Cracked windshield
Cracked windshield
So mad this happened, first time for me on any of my past 5+ cars. But I got a rock chip crack in my windshield on the C7 this past weekend.
It's a good size crack, half dollar size, and sadly the crack is right in the drivers view directly in the middle.
I realize in the state of FL the windshields are replaced for free under my insurance, but I wonder when they switch it out will they use a factory GM windshield with the logo and one that is capable of working with the heads up display without any issues? Have anyone done this already and recommend a good company?
from what i understand they have a coating in the glass to make the heads up show better and it also costs a lot more ....make sure you tell them you have a heads up.....a glass guy told me he did one a camero and the said to just put reg glass so they dident have to pay the difference and the heads up was hard to see and blurry......thats just what i was told tho
I have state farm insurance and had a rock hit my windshield and crack it on my 2010 GS. I demanded a GM logo windshield, but the company stated that they don't replace with a GM windshield due to the high cost of the part. Instead they use an OE part which was ok, but the sunshield built into the upper part of the windshield wasn't like the GM part and the glass itself was lower quality.
You should be diligent that they DO NOT reuse the windshield molding and gaskets as the fitment will never be right. Ask them to replace with new gaskets and molding. They reused mine, and I never had any leaks, but when it was hot outside the gasket would pop out a bit and I had to push it in in some places on occasion. Lessons learned. Hope this helps.
Already looked into this. There is no windshield with the proper coating/surface requirements available today to use with the HUD other then the GM Chevy OEM windshield. DO NOT let your insurance company use a aftermarket windshield.
Cruising
Same thing happened to me
Simple enough repair and yes it is good to have insurance.
Jb.
Not any more...
I just had my windshield replaced under State Farm and when I demanded a GM certified version ($1,400), which is $400 more than a non certified, they said 'no problem" and it was replaced. I demanded a GM version after people on this forum advised me to do so. Of course, 2 days after the installation I got another chip which will mean another windshield but I am allowed 4 per year in AZ, thank goodness.
Turns out with my crack being directly in the driver's point of view the entire windshield needs to be replaced and the company the dealer recommended was happy to order the factory GM windshield! Let's hope it gets installed with all new rubber gaskets soon!
Thanks for all the input!
A quick word of caution... There's a large cable that serves the mirror lights, PDR, OnStar, etc. that runs up the A pillar on the passenger's side, so they tell me. It can be cut while trying to cut out the glue. The labor to replace it is over $2k, plus the cost of the cable. My dealer had a car in for this problem after the owner let an after market glass company try to replace the windshield. Lots of down time, lots of parts to remove and replace to replace the cable. I'd rather have the dealer do the work. I've used Safelite before with good results but really... how many C7s could the dude have replaced before "learning" on my car? Best have the dealer do it.
Safelite replaced the windshield on my 2014 BMW Grand Coupe with heads up display and matched the windshield to a T. I would call them if it happened to my Stingray.
CF Old Timer
Safelite is just a broker, they use independent shops based on your location, so your mileage can vary greatly over the skills any one shop can have. While I have received amazing service when calling for work at my office, 50 miles away where I live, the local shop they use is just awful. Starting with missing appointments, to the total lack of skills of the technician.
When scheduling with Safelite, be sure to get the name of the underlying shop. Call them and ask about their skill level working Corvette's etc. or better yet ask them for a reference customer in your local area. I know its crazy but better safe than sorry. YMMV
