Building up a c2-c3 chassis
Old 09-02-2014, 11:38 AM
0RideTech Rodney
Former Vendor
RideTech Rodney's Avatar
Default Building up a c2-c3 chassis
working on a c2-c3 chassis to show off some new parts
new rear corvette upper crossmember
Old 09-02-2014, 02:08 PM
Tin_Can_Terminator
Tin_Can_Terminator's Avatar
Nice !
Old 09-02-2014, 04:13 PM
68-427Rich
68-427Rich's Avatar
Nice? Sexy!!!
Old 09-02-2014, 04:52 PM
mrvette
mrvette's Avatar
It does look GOOD, but as with all these chassis/suspension mods, when getting really advanced and beyond the capability of about 95% of the owners out in the field, I have to ask WHY?? for all out competition, fine, but these are ~40 y/o cars.....still the coolest ride on the planet far as I concerned.....
MY position is to make the mods a guy has a chance to do in his own garage, even weld up some stuff on his own or with a welder buddy helping out.....and to keep price/cost/effort down to a minimum....
For ***** OUT racing, yes, but for the typical owner interested in keep his car in GOOD shape and some simple changes.....I fail to see the point.....
the largest change to make starts with wheels/tires....like my easy enough '89 vette wheels/tires on the '72....sure I went with 255/50 up front, and Nitto 275/50 in rear so yes it's not the track hero, but it gained a hell of a lot in handling right there, and reinforced the change with a few other simple mods....
but gotta admit, wish you all were around some years ago...make that almost two decades....
Old 09-03-2014, 09:57 AM
0RideTech Rodney
Former Vendor
all our stuff is bolt on, absolutely no chassis modifications, I even use the factory steering system instead of a rack and pinion conversion (I personally haven't had good results from rack conversions) and you can build it complete or do the front system and later on do the rear system
Old 09-03-2014, 10:07 AM
0RideTech Rodney
Former Vendor
Default heres the front arms and spindle
here's the front arms and spindle......we built in increased castor for better straight line tracking, the taller spindle gives a better camber curve, and finally a billet steering arm with all new geometry to improve akerman, steering response and eliminate bump-steer
Old 09-03-2014, 11:05 AM
keithinspace
keithinspace's Avatar
Curious: Is that a wrinkle finish paint on the frame?
I am rehabilitating a frame and am not sure what I'll do with all the pock-marks from the surface rust. A textured finish could be a step in the right direction. Just curious what you used to achieve that look.
All the parts look incredible, too.
Old 09-03-2014, 12:51 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Looks nice. Given so many mainstream companies in the restomod industry ignore us, its always good to see new, improved suspension bits becoming available for our generations. Please to satisfy my curiosity...
Qs about spindles & steering arms:
Resulting steering ratio (relative to stock manual and power)?
Available a la carte?
How much taller? 3/4"?
Do the arms bolt up to stock spindle?
Bumpsteer geometry compatible with stock manual relay rod?
Ackerman vs stock?
Approx. how much clearance for additional wheel backspacing?
Qs about CAs:
Bushing material?
How much additional caster? (Some of us with manual steering have reasons for running no more than 2-3*.)
Q about diff x-member:
Diff raised vs stock height, correct? How much?
I've got a million more, but figure that's enough for now. TIA
Old 09-03-2014, 01:19 PM
0RideTech Rodney
Former Vendor
this was a Craigslist frame and it had some issues also, and the wrinkle finish paint has a great look to it, a local guy around here blasted and powder coated
Old 09-04-2014, 10:27 AM
0RideTech Rodney
Former Vendor
Ackerman vs stock?
Qs about CAs:
Bushing material?
lots of question!! awesome I snapped some pictures for you on the spindle and you can see what we did....
were the stock spindle looks taller, it isn't really because of the ball joint mounting design....we couldn't get the needed camber curve with the stock spindle, and brake packages were limited...so with a conventional RideTech style tall spindle it moved the pivot point lower, the upper ball joint stayed the same, I will see if Britt can give more detail
Old 09-04-2014, 11:47 AM
jakvette
jakvette's Avatar
Hi ,
That is some seriously nice engineering on that frame , would love to see the completed chassis . What are the design intentions for the rear trailing arm set up ?
Nice work on it so far , what sort of costs are involved for the front control arm conversion with the coil over shocks ??
I like
john
Old 09-04-2014, 12:27 PM
Vince'82
Vince'82's Avatar
nice setup.
do you plan to build a 80-82 rear suspensions kit later ?
can we re-use brakes designed for stock spindles ?
Old 09-04-2014, 12:54 PM
marolf101x
marolf101x's Avatar
You all have some good questions! I'll address these in a number of posts so it's easier to read and understand.
MrVette asks, "Why?"
