was left with in and try to correct all the problems in the original build. After tearing the car apart and discovering so many issues with the motor build Bryan and I decided to proceed with a 427 LSX motor and along the way we have made some additional upgrades.
I want to use this thread to highlight the great job that Bryan at LME has done so far on my motor build and the time and effort and quality work that Jay, Josh, Steven and Paul have put into my car at LMR.
So everyone stay tuned for the finished product. It has been 2 years in the making and I cannot wait to get her back.
What is standard on an ECS kit? 3.3? 3.25? I can see the OD crank. Just wondering because I'm always interested in what Ysi's make at different pulley combos.
Unfortunately it's the 6L80. Beefed up by Mike Kurtz at Century Automotive and Transmission in Houston. I also have a custom transmission brace that Chris (aka) The Subfloor designed installed.
3400 Yank Stall and B&M fan powered tranny cooler.
Mike is doing the fine tuning on the transmission at his shop. We all know how finicky these 6L80's can be.
Great numbers thru the auto! That with the converter locked? (It sounded like it was locked...)
I hope I'm making 850 through the auto but.... I can't lock the converter so ill likely never Dyno it again..
Glad to see you getting the car back and done right. Bryan gave me excellent service and a great shortblock and so far its been excellent. Keep us posted on how she runs. I am especially interested in how the trans holds up to that power.
Here is a short list of some of the items in the motor build:
Callies Dragon Slayer 4340 forged 4.00" stroke
crankshaft w/Indexed & Trued Journals
Callies Ultra H 6.1... Callies Ultra Billet 6.125" H beam rods w/ARP ULTRA 7/16" bolts (good to 1400 RWHP turbo applications)
Pistons LME/Wiseco Custom Pistons w/Lateral Gas port, double
pin oilers, anti friction coating on skirts(includes
Stainless chrome ring pac for high heat applications)
Pins Upgraded Tool Steel Wrist Pins .210" Wall Thickness Bearings2 Clevite MS 2199 H mains, Clevite CB 663 H rods, Dura
Bond CH-23 cam bearings
JP double 4X JP Performance LSX double roller 4X timing set w/
torrington bearing and nitrited gears
Crane Tie Bar Hyd. Crane Cams High RPM Tie Bar Hydraulic Roller Lifters
YT L92 1.7 Yella Terra Ultra Lite aluminum roller rockers LS3 1.7
1.7 ratio
Cometic 6 bolt Cometic MLS Head Gaskets
Melling LS Melling 10295 high pressure, coated oil pump/ ported
Manley L92 exh. Manley L92 stainless 1.600" exhaust valves
1.7 ratio
Steven is doing the tuning. Its nice to have someone who really knows what they are doing taking care of the tuning on the engine and tranny.
Good luck on your build as well...
I also have some Kooks headers, 3 inch tubing with catless X pipe and an Akrapovic Exhaust. Josh handled the custom welding to get this exhaust installed on the auto.
I cannot wait to hear her run in person.
I have been reading all of your posts.... With everything that I have gone through with the car so far I am NOT trying to find the weakest link... lol
Unfortunately due to the amount of money I have spent on this car... Considering I have ad to have the motor done twice.... I have had to stay with the stock heads and intake for the time being... I knew someone would eventually ask.
