Remainder of 2001 Z06 part-out; lots of misc and interior
I had to take a break from parting out a 2001 Z06 due to time constraints. I’m ready to finish parting it out. I have the below items for sale. All interior/exterior items are black. All prices are negotiable. I didn’t know what some items were worth, so I just tossed a number out there. Feel free to haggle. I have pictures of everything, but in order to reduce clutter in the thread, I’m going to supply them on request. Also, this is every item I have left. Please don’t contact me asking if I have a different part you may be looking for. I have nearly a complete interior minus the dash, center console, door panels, headliner, sun visors, and seats. I have all other pieces.
***Most importantly, I do not frequent the forum like I used to, so email me at spoolin7@gmail.com for the quickest response***
A/C Condenser - $75
A/C dryer - $40
Accelerometer (GM 25697709) - $40
BCM body control module (GM 10304931) - $150
Bose amplifier (GM 10283023) - $100
Brake booster - $100
Brake pedal assembly - $75
Center console/hvac/radio frame (behind dash) - $65
Center defrost vent/grill (GM 10400366) - $20
Door wiring harnesses (both sides) - $70
Driver a-pillar (GM 10247723, has one small nick and would be perfect for pillar gauge pod) - $40
Passenger a-pillar (GM 10247724) - $60
Headlights (just housing, no additional components; both sides) - $60
Driver pillar/speaker trim (GM 10258568) - $40
Passenger pillar/speaker trim (GM 10258563) - $40
Complete carpet - $300
Driver window regulator and track (GM 10446574) - $100
Floor kickup panel (GM 10290668; covers BCM and fuse center) - $40
Glovebox frame (metal behind dash) - $75
Glovebox (minus lock) - $100
Hood latch and cable - $35
Hood weatherstripping/gasket - $25
HVAC unit (behind dash, minus motor) - $250
Ignition switch (comes with key) - $30
Kenne Belle Boost a Pump (20amp) - $75
Knee bolster panel (GM 10426429) - $80
Left seatbelt cover (GM 10426017) - $25
Right seatbelt cover (GM 10426018) - $25
Turn signal stalk/multi-function switch - $125
Passenger airbag switch (GM 10440761) - $15
Passenger side quarterpanel liner - $50
Passenger side front splash guard - $30
Passenger window weatherstripping/molding - $30
Passenger window switch (GM 12135165) - $35
Rear bumper foam – $80
Rearview mirror (has LEDs) - $60
Shift boot (plastic ring has a crack, can easily be fixed) - $25
Shift linkage - $75
Steering column shroud (top and bottom) - $40
Stock airbridge/intake tube - $30
TAC throttle actuator control module (25311783) - $225
Taillight wiring harness - $40
Third brakelight - $40
Trunk weatherstripping/molding - $35
Steering column knee trim (GM 10297244) - $15
Wiper motor/arm assembly - $70
YAW sensor (GM 10277333) - $80
Rear suspension cradle - $100
Rear suspension arms - $80
Rear hub/knuckle assemblies - $60
Front hub/knuckle assemblies - $60
Alternator bracket (strong version) - $50
Trunklid - $100
A/C Condenser - $75
A/C dryer - $40
Shift linkage - $75
Trunklid - $100
also worth noting, I have the stripped frame from the car with the rear tub intact. this has a clean title and would be perfect for a project. has front left frame rail damage which can be easily fixed. email me for specifics.
St. Jude Donor '10
For the Passenger Airbag Switch, do you have the wiring harness as well? I want to retrofit this into my 99 FRC. If you have everything relating to this I would be interested in it.
