Intakes Intakes INTAKES! | C6/C6 Z06 | Best prices & FREE shipping | JDP Motorsports
Former Vendor
JDP Motorsports is proud to offer a wide variety of intake systems for your C6 Corvette!
Airaid
Airaid - Intake System (Oiled Filter) - 2005-2007 C6 Corvette - Part # 250-218
Airaid - Intake System (SynthaMax Non-Oiled Filter) - 2005-2007 C6 Corvette - Part # 251-218
Airaid - Intake System (Oiled Filter) - 2006-2013 C6 Z06 Corvette - Part # 250-216
Airaid - Intake System (SynthaMax Non-Oiled Filter) - 2006-2013 C6 Z06 Corvette - Part # 251-216
It is a proven scientific fact that cold air is denser than hot air, which means that an engine breathing cold air is going to make more power than the identical engine breathing hot air. The quest for cold air is what drives the AIRAID® Cold Air Dam Intakes. The CAD Intakes retain the stock filter location but give the stock intake system a big boost with the addition of a huge air inlet that provides a steady, free-flowing supply of cold air. This is done via Cold Air Dam panels, which mount in the factory air box location and utilize any factory cold air inlet ducts that are present, while adding additional cold air passages to the filter. These panels also keep the filter isolated from the hot engine compartment air by sealing to the underside of the hood via blade-style weatherstripping. Each AIRAID® Cold Air Dam Intake is designed specifically for each vehicle application and offers a simple, trouble-free installation using simple hand tools. Like the rest of the AIRAID® systems, the CAD Intakes are Made in the USA and include all the necessary installation hardware as well as easy-to-understand instructions written with the do-it-yourselfer in mind.
Product Features
- Easy to install with basic hand tools
- HP Power increase Guaranteed
- True OEM Direct Replacement
- Hand Poured Urethane Body – Won’t crack, shrink, or curl like Rubber or Plastisol
- AIRAID’s exclusive unique filtration technology – enables the AIRAID filter to filtrate far superior to the average cotton filter
- Oiled or SynthaMax non-oiled filter
- Includes free shipping to the lower 48!
- Proudly Made in the USA!
Airaid - Replacement Filter (OEM Airbox) - 2005-2007 C6 Corvette V8 - Part # 851-063
AIRAID® Direct-Fit Replacement filters fit in the factory air box and are drop-in replacements for stock paper filter elements. Constructed using the same premium materials used in our Cold Air Intake Kits, these filters offer significant improvements in air flow and filtration while being washable and reusable. Why throw money away on a paper filter each time the old one gets dirty when you can upgrade to a serviceable AIRAID® Premium Filter for often less than the cost of two stock replacements? AIRAID® Direct-Fit filters require no modifications and installation is as simple as replacing a stock filter.
Product Features
BBK
BBK - Cold Air Intake System - 2005-2007 C6 Corvette LS2 - Part # 1735
BBK - Cold Air Intake System - 2006-2013 C6/C6 Z06 Corvette - Part # 1749
These Corvette C6 systems can be installed in just minutes and are good for approximately 14-20 horsepower, depending on other modifications. They will enhance the performance of other power adders such as performance exhaust and performance throttle body and are available to fit 2005 through 2013 Corvette C6 models.
These BBK Corvette C6 Cold Air Intake Systems utilize high flow washable cotton element filters and are CAD designed for optimum airflow and Maximum Performance. All Corvette kits are vehicle specific and are designed as a direct bolt on using simple hand tools - For maximum performance for your Corvette BBK recommends adding a throttle body and exhaust system.
Halltech
Halltech - Super Bee MF103 (MAF Forward) Intake - 2006-2013 C6/C6 Z06 Corvette - Part # SBMF103
Halltech - Super Bee MF103 (MAF Forward) Race Version Intake - 2006-2013 C6/C6 Z06 Corvette - Part # SBMF103R
Halltech's Super Bee™ MF103 Ram Air Induction including Beehive™ requires NO TUNING and has better than stock idle manners due to the MAF forward design and integrated velocity stack built into the filter flange. Made from roto-molded cross link polyethylene it brings the same horsepower to your LS3 or LS7 as you have seen with the Super Bee™ FG102 or CF112 Carbon.
