C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
C7 Corvette Stingray Skip Shift Eliminator - CAGS units from SCP....
Old 02-21-2014, 01:35 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default C7 Corvette Stingray Skip Shift Eliminator - CAGS units from SCP....
Also called CAGS Defeat
Do you hate the 1-4 skip shift installed on the C7 Manual Transmission? This little device will eliminate that annoying issue.
Our corvette skip shift kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your C6 Corvette's 7-speed gearbox. This kit comes with the correct connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function, if you so desire. This kit is designed for use a C7 Corvette only. Will not fit C5 or C6 Corvette. No permanent modifications are required to install this product.
In stock here: http://www.southerncarparts.com/corv...or-p-5789.html
Old 02-25-2014, 06:32 PM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
Thanks for the video... mine are on their way from you and I'm excited to get them installed!
Old 03-09-2014, 06:05 PM
southerncarparts
Supporting Vendor
Thank you sir!
Old 03-14-2014, 05:12 PM
southerncarparts
Supporting Vendor
Dave Hrejsa (06-26-2017)
Old 06-18-2014, 07:48 PM
flaagan
CF "Young" Senior Member
Support Corvetteforum!
flaagan's Avatar
St. Jude Donor '12
I've been considering ordering one, but one thing that sticks in my mind is "What is exactly that this mod does to the car to get rid of the 'problem' of skip shift?"
Old 06-18-2014, 08:53 PM
Q8 c7
Q8 c7's Avatar
Old 06-25-2014, 07:03 PM
southerncarparts
Supporting Vendor
Just overrides the computer that locks out 2/3. 100% safe, I have on my 2014.
Old 03-08-2015, 03:09 AM
Jedi-Jurist
Jedi-Jurist's Avatar
St. Jude Donor '15
The video skips the most difficult part, which is the removal of the original wiring harness.
Old 08-02-2015, 12:11 AM
srabin
srabin's Avatar
Does this work for Z06 too? Just want to make sure before I order it.
Steve
Originally Posted by southerncarparts
Old 08-21-2015, 08:37 AM
southerncarparts
Supporting Vendor
Steve
Yes, it does..
Old 10-27-2015, 10:41 AM
bjones7131
bjones7131's Avatar
I have one on my C5, and I assume it works the same way. Love it but U will still get the light on the instrument panel but just ignore it U can shift without being locked out. Forgive me for jumping in on the C7 forum, I am close to pulling the trigger on a 2016 and am reading up on U guys forum issues.
Old 02-28-2017, 12:18 PM
thirtythird
thirtythird's Avatar
Worth it. I was running into skip shift all the time due to how I drive and it drove me nuts. Now all is good again. Great product.
Old 08-03-2017, 08:44 PM
B's Z06
B's Z06's Avatar
I have an extra C6 skip shift eliminator, will that work on the 7speed manual C7 Z06?
Old 08-04-2017, 09:50 AM
southerncarparts
Supporting Vendor
It's possible, depending on the style. And if not, some can be modified to work. Give me a call at 888-631-1433 and I can explain further.
Old 10-07-2017, 01:28 PM
TEXHAWK0
TEXHAWK0's Avatar
Is the resistance different or is it just the connector?
I have one of the new style like this and it only measures 25ohms instead of 2.2K ohms as some have reported.
I noticed some of the connectors have and extra partition that might keep them from going together.
Old 10-08-2017, 10:17 AM
southerncarparts
Supporting Vendor
I'll bet that one will work if you file away the partition on the female end.
Old 05-11-2019, 12:44 PM
southerncarparts
Supporting Vendor
Thank you for the orders!
To C7 Corvette Stingray Skip Shift Eliminator - CAGS units from SCP....
Old 06-16-2019, 09:17 AM
Boxcar
Life Starts at 120 mph
Boxcar's Avatar
NCM Lifetime Member
Had one on my C6, and need one on my C7, just ordered, please send the correct one. LOL
Old 07-23-2019, 07:58 AM
southerncarparts
Supporting Vendor
Old 10-15-2019, 08:17 AM
southerncarparts
Supporting Vendor
Quick Reply: C7 Corvette Stingray Skip Shift Eliminator - CAGS units from SCP....
