Well, I finally did it.. (ECS /FSP)
Received 1,194 Likes
St. Jude Donor '15
Well, I finally did it.. (ECS / FSP) - Supercharger / Mantic 9000 / AlkyControl
Updated 9/26/2017 - THREAD INDEX:
Pulling transmission/rear (torque tube bearings)
https://www.corvetteforum.com/forums...post1588323831
Unboxing ECS supercharger kit
https://www.corvetteforum.com/forums...post1588432856
Beginning Install
https://www.corvetteforum.com/forums...post1588432980
Harmonic balancer failure
https://www.corvetteforum.com/forums...post1588510589
Racetronix harness / BAP install
https://www.corvetteforum.com/forums...post1588579334
Dash logic install
https://www.corvetteforum.com/forums...post1588702119
Replacing AC clutch
https://www.corvetteforum.com/forums...post1588800046
Belt alignment
https://www.corvetteforum.com/forums...post1588867466
Clutch bleeder install
https://www.corvetteforum.com/forums...post1588955727
Pilot bearing install
https://www.corvetteforum.com/forums...post1588964790
Alky control kit unboxing
https://www.corvetteforum.com/forums...post1589098615
Alky control install
https://www.corvetteforum.com/forums...post1589189668
Clutch replacement, again
https://www.corvetteforum.com/forums...post1589134147
Gutting cats (off-road use only, of course)
https://www.corvetteforum.com/forums...post1589189737
Monster LT1-S TRIPLE
https://www.corvetteforum.com/forums...post1589232067
More clutch bleeder install pics
https://www.corvetteforum.com/forums...post1589228899
Swap to card style MAF
https://www.corvetteforum.com/forums...post1589323080
ID1000’s showed up!
https://www.corvetteforum.com/forums...post1589331178
Moved IAT to after TB
https://www.corvetteforum.com/forums...post1589497269
New style steering wheel install
https://www.corvetteforum.com/forums...post1589592598
https://www.corvetteforum.com/forums...post1589610616
Opening up restrictor plate (1st time)
https://www.corvetteforum.com/forums...post1589597930
Center console / nav
https://www.corvetteforum.com/forums...post1589643618
Mighty Mouse catch can
https://www.corvetteforum.com/forums...post1589765556
https://www.corvetteforum.com/forums...post1589790315
Remote catch can drain / flex fuel wire / Z06 Exhaust
https://www.corvetteforum.com/forums...post1589887793
Z06 Exhaust Install
https://www.corvetteforum.com/forums...post1589938906
BTR 660 valve springs / trunion
https://www.corvetteforum.com/forums...post1589981178
One more clutch swap.. Monster LT1-S Twin
https://www.corvetteforum.com/forums...post1590166848
Z06 fuel pump
https://www.corvetteforum.com/forums...post1590233661
Power steering pump failure / replacement
https://www.corvetteforum.com/forums...post1590320767
Power steering pump / new 3.25” blower pulley and push rods
https://www.corvetteforum.com/forums...post1590332429
Added fuel pressure sensor
https://www.corvetteforum.com/forums...post1590483029
https://www.corvetteforum.com/forums...post1590762554
SC Tensioner pulley bolt breakage
https://www.corvetteforum.com/forums...post1590663471
New battery cable ends
https://www.corvetteforum.com/forums...post1590810463
Cam swap parts collection
https://www.corvetteforum.com/forums...post1590836114
https://www.corvetteforum.com/forums...post1590889484
Cam swap
https://www.corvetteforum.com/forums...post1590895893
A&A air filter (nicer than ECS one)
https://www.corvetteforum.com/forums...post1590931196
NPP Exhaust Controller install
https://www.corvetteforum.com/forums...post1591003860
New charge tube, no MAF
https://www.corvetteforum.com/forums...post1591608011
New tires, NT05R Rear, NT05 fronts
https://www.corvetteforum.com/forums...post1591749014
Alky pump replacement, before/after pressure graph
https://www.corvetteforum.com/forums...post1591860211
Rear steam vent / coolant crossover install
https://www.corvetteforum.com/forums...post1592019809
First 1/2 mile (Hot Springs, VA) - Fogged out
https://www.corvetteforum.com/forums...post1592108363
GoPro Gimbal
https://www.corvetteforum.com/forums...post1592141811
Second 1/2 mile (Georgia)
https://www.corvetteforum.com/forums...post1592219177
dude_man fish and beard special
https://www.corvetteforum.com/forums...post1592406406
HUD repair / shift light install
https://www.corvetteforum.com/forums...post1592409879
AEM 30-0333 wideband install
https://www.corvetteforum.com/forums...post1592473632
FUEL SYSTEM Build / Install
https://www.corvetteforum.com/forums...post1592942709
https://www.corvetteforum.com/forums...post1592984655
https://www.corvetteforum.com/forums...post1593030905
https://www.corvetteforum.com/forums...post1593043108
Third 1/2 mile (Georgia)
https://www.corvetteforum.com/forums...post1593077328
New ECS tensioner
https://www.corvetteforum.com/forums...post1594080192
Moved IAT back to charge tube
https://www.corvetteforum.com/forums...post1594496212
Long tubes from Vararam
https://www.corvetteforum.com/forums...post1594542483
https://www.corvetteforum.com/forums...post1594694230
Fourth 1/2 mile (North Carolina) - finally, 163mph first run
https://www.corvetteforum.com/forums...post1594785712
LS9 Head gaskets / ARP head studs
https://www.corvetteforum.com/forums...post1594827776
https://www.corvetteforum.com/forums...post1594925471
Fifth 1/2 mile (Hot Springs, VA) - 160mph (higher elevation)
https://www.corvetteforum.com/forums...post1595257415
Original Post:
After watching you guys have all the fun for years, I finally sent a check off to Matt @ FSP this afternoon for an ECS kit. Hopefully I'll be able to install it over Thanksgiving break and start the process of breaking more parts
I guess this is how it always begins??
