C5 Vendor for Sale Exclusive forum for vendors to list C5 products, services and promotions.
Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 12-06-2014, 01:44 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Default Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
=&amp2013 C6 Z51 Sway Bars!
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $269.99
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 325 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
You know that feeling when you’re going into the turn and the car leans pretty heavily? These bars are meant to make the vehicle feel flatter in the turns and corner much better in the turns. Another advantage is the handling when you’re coming out of the turn. When you come out of the turns you will not be fighting the wheel as much as you would with the stock bars. These bars, since they’re thicker, make it easier all the way through the turns.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
We offer these sway bars with the 2013 C6 Z06 shocks. Also, whether it is a C5 or C6, coupled with the 2013 C6 Z06 shocks it makes a total different handling package. This package speaks for itself as we have many testimonials from many customers from whom we sold these to here on the forum!
To order, please call 484-334-8833 or go to the link below to order!
https://www.cultragfactoryparts.com/...-kit-c6z51bars
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
Complete kit front and rear is $269.99
Use part number c6z51bars on our website.
=&amp2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $309.95. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
https://www.cultragfactoryparts.com/...it-c6z06shocks
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $319.99.
For the shocks on our website, use part number c6z06shocks.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Thank you,
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 01-04-2015, 10:49 PM
Breze84
Breze84's Avatar
What do you sell for front and rear swaybar endlinks... Endlinks only, I need a set... I had Heim Joint ones and they rusted and were froze solid...
Old 01-09-2015, 12:10 AM
patrickt
patrickt's Avatar
Yes we do! You can email me at Patrick@cultragperformance.com and I can get you set up with some
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
Old 01-09-2015, 02:23 PM
at1222
Navigator
at1222's Avatar
I am about to purchase locally some used c6 z06 shocks and a c6 z06 front only sway bar because I read the front is the same z06 or z51. Am I able to order a c6 z51 rear sway bar separate or do I have to buy the whole front/rear kit? If front only could you please PM me a price? Thanks!! Also do these work well with the stock c5 tire size 245/275 or should I also look into wider wheels and tires for these?
Old 01-09-2015, 10:47 PM
Gene Culley
You can purchase the sway bar and bushings separately. Please send me an email to gene@cultragperformance.com with the zip code and I will take a look at it for you. You'll be good with the tire size.
Old 02-09-2015, 05:50 PM
Rj-lo
Rj-lo's Avatar
So Im clear, if I have a c5 with the adjustable suspension (sport/track/whatever).. would these shocks work or what would happen?
Old 02-11-2015, 09:22 PM
Gene Culley
If you do not have the 2003 or 2004 Anniversary Edition with the adjustable suspension you can use the shock simulators, yes.
Old 05-25-2015, 11:29 PM
Kehraus
Kehraus's Avatar
Ordered with the Memorial Day discount, awesome deal!
Old 05-27-2015, 09:49 PM
Gene Culley
Thank you for the opportunity to earn your business. I certainly appreciate it.
Old 06-20-2015, 01:07 AM
Kehraus
Kehraus's Avatar
I got in on the Memorial Day sale, this is a really good deal.
I got mine on today and took it out for a spin through nice roads and I am very happy with this upgrade.
Old 06-21-2015, 01:01 PM
Gene Culley
Thank you for your business. We're happy that you're happy!
Old 06-27-2015, 08:42 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Gene,
What is your price for GM T1 front and rear bars with end links? My zip is 18064.
Thank you
Dan
Old 06-27-2015, 02:53 PM
mikehimself
mikehimself's Avatar
I'm new to doing track days in a Corvette, but I have a bit of experience in other cars. The stock setup was pretty sloppy on my 98 -Z51 so I ordered the sways, shocks and endlinks listed above. The car is WAY more neutral, much more flat through the turns but not harsh at all on the street. I'm very happy with this setup for the street and track.
Old 07-01-2015, 10:07 PM
Gene Culley
Originally Posted by Dan H.
Gene,
Thank you
Dan
The kit is $995. This thread is in regards to the C6 Z51 sway bars and C6 Z06 shocks. For all other requests please send us an email or give us a call.
Gene Culley
Thank you for your business and the valuable feedback.
Old 07-22-2015, 11:12 PM
Rj-lo
Rj-lo's Avatar
Dang it. I need to get off my butt and order this... my shocks are gonzo
Old 08-16-2015, 10:10 PM
Scn1998
Scn1998's Avatar
Have installed the sways, shocks, and metal end link from Cultrag. Made a huge improvement on the handling of the car. While I do not track the car I do appreciate how level the car is entering fast corners.
To Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 08-19-2015, 11:20 AM
patrickt
patrickt's Avatar
thank you for the feedback!
Old 11-14-2015, 12:57 PM
patrickt
patrickt's Avatar
Thank you for your orders
Old 11-19-2015, 03:54 PM
Jeremy S
Jeremy S's Avatar
Originally Posted by Gene Culley
Order your suspension upgrade from CULTRAG Performance.
Definitely going to pick up a set of the C6 Z51 sways with new endlinks.
When will we see the Black Friday special?
Thanks
Quick Reply: Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
