Carbotech brake pads coupon code z28
Supporting Vendor
St. Jude Donor '11,'13
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam - can you explain your pre bed procedure and cost VS what carbotech recommends for on car bedding?
I looked on your website and could not find the information nor a part number associated with pre bedding.
Supporting Vendor
Pre bedding is done by carbotech. There is no part# for it. Pre bed option is $20 an axle so, total $40. The procedure consist of heat the pads in an oven for a certain amount of time to release the gasses from the binding material. This allows you to put them on and go. Your rotors will need to be clean if the material on them is not carbotech. This is only for AX and XP series pads. The 1521 does not require this procedure. What are you looking for?
Supporting Vendor
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call, Email or PM and we can recommend the compounds that will be perfect for your front and rear pads, assuring that they perform together with optimum effectiveness.