The Super Bee™ MF103 is 102.5mm at the MAF read and at the exit, meaning it is larger than the massive Williams Performance 102 Throttle Body, but comes with the connector hose for the stock throttle body, however, it can be ordered with the larger connector hose for the WP102 TB.
Halltech's roto-molded version of the Super Bee™ FG102 features the same filter and Beehive™ as the Carbon and Fiberglass version as well as the Killer Bee™ II. Since early 2010, the Super Bee™ has been the dominant Halltech induction system, with staggering horsepower and torque numbers that have literally shattered all records.
The MAF sensor and PCV plastic nipple are not included, since they are swapped from the stock intake system. You will need an 8mm and 7mm nut-driver to install this intake system. You may need to include the Security TORX bit shown as an accessory in the side bar to remove your stock MAF screws. 2011 LS3s may have the 5 point Security Plus screws from GM. Full Ram Air requires some cutting of the radiator shroud, which can be done without removing the shroud.
K&N
K&N - Fuel Injection Performance Kit - 2005 C6 Corvette V8 - Part # 57-3052
K&N - Aircharger Intake System - 2006-2007 C6 Corvette - Part # 63-3052
The 57 Series Generation II air intake, also referred to as an FIPK is K&N's ultimate performance product. These performance intakes are designed to increase power by as much as 10%. 57 Series FIPK's are CARB exempt, street legal in all 50 US states, come with a Million Mile Limited Warranty and are guaranteed to increase power. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This translates into more power and torque for your vehicle. The filters in these kits are washable and reusable.
K&N 63 series aircharger kit for a 2006-2007 C6 Corvette includes a composite intake tube, and high flow K&N washable air filter. This system replaces the factory restrictive intake system and is designed to dramatically reduce intake restriction resulting in increased horsepower and performance.
Product Features
- Guaranteed horsepower gain
- Designed to improve throttle response and engine sound
- Free-flowing high density polyethylene tube
- Replaces entire factory air intake system
- Lasts up to 100,000 miles before service is required (depending on driving conditions)
- Easy to install, usually in 90 minutes or less
- Includes K&N's Million Mile Limited Warranty!
- Includes Free Shipping to the Lower 48!
K&N - Aircharger Intake System - 2008-2013 C6 Corvette LS3 - Part # 63-3073
Aircharger systems are a sister product to K&N's 57 Series FIPK. The K&N 63 Series AirCharger Intake Kits are guaranteed to increase horsepower and come with a Million Mile Limited Warranty. K&N intake systems replace your vehicle's restrictive factory air filter and intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This allows your vehicle's engine to inhale a larger amount of air than the OEM filter assembly. More air means more usable power and acceleration throughout the engine's RPM range. The filters on these kits are washable and reusable. Most of K&N's intakes are relatively easy to install using basic hand tools. 63 series intakes are street legal in most states.
Note: The 63 series air intake can't be sold in California and is not legal for use in California or other states adopting California emission standards.
LG Motorsports
LG Motorsports - Carbon Cold Air Intake - 2005-2013 C6/C6 Z06 Corvette - Part # 2077
LG's carbon air intake made entirely of carbon fiber, this high-flow air intake will not only increase your Corvette's performance, but will also dress up your engine bay at the same time! This intake has shown an increase of 12-15 rwhp over the factory stock intake system. Included is a high performance cotton gauze filter element that is washable and will last the life of your vehicle. Kit also comes with all required clamps and hoses.
Product Features:
- High flow lifetime filter
- High flow plenum area
- Smooth coupler
- OEM hold downs
- Includes hardware for complete installation
Vararam
Vararam - Snakecharmer Air Induction System - 2005-2007 C6 Corvette LS2 - Part # VR-SC1
Vararam - Snakecharmer Air Induction System - 2006-2013 C6 Corvette LS3/LS7 - Part # VR-SC1R
Features special internal aerodynamics and filter placement to maximize peak cfm. They include a pleated filter that is washable and reusable. It has deeper pleats--more than any other filter--and peaks and valleys that have been opened up to further increase flow capacity per square inch. The system uses a roto-molded upper section to ensure a seamless internal aero package leading into the mass airflow sensor. The lower scoop section is vacuum-formed to allow for different vehicle applications.
