Difference between LT1 and std 350?
I apologize if this is a dumb question, but Im new to the C3 side of the house. I was just hoping someone could give me a run down as to the mechanical differences between the LT1 and the L46.
Thanks
Thanks
Basically, an engine is a air pump, to get more power, you need to move more air. The big block cars move more air because they have larger cylinders. So at the same RPM as the base engine, the big block will move more air. The LT1 moves more air by being able to run higher RPMs. The engine is designed to allow the motor to run higher RPM.
- Larger Valves
- Push Rod Guide Plates
- Screw in Rocker Posts
- Forged TRW Pistons (11:1 domed)
- Shot Peened / Magafluxed (pink) Connecting Rods
- Forged Steel Crank
- Electronic Ignition (Transistor)
I apologize, should have been more specific....LT-1 vs. L46. I know both had 11:1 comp, just curious as to what the other differences are
Received 2,878 Likes
Hi FN30,
When you read the lists that people have posted.... carb, intake, cam, lifters, a person might begin to wonder if the 70 LT-! might have been a little-under rated at 370HP compared to the L46's 350hp.
Really QUITE different engines. And, oh the noises a 70 LT-! makes!
Regards,
Alan
Regards,
Alan
Hi FN30,
Regards,
Alan
Regards,
Alan
First, the standard 350, is not the L46, so not sure exactly what you are asking. The HP ratings for standard engine was 300 HP, the L46 was 350 and LT1 was 370 HP. Cam specs, Heads, intake, Valve sizes, carb ( Holley or Rochester), Main journal bolts, LT1 had solid lifters, allowing higher RPMs before valve float.
All had similar peak torque, but the torque curve would be longer and higher up in the RPM band for the higher HP engines. The base engine would pin you to the seat just like the LT1, but the LT1 would pin you to the seat thruout a longer rpm range.
The L-46 (350/350) did not have screw in rocker studs or push rod guide plates.
The L-46 also had a forged steel crank, however I don't believe it had the tufftride heat treatment on the journals.
There was not a great deal of difference in performance between the L-46 and the LT-1 up to 6K rpm, however the LT-1 could go beyond that, as mentioned, then it would out perform the L-46 by a fair margin.
omg! although there were subtle differences in the heads , the intake on the LT-1 was better and it had a solid lifter cam. they were very close to the same engine. the 350/350 was really a better street engine. some knowledgeable chevy guys said there was more power difference in the intake than the cam, on the street. both were excellent performers. whoever cam up with changing horsepower ratings didn't help anyone.
Sorry but that's wrong. My L-46 1969 has pink connecting rods, 11.1 domed pistons. Forged steel crank.
Yes, you are correct, the L46 (non std 350) does have the items you listed.
L46 was an option … base motor was 300 hp L48
https://www.gmheritagecenter.com/gm-...tion-kits.html
download year-specific original gm spec docs... many many details
free of charge!
free of charge!
I've looked at the acceleration times recorded back in the day and the L46 was actually faster than the LT-1 up to 70 - 80 mph. In the 1/4 mile the LT-1 was about 1.5 tenths of a seconds faster.
