Help! 1964 heater core change with AC
Old Jul 6, 2014 | 08:53 PM
ejpii's Avatar
ejpii
Default Help! 1964 heater core change with AC
Good evening everybody. I am pulling out what little hair I have left.
I am changing the heater core in my wife's 1964 coupe with air. I have searched the forum and probably read 90% if not all the threads on heater core changing. I have removed the two nuts on the inside of the car and the three nuts on the firewall in the engine compartment. It feels like there is one more nut somewhere. The lower part of the box moves freely but the top has something holding it.
Am I missing something?
I am trying to be patient with these 50 year old parts so I don't make an expensive mistake. The car is a November of 63 build if it makes a difference.
Thanks,
EJ
Old Jul 6, 2014 | 09:07 PM
Mike Geary's Avatar
Mike Geary
did you get the one on far left/top?
Old Jul 6, 2014 | 09:10 PM
65GGvert's Avatar
65GGvert
Just above the accelerator pedal.
Old Jul 6, 2014 | 09:12 PM
ejpii's Avatar
ejpii
Hi,
Yes I removed the one by the gas pedal and the one all the way to the right by the kick panel.
Old Jul 7, 2014 | 10:52 AM
ejpii's Avatar
ejpii
Does anyone have a picture of the heater core box from a A/C car, The portion that faces (mounting side) the firewall?
Old Jul 7, 2014 | 11:17 AM
62Jeff's Avatar
62Jeff
From my 65
I'll see if I have better photos
Old Jul 7, 2014 | 12:11 PM
ejpii's Avatar
ejpii
Thanks for the pictures Jeff. What I'm trying to see is if there is a hidden bolt/nut somewhere.
I took the 3-Nuts off from the firewall on the engine side around the heater core plate, and the 2- nuts off in the interior side the one to the left and the one to the right.
Is there a hidden nut or bolt under the evaporator core case/blower motor assembly? All the pictures and diagrams I'm seeing show 5-mounting points.
EJ
Old Jul 7, 2014 | 03:32 PM
Mike Geary's Avatar
Mike Geary
EJ
Might be a bead of sealant across the top. You've removed all the nuts that I know of. Can you take a feeler gauge and use it like a thin putty knife to go around the perimeter?
Old Jul 7, 2014 | 03:56 PM
ejpii's Avatar
ejpii
Mike, I will try that this evening after work.
Thanks,
EJ
Old Jul 7, 2014 | 08:26 PM
JohnZ's Avatar
JohnZ
Here are a couple of photos of an A/C heater case showing the firewall attachments - there are no hidden screws.
Old Jul 7, 2014 | 08:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
while its out it might be a good time to replace all the foam seals in the heater box for all the flaps.
Old Jul 7, 2014 | 09:23 PM
ejpii's Avatar
ejpii
Default Update!!!!!!
Update!!! The heater core assembly has been removed from the firewall. It appears that 50 year old glue is strong stuff. I had to give the box a little more persuasion than I would have like but I was able to get the job done.
Thanks to all for your input and pictures it helps when you think you've checked everything but still feel you missed something.
Now I will properly reseal the box and replace the heater core or fix the old one if it/s repairable.
Thanks again you guys are the best.
EJ
Old Jul 7, 2014 | 09:35 PM
JohnZ's Avatar
JohnZ
EJ
There's only ONE place to get the seal kit - Dr. Rebuild - his seals are the BEST - right size, right material.
Old Jul 7, 2014 | 09:39 PM
ejpii's Avatar
ejpii
Your correct on that JohnZ. I picked them up from the Dr. on Thursday. Lucky for me his warehouse is the next town over from me.
EJ
Old Yesterday | 01:55 AM
c2vettehead's Avatar
c2vettehead
I'm having the same problem.
top stud above the core seems to not want to move.
they actually glued these things on?
To Help! 1964 heater core change with AC
