Get Your LS7 Clutch Kit & Fidanza Aluminum Flywheel Option From CULTRAG Performance!
Premium Supporting Vendor
Hello All,
Thank you for your interest in our LS7 clutch kit. Many people ask us how much horsepower this clutch can hold. GM doesn’t have any official numbers but you can count on 650 horsepower. We have not had any reports of issues with this in any vehicle, unless you take it to the track and constantly dump the clutch. If you’re dragging the vehicle, then you need a different clutch.
With the 2004 Z06 GM updated the slave and master cylinders for a bigger bore to allow more fluid flow. The slave and master cylinders that we sell are only the 2004 Z06 and fit all C5’s from 1997-2004. The slave cylinder also comes with a new throw-out bearing. We recommend a new pilot bearing when installing as well.
To order, please call 484-334-8833 or go to the link below to ordering using our LS7 clutch kit configurator system.
Thanks. Gene.
Order LS7 Clutch Kit Link!
https://www.cultragfactoryparts.com/...t-ls7clutchkit
Our independent in house weight test results were stock LS7 flywheel 26 lbs. 11 oz. and the Fidanza aluminum flywheel 13 lbs. 5 oz.
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24255748 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are $559.99 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
We are now offering the LS7 clutch kit with the matching Fidanza 12.9 lb. aluminum flywheel.
Comes with LS7 clutch disc, pressure plate, alignment tool and Fidanza flywheel - $799.99
24264180 - LS6 Slave Cylinder – $158.16
12564455 - LS6 Master Cylinder – $161.01
14061685 – Pilot Bearing – $16.48
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, you can only use LS1/LS6 hydraulics, not LS7 hydraulics.
=&We now also provide a clutch alignment tool with the kit and the kit from GM does not come with this so we have added it for your convenience!
Thanks. Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Place your order today!
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
Carajo (01-17-2017)
Thinking about ordering this setup. Cant decide if you want to go with the lighter flywheel...
Doesn't the ls7 clutch and weight more than the ls1 clutch? I want it to be as close as it is to stock feel as I can get.
Carajo (01-17-2017)
We do not have exact weights of the LS1 clutch to compare but since it is larger it would suggest it would weight a little more
The memorial day sale is over but thank you all for your orders and patronage. IT is greatly appreciated and thank you again to our brave service members for all you do and the risks and sacrifices you take every day.
Yes, you can change the master without any issues. All you need to do for shipping options is to add to the shopping cart on the website and select from the list of shipping options.
Greetings Friends and Patrons,
Happy Holidays and Merry Christmas to you and your family from all of us here at CULTRAG Performance. As usual, leading up to Christmas we are being asked if we will please bring a sale for Christmas this year. And you know we’re always up for a sale! It’s great that you guys ask for it.
As we announced previously, at the beginning of November, we already lowered the prices approx. 10% across the board on our website.
This year we are going to give you an opportunity to take a little more money off for Christmas. To step it up a notch, and as a thank you to all of our customers, we will take 10% off ALL orders up to $999 and we will take 15% off orders over $1000.
Starting at midnight Eastern, Sunday 12/22/2019, through Friday 12/27/2019 at 11:59 PM Eastern on our website only at cultragfactoryparts.com we offer you the following:
Use promotional code CHR201910
15% off ALL orders over $1000
Use promotional code CHR201915
Please keep in mind, the ending of the GM strike and their efforts to get back on track have caused delays. When processing your order, we’ll give you an idea of what to expect on your individual orders and items.
We will be out of the office Christmas Eve, 12/24/2019 and we will return on Thursday 12/26/2019. If you need assistance with your orders, please email customer.service@cultragfactoryparts.com.
We ask you to like us on Facebook, https://www.facebook.com/cultragperformance, follow us on Twitter, https://www.twitter.com/@cultrag or follow us on Instagram, https://www.instagram.com/cultrag_performance.
Thank you for your business and support,
Gene & Patrick
How to use promotional codes?
As you’re checking out you’ll be asked for a Promo Code right below where it gives you the order total in the order summary box on the RH side of your screen. Use the appropriate promotional code for your order total. If you have any problems or issues with your order or using the code, do not worry, we will assist you in getting the parts you need. Please do not check out or place an order without the promotional code.
The CULTRAG Performance Christmas Holiday Sales Event is valid from Sunday 12/22/2019 (12:01 AM Eastern) through Friday 12/27/2019 (11:59 PM Eastern) for orders placed on the website only. Orders placed before and after these dates and times are not eligible for the promotional code(s). Customers must use the promotional code at the time of ordering in order to be eligible. If the promotional code is not used at the time of checkout no concessions will be given later.
Gene & Patrick
Get in on the deal. And as the sale closes tonight I'd like to thank all of you for your orders. One thing to keep in mind, once our sales close I always get someone who comes in late or the next day with a problem not being able to order or some other type of comment. If it is a couple of hours or a day or so after the sale is over just send me an email to gene@cultragperformance.com and let me know what you are looking to order and I'll take care of you. It's no big deal.
