L82 Cam Specs
In today's technowlogy, what is a current cam that meets this original cams performance?
Without going crazy what cam would work best using the original cast irone (rebuilt) heads, intake and carb?
Would replacing the exhaust manifold with a long tube header change your recommendation?
Not sure what gears I have in the rear end but car tachs about 3300 RPM@ 70 MPH.
Thanks
Before I went Roller cam I was looking at the Lunati Voodoo Flat tappet cam 262/268 for some increase in performance:
Lift .468/.489
Duration-219/227
LSA-112
Operating range of cam-1,300-5,500 RPM-good bottom end, strong mid range, decent power to 5,500...certainly better than the L-82 cam
Thanks, Gary in N.Y.
P.S. We still manage to sell a fair amount of these cams during the course of any business year! We've had decent HP numbers on the pump-gas 350" on some dyno tests also, using this cam.
Here are 2 sources I just looked up:
http://paceperformance.com/i-6255716...hydraulic.html
http://www.jegs.com/i/Chevrolet-Perf...96962/10002/-1
I have always thought the duration was 222?
Chevrolet Performance 3896962 - Chevrolet Performance Hydraulic Flat Tappet Camshafts
Representative Image
Product images may differ from actual product appearance.
JEGS Part Number: 809-3896962
Hydraulic Flat Tappet Camshaft •1968-81 Small Block Chevy L-46 and L-82 Corvette
•222 / 222 Duration @ .050''
•.450'' / .460'' lift
•114 Lobe Separation Angle
Clearly some sources say 224 and others say 222.......................
Also for you cam experts, the reason I was looking at the Lunati Voodoo 262/268 as a replacement for the L-82 cam at one time, my understanding the extra lift coupled with the split duration of 219/225 would produce noticeably more power than the stock L-82 cam even with stock heads? Yes?
Barry's70LT1 posting of GM cams might be corporate deception so other builders are thrown off slightly. I have worked on some of the original big block racing corvettes now raced in Historic motorsports association.
Just for the fun of it over beer after work we pulled a new in the box GM off road mechanical cam out and rigged it up with dial indicators and it measured different and lower numbers than the cam card. I'd say deceptive. But this was a very radical cam. If you ever get a chance be in the pit area when they are warming a group of them getting ready for their heat races like at the up coming Monterrey Historics! We usually took a couple of Can-Am cars and I was a pit crew person.
http://vid124.photobucket.com/albums...t044_WMVV9.mp4
The parts of the Voodoo cam that would make a difference is the more aggressive lobes which have less duration below the .050 spec and more above it with a broader nose. This will give more area under the curve for better cylinder fill. The tighter lobe center would give slightly more overlap. The tighter LSA along with the shorter duration would give an earlier closing intake valve that would help bottom end power. The aggressive lobe with less duration at .006 would make for better bottom end also. The combination would make for a little better usable power, nothing big though.
Mike