Well, though the Vette is decent in stock form there are a lot of improvements that can be made. Just as a stock first gen Camaro was ok, we have the ability to make it MUCH better just by bolting on product that cures the ailments of the stock design, and corrects the geometry for modern wheel/tire packages. These cars cannot hold a candle to a modern Vette (C5/C6/C7) in stock form.
It is our goal to create an affordable kit that is as bolt on as possible and make the old girls handle and ride as well as, if not better than, the new models from the General.
These are not full on race kits. . .though you can be VERY competitive in the new forms of "street car racing" (Goodguys autocross, Ultimate Street Car events, etc).
Old 09-04-2014, 01:54 PM
marolf101x
marolf101x's Avatar
Sorry, I should have mentioned earlier that I am the Engineering Director for Ridetech. I just noticed I don't have much information to the left of this message.
Now, on with the show.
TheSkunkWorks:
-We upgraded both our C2 (1964) and C3 (1972) to a Borgeson 12.7:1 box. The box in the 64 was completely junk, while the C3 was better. However, I suggest a good "fast" box to compliment the suspension.
-you can buy the front or the rear as a kit so you can build in stages if you'd like.
-see Rodneys image
-no. We use our "tall drop" spindle. This is the same spindle we use in our first gen Camaro kits, 64-72 A-Body kits, and our 64-66 Mustang TruTurn kits.
-bumpsteer with our TruTurn system is under 60 thousands throughout full suspension travel range
-OE bumpsteer was 1.375" on our 64 in stock config
-TruTurn kit fits both manual and power versions
Ackerman vs stock?
-I'll be honest I don't know the stock ackerman. . .I tossed those parts as soon as I knew we were using our spindles.
-I don't want to put on the web what ours measures as the steering linkage locations are the key to our kit. I can tell you the new ackerman and linkage locations provide amazing turn in without being "darty" on the street, and does not limit turning radius compared to stock.
-till the tire hits the frame or the sway bar at full lock.
Control Arms:
Bushing material?
-Injection molded Delrin with 13% PTFE. Means near solid performance without as much NVH; no lubrication required (Teflon impregnation so they are "self lubricating).
-We typically run as much as we can get (6* or more). However, the upper control arm shaft has caster slugs, so you can move them all over the place. Mind you the lower ball joint is in a fixed location, so moving it too far may make the wheel look funny in the opening.
-When we use our "center" slug we get 2.8*; ".125" slug we get 5.6*; and ".250" slug we get 6.8* (all measured without shims on upper control arm)
diff x-member:
-places the inside u-joint 0.50" higher than the outside. You can't move it much as the driveshaft yoke will hit the bodies on the earlier cars and you'll start running into pinion angle issues.
Old 09-04-2014, 02:04 PM
marolf101x
marolf101x's Avatar
Jakvette asks, "What are the design intentions for the rear trailing arm set up?"
Design intention is:
-limit toe change via OE front bushing
--we have two options, a "low movement" rubber bushing, for those who want to daily drive with minimal NVH increase; or a teflon lined bearing option for those who want zero movement.
-allow the widest wheel/tire combo possible
--we do this by stepping the trailing arm in around the tire. The OE frame is now the limiting factor
-increased strength
--we use a fully welded "truss" design that keeps things extremely strong but doesn't weigh a ton
-adjustable pick up location for coil over (coil over located behind axle)
-look cool!
Old 09-04-2014, 02:11 PM
marolf101x
marolf101x's Avatar
Vince'82 asks,
"do you plan to build a 80-82 rear suspensions kit later?"
-If there's enough interest, yes.
"can we re-use brakes designed for stock spindles?"
-not at this time. Our spindle uses F or A Body brakes. We did this for a couple of reasons; one there are more brake options available for the A/F Body cars; two our spindle works great in this application.
-I'm working on a spindle that would allow you to use your current brakes. Would require a bracket change. However, with so many brake options out there this may not be feasible.
Old 09-04-2014, 04:08 PM
TheSkunkWorks
Appreciate the quick response to so many of my questions.
Tho I'm not personally in the market for a drop spindle based setup, I'm certain those who may be will find the info very helpful in their considerations. Best of luck!
To Building up a c2-c3 chassis
Old 09-04-2014, 06:29 PM
marolf101x
marolf101x's Avatar
Though we use a drop spindle we don't lower the car that much. The C2 needed to get lower. . .the C3, not so much. The C3 was more of a "make the tire fit the well better" deal while dramatically improving suspension geometry.
Old 09-04-2014, 06:54 PM
7t9l82
7t9l82's Avatar
nice set up, that wrinkle finish will collect dirt in a hurry, ask how i know.
Old 09-05-2014, 01:28 AM
jakvette
jakvette's Avatar
Default suspension design
Hi ,
Great idea's and design sounds and looks great from the pictures posted .
Any pics of the rear design or components other than the diff mount member ??
Pricing ??
john
-increased strength
-look cool!
Quick Reply: Building up a c2-c3 chassis