I'm already adding up how much a decent clutch & meth are going to cost me next..
Beginning Install
Dash logic install
Replacing AC clutch
Belt alignment
ID1000’s showed up!
Z06 Exhaust Install
Z06 fuel pump
Cam swap
GoPro Gimbal
New ECS tensioner
Original Post:
The following 3 users liked this post by schpenxel:
Don't worry. The beauty of buying at FSP is that Matt guarantees the car bumper to bumper for one full year, even if you install it yourself.
You will have a blast. Enjoy.
St. Jude Donor '15
Congrats! My suggestion to you is to read the instructions a couple of times before you start and take your time. A helper will be great at certain points, like when removing the steering rack out the way. I tried removing it from the drivers side like the instructions recommend to no availability. I just did it the same way like when I installed the cam previously and let me tell you that it's just easier.
Since I did it about 3 weeks ago, everything is still fresh in my mind. Pm if you need help.
Free back rubs and foot massages too
St. Jude Donor '15
Congrats! My suggestion to you is to read the instructions a couple of times before you start and take your time. A helper will be great at certain points, like when removing the steering rack out the way. I tried removing it from the drivers side like the instructions recommend to no availability. I just did it the same way like when I installed the cam previously and let me tell you that it's just easier. Since I did it about 3 weeks ago, everything is still fresh in my mind. Pm if you need help.
One question--on pinning the crank, I've seen two different methods. One is pulling the steering rack altogether, another is lowering cradle while raising engine to get enough clearance. Seems method #2 would be less work, but not many people seem to do it that way. I think it was the Magna charger instructions that used second method
Any suggestions from anyone on which is best? I pulled the transmission/torque tube in like 2 hours last weekend without a lift, so I think I'll be fine regardless, but still want the easiest way that works
St. Jude Donor '15
St. Jude Donor '15
St. Jude Donor '15
Thanks--I've read through them a few times. Some of it wont make sense until I have it all in front of me, but I at least have a basic idea of what has to happen
St. Jude Donor '15
No problem. I tried the ECS method in the instructions which happens to be the same as the magnacharger and I thought that it was a bad idea. I just didn't have any luck loosening the craddle nuts since the whole stud would be coming off, and that's a no no. So that was a waste of time and reverted to the passenger side method which I used in the past for my cam install and it worked just fine. I recommend ondoing the abs module bracket and the power steering pump too for added freedom of handling of all the lines for the steering rack.
Or I could be completely wrong. I'm still researching it
Received 1,261 Likes
I just moved the rack over to the passenger side enough to gain clearance to the balancer... I've done it twice this way, once to do my cam and another to install a new balancer... the only way I think it will totally come out from the driver side is to lower the cradle just a bit, but you don't have to go that far if you don't want to
Removing the rack is a PITA!! I lowered the cradle by wedging a couple pieces of wood to hold it in place and raised the engine. Waaaaaay easier and had plenty of room. You'll need a 90° air powered drill cause there smaller. It seems harder than it is. It really was easy to do.
OP, my bad I forgot. I removed the steering rack this second time because I had to swap the hb since I installed an ud one when the cam went in. But yes, the steering rack can be a pain and may need to be removed if you're planning to install a better hb.
Exactly what I did.
St. Jude Donor '15
Exactly what I did.
it can still be done without totally removing the rack, just move the rack as far over to the passenger side as possible and move the driver side tie rod up and out of the way to clear the balancer so it can be removed... I did my cam and then a balancer swap with the rack still in the car on both occasions... the first time it will seem like a pain but after that it's a piece of cake and not as bad as it's made out to be
Thanks everyone. Just curious how long it takes you guys to "work around" the rack, be it by lifting engine or just sliding it over?
It took me about 2 maybe 3 hours total to do it and that's that about an hour or so of that was just in pinning the crank with 3 drill bits later. I have a forged crank so it takes fooooorever!! Lol
Drill bit went right through the steel part of the balancer but once it hit that forged crank it slowed waaaaay down!!
