C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2008 Z06 - Starter went.. aftermarket options?
Old 07-26-2014, 01:57 PM
silvrhand
silvrhand's Avatar
Default 2008 Z06 - Starter went.. aftermarket options?
looks like the starter went, have to pull it and get a new one. Are people just using the OEM starter, or are there better options such as the MSD starter?
I've also heard some people having heat failure due to aftermarket headers, I'm running the ARH 1 7/8" headers, jet coated.
Any information/thoughts/flames are welcome.
Old 07-27-2014, 01:39 AM
erikszr1
erikszr1's Avatar
stock is fine, I would not buy any rebuilt unit from an auto parts store....EVER. I would buy a used one before I did that. LOL, get a A/C delco unit online from one of our GM parts suppliers here.
Old 07-27-2014, 10:34 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I've heard nothing but good about the rebuilt napa ones. They come out of Michigan. $80.
Old 07-27-2014, 01:01 PM
erikszr1
erikszr1's Avatar
sounds like a good option
Old 07-27-2014, 01:20 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
C6 of Year Finalist (performance mods) 2019
Before buying a full replacement starter, check the solenoid for a broken post. The combination of heat, vibration, and stress (tension) has been well known to crack the bakelite housing, which results in a loss of electrical continuity.
A new solenoid is about $40 installed on your starter motor when you take it to a local rebuilder.
Old 07-27-2014, 08:25 PM
silvrhand
silvrhand's Avatar
As much as a pain as it is to remove as I have to drop the headers, get it up on the ramps I'd rather just pay the $200 for a new one and not worry about it for a while.
Old 07-27-2014, 11:17 PM
HOXXOH
HOXXOH's Avatar
That's what I thought when I replaced the first one. I'm now on solenoid #3 and both starter motors check out fine. I've already put a solenoid (#4) on the spare motor, so I'm ready for the next failure.
BTW, I didn't need to drop the headers (LG) on mine.
Old 07-28-2014, 09:59 AM
Unreal
Unreal's Avatar
Stater will come out on LGs, put no way on my 2" ARH. Don't have to remove it, just loosen the bolts so it can wiggle a bit.
Old 07-28-2014, 10:54 PM
silvrhand
silvrhand's Avatar
So,
I had to break the headers loose to get the stock starter, down, the solenoid was cooked and broke off in my hand and then all over my face while under the car! As always the taste of burnt plastic and clutch dust is an great feeling.
I am replacing it with a powermaster 9509, which is smaller lighter (10lbs guys!) and the solenoid is protected in metal, with a small heat wrap I should no longer have issues.
I will take some pictures and post the size, weight, and installation with ARH headers for everyone.
Old 07-29-2014, 12:02 AM
427ZM
Support Corvetteforum!
427ZM's Avatar
Pace performance has brand new ones for any LS application for $108. Can't beat it.
Old 07-29-2014, 02:58 PM
ConfusedGarage
ConfusedGarage's Avatar
With headers and no heat wrap they seem to be on borrowed time until the situation as you described rears its head. On my new starter with a heat wrap and many track days later, its still starting like new. I highly recommend some sort of heat protection while folks are doing this, its cheap and easy. I used a DEI wrap, and then DEI heat tape to seal it up and protect wires and such.
Old 10-09-2017, 11:39 AM
dcooper23
dcooper23's Avatar
So,
Can you update on this? I am searching for the right starter and was wanting to know how this one has held up for you.
Old 12-16-2018, 11:20 AM
shythone
7th Gear
shythone's Avatar
What model Vette? Mine is an 07 and hopefully wont have to drop headers.
Old 12-16-2018, 11:47 AM
silvrhand
silvrhand's Avatar
just saw this, I ended up changing it again as it didn't last either,
https://www.speedwaymotors.com/MSD-5...rter,9612.html
I used this one as it clocks away from the headers and I haven't had any issues since.
Old 12-16-2018, 05:58 PM
froggy47
froggy47's Avatar
See my starter videos on froggy's Garage if you need info.
2k Cobra (02-16-2019)
Old 12-16-2018, 11:05 PM
Red06Vette
Red06Vette's Avatar
Default aftermarket Starter
Check out this company, got a gear drive starter for my LS7 with 3.75:1 gear reduction. They don't list one for LS engines but he has them.
http://www.ecae.com/index.html
Old 12-17-2018, 08:51 AM
double06
double06's Avatar
The MSD may or may not fit some headers. I think it is like 1/2 to 1 inch longer than the stock starter. I just replaced mine with a AC Delco 323-1640 one and the stock Z06 starter is only like 8 pounds. I had some issues with the post getting to hot also when I pulled starter out I could move the post around like a stick shift. My ARH headers seem to be further away from the starter than my old headers so I am hoping the damage was done from prior headers. I also got the higher end AC delco starter and what I noticed is it sounded like a mini starter. It also turn motor over faster part of which could have been the weak lug in solenoid.
Old 12-18-2018, 02:14 AM
froggy47
froggy47's Avatar
I'd love to see pictures of these "better" starters installed, I barely got a stock replacement in & it was work.
Old 02-16-2019, 02:22 PM
froggy47
froggy47's Avatar
Pics aftermarket starter? Installed.
To 2008 Z06 - Starter went.. aftermarket options?
Quick Reply: [Z06] 2008 Z06 - Starter went.. aftermarket options?
