Lexan drilling
Lexan drilling
Just a quick Q. to the ones that went through this before...
I'm reassembling the hard top for my 65 and replaced rubber and hardware along with the back window, now that the window is in I realise it doesn't come predrilled for the upper and lower reindorcements so I was wondering if you guys have any tips, I don't want the lexan to start spidercrack on me as I drill, so..... is there a specific bits for the job or it just like any other hole?
Thanks in advance!
Thanks in advance!
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Or take a stone and break the corner on the flute to the tips at the OD of the drill, basically dull it. Helps a bunch. Drill it dry, and make sure the hardware is free of oils. We use lexan for guards at work and if we don't take the oil off the screws or anyone screws up and drills/taps with oil, the lexan will crack a few days after assembly.
Thanks guys, I wasn't aware of a specific bit for lexan, a quick look on Ebay and I see they run about $70? WTF? Does it have a gold tip?
Ant way, I guess it's still cheaper than a new window I suppose....
I'll try the dull bit and also the step bit first, I have a handfull of those.
Thanks again!
Thanks again!
St. Jude Donor '05, '09, '15
Thanks again!
Thanks again!
http://www.eplastics.com/Plexiglass_...tic_Drill_Bits
Tom
Thanks Tom, I guess I overlooked the size and just looked at the $ first!
http://www.ebay.com/itm/drill-bit-for-lucite-plexiglass-acrylic-lexan-15-16-/360200642562?pt=LH_DefaultDomain_0&hash=item53dda1a002
2016 C1 of Year Finalist
Check Glassworks, $7.00 (seven dollars) plus shipping.
Auto Entec , $5.00 (five dollars) plus shipping.
I'm no machinist but the sharpness has nothing to do with cracking or breaking of the plexiglass window.
The reason they break has to do with the angle at the point of the drill. So invest a few bucks and save a rear window.
Drill Bit for Lucite Plexiglass Acrylic Lexan 15 16" | eBay
Tom
i am doing this now and need the size of the drill bit i need for the rear window...i may have missed the size but i did read thru the excellent article...and yes i know it is an old tread.lol.john b
Ohiovet is correct. I just did my 59 complete restoration myself and bought everything from Glassworks including the Lexan drill bit. I was impressed on how great the drill worked, it looked like a factory cut. Do yourself a favor and order the Glasswork Lexan drill bit. Just $7. If you are in a hurry have them shipp next day delivery. I was very hesitant to drill the new rear window but now I can assure you that I would do it again with their drill bit without hesitation.
Minor point
Are you guys sure your hard top windows are made of Lexan? All of them that I've seen were made of Plexiglass. I'm not questioning the need for a special bit, just the actual material you're drilling. There is a big difference in durability and cost between Lexan and Plexiglass.
I drilled a lot of Lexan when I was boat racing.
Make sure you do not put pressure on the drill bit. Let it drill very slowly.
Use a drill press at low speed, minimal pressure on the bit
Make sure the Lexan is backed up in something firm - like sanded 3/4 plywood or particle board. Under the drill area.
When done Polish the hole with 400 sand paper.
Do not overtighten the screws going through the Lexan.
I drilled holes from 1/16 to 1 1/2'.
I used regular drill bits, If you have a clutch on the drill set it to the lowest setting.
The key - a firm backing to the Lexan - do not wobble the drill bit and do not press on the bit.
The material is Acrylic not Lexan. The glassworks Acrylic drill bits are :
56-62 Acrylic Drill bit SKU 2301-A 1/8 in diameter
63-67 Acrylic Drill Bit SKU 2301-B Do not know the size.
The drill bit has a very sharp edge triangle shape point. It is very easy to use as the shape and the sharp cutting edge cut like butter. The resulting hole is perfect as I said I was impressed.
Received 1,533 Likes
I thought that Lexan is a trade name for polycarbonate plastic. A Google search kinda states it that way.
So, I guess the rear windows on all hardtops are Acrylic???