The C6 Corvette Vararam VR-SC1/R Snakecharmer is the choice of Corvette enthusiast that want true RAM Air performance. The VR-SC1 fits Corvettes with the 6.0L LS2 engine and the VR-SC1R fits Corvettes with the 6.2L LS3 and 7.0L LS7 engines. If you are looking for a Corvette Intake system that draws cold air from the outside of the car, then look no further than the Vararam VR-SC1R. The Vararam air induction system does not require tuning. Unleash the power of your LS2, LS3 and LS7 powered C6 Corvette!
Product Features
- Roto-molded upper section to ensure a seamless internal aero package leading into the mass airflow sensor
- The lower scoop section is vacuum-formed to allow for different vehicle applications.
- Deeper pleats--more than any other filter--and peaks and valleys that have been opened up to further increase flow capacity per square inch.
- Guaranteed gains of 3.5 tenths or 3.5 mph through the 1/4 mile.
Please feel free to call, PM or email us anytime with questions. We appreciate your interest and support and hope toy have a great day!
Best regards,
Tyler
801.545.4215
sales@jdpmotorsports.com
Airaid
Product Features
Product Features
BBK
Halltech
K&N
Product Features
LG Motorsports
Product Features:
- Smooth coupler
- OEM hold downs
Vararam
Product Features
Best regards,
Tyler
801.545.4215
Former Vendor
Thanks for the orders! Please feel free to call, PM or email us anytime with questions or for a sweet deal!
Best regards,
Tyler
888-308-6007
Best regards,
Tyler
888-308-6007
Former Vendor
Give your Vette a breath of fresh air with one of these Intakes
Please call, email or PM us anytime with questions. We appreciate your interest in our products and have a great day!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
Thanks for the orders, Corvette Forum! Please call, email or PM us anytime with questions. We appreciate your interest in our products and have a great day!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
All the good ones, right here. Let the gateway modding commence!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
All PMs and emails replied to. We appreciate all the interest, Corvette Forum!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
See us on MavTV in the Optima Battery Search for the Ultimate Street Car Invitational!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
All the best,
Jared Royce
JDP Motorsports
888.308.6007
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Mr Royce could I get a price check on a airaid cia for a 2009 base with performance package, shipped to clovis ca? Thank you for your time sir. ...
Former Vendor
Former Vendor
All the best,
Jared Royce
JDP Motorsports
801.545.4215
Former Vendor
Nothing wrong with getting all your ducks in a row before race season . Let us know if we can help. We will get you the best price around!!
Best regards,
Kayla L.
801.545.4215
Best regards,
Kayla L.
801.545.4215
Former Vendor
Help your Baby get the air She needs!!! Great gains and performance for your buck!!!
Any questions, please feel free to give Us a call!!!
Best Regards,
Robert @ JDP Sales
801*545*4215
Best Regards,
Robert @ JDP Sales
801*545*4215
Former Vendor
Hump day bump ! The weekend is so close you can almost taste it! Let us know if you need any parts for your weekend project .
Cheers,
Kayla L.
801.545.4215
Cheers,
Kayla L.
801.545.4215
Former Vendor
Lets hope this week go's by fast so we can enjoy one last ride before hibernation .
If you are planning on working on your car this winter let us know what you need or if you have any questions! Feel free to call,PM or email us at any time!
Cheers,
Kayla L.
801.545.4215
Cheers,
Kayla L.
801.545.4215
Former Vendor
It's finally Friday! We made it through the week and now it's time for some weekend fun . Let us know if you have any questions about any of our products!
Cheers,
Kayla L.
801.545.4215
Cheers,
Kayla L.
801.545.4215
