C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Old 01-03-2015, 02:27 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Do you get tired of driving down the road and having all of your belongings in the trunk cargo area end up directly behind your head? Southern Car Parts is carrying on our tradition of the trunk partition for the all new 2014-2015 C7 Corvette Stingray. We originally created the Corvette trunk partition for the C5 Corvette and then C6 Corvette. Many Stingray owners were asking for us to create something for their C7 and we did. This trunk partition will easily slide into the cargo area and just rest in place, tightly against the roor latches.
In Stock Here: http://www.southerncarparts.com/corv...on-p-6612.html
The C7 Corvette Stingray trunk parition is designed so that you simply lay the partition down while the removable top is being stored. Best of all, this partition does not require any permanent modifications and can be removed in the matter of seconds. We've designed this parition to sit in place tight and will not move under hard acceleration or under hard breaking.
The C7 Corvette Stingray trunk partition is made out of quality 1/2" MDF board and is carpeted on all sides and on all edges for a nice finished look. This piece really looks like GM included it from the factory.
ALSO AVAILABLE C7 CORVETTE TRUNK VETTE TRAY
For the C7 Corvette Stingray. Are you tired of items sliding around the back of your Corvette with little usable or convenient storage space? If so, the Southern Car Parts VetteTray Cargo Organizer is for you.
VetteTray Available here: http://www.southerncarparts.com/corv...ay-p-5855.html
The VetteTray is sturdy yet lightweight weighing in at less than 1 pound. Our registered design is constructed of 2 inch High-Density foam which is factory cut and wrapped in matching black or dark grey carpet for a perfect fit and finish. Keeping weight in mind, the Vette Tray is made from Extruded Polystyrene foam and wrapped in black carpet that is a close match to the C7 carpet. If you are unhappy with your purchase for any reason, simply return it for a full refund.
- Each VetteTray comes standard with (2) Drink Holders and (2) 9 x 12in storage trays
- Perfect for holding cellphones, PDA's CD's, wallets or any other small items
- Required NO modifications to your Corvette
- Does not come loose with hard braking or acceleration
Old 02-15-2015, 10:11 PM
steve miller
Support Corvetteforum!
steve miller's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Will the top fit in the car with the tray installed, and can it installed over the Lloyds cargo mat?
Old 02-16-2015, 04:48 PM
southerncarparts
Supporting Vendor
The top storage...With the tray yes, with the partition, no. Yes, you can use the lloyd cargo mat with either.
Old 04-12-2018, 10:17 AM
southerncarparts
Supporting Vendor
Thanks for considering Southern Car Parts!
Old 04-21-2018, 12:26 AM
zeagen
zeagen's Avatar
Default Question on Trunk Partition
Didn’t you use to make a version that had lids? Was nice to keep things hidden and out of the sun.
Old 04-25-2018, 10:19 AM
southerncarparts
Supporting Vendor
Not for the C7. I used to have them with lids for the C5 and C6, but they're discontinued these days. I keep hoping we'll be able to bring them back at some point, but one of my parts suppliers isn't in the business anymore and I haven't found a suitable replacement yet.
Old 08-10-2019, 08:35 AM
southerncarparts
Supporting Vendor
To New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Quick Reply: New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
