Wilwood C6 C5 Big Brake Front & Rear Upgrade kit w/ 14" Rotors-$2299-Free Shipping
Old 09-02-2016, 12:53 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Default Wilwood C6 C5 Big Brake Front & Rear Upgrade kit w/ 14" Rotors-$2299-Free Shipping
Wilwood C6 C5 Big Brake Front & Rear kit w/ 14" Rotors-$2299
-Free Shipping!
-0% Financing for up to 1 Year!
-We accept ALL Car Care One Cards!
CLICK HERE TO PLACER YOUR ORDER!
Are you looking for a GREAT big brake upgrade for your C6 or C5 that won't break the bank? This is the kit for you! This kit comes with everything you need from Wilwood and TPS Motorsports! No other brake kit come close to giving you the performance of this kit for your money! ONLY other big brake kit in this price range is the C6 Z06 kit... why get stock when you can have an upgrade!
This great kit has everything you'll need to bolt them on your C5 or C6! This kit features large 6 piston front calipers with 14" Zinc Coated rotors and 4 piston rear calipers with 13" rotors. Calipers are NEW Wilwood Engineering parts and TPS Zinc Coated Rotors. Wilwood Street Brake Pads and DOT approved stainless steel brake lines are also included. Unlike other kits on the market our kit gives you the option to pick which rotor style, brake pads, and caliper you would like.
This is a direct bolt on system and comes complete with all needed parts.
* (2) Wilwood Aero6 6 Piston Front Calipers
* (2) Wilwood Superlite 4R 4 Piston Rear Calipers
* (2) 14" TPS Zinc Coated Cross Drilled Front Rotors|
* (2) 13" TPS Zinc Coated Cross Drilled Rear Rotors
* (1) Set Wilwood Street Front and Rear Brake Pads
* (1) Wilwood DOT Steel Braided Brake Lines.
* (3) Pints Motul Racing Brake Fluid.
Brake Rotor Option
*Slotted Only
*Cross Drilled
Zinc Rotor Color Option
*Slotted Only (Black only)
*Cross Drilled (Black, silver, or Gold)
________________________________________ ________________________________________ __
Wilwood Aero6 6-Piston Front Caliper
Aerolite 6R six piston radial mount front caliper kits add big brake stopping power and style to any 1997-2013 C5 or C6 Corvette! Aerolite 6R calipers incorporate race proven technology in a high strength forged triple bridge body design. They provide positive and confident pedal response that is matched to the OE master cylinder output and fully compatible with the ABS system. BP-20 dual-sport compound Smart Pads provide clean and quiet driving on the street, with improved friction and high temperature fade resistance for auto-cross and other sport driving applications.
Wilwood Superlite 4R Rear 4-piston Caliper
Superlite 4R calipers incorporate race proven technology in a high strength, center bridge reinforced forged body design. They provide positive and confident pedal response that is matched to the OE master cylinder output and fully compatible with the ABS system. BP-20 dual-sport compound Smart Pads provide clean and quiet driving on the street, with improved friction and high temperature fade resistance for auto-cross and other sport driving applications.
TPS 14" & 13" Zinc Coated Cross Drilled Rotor Set
TPS Performance Brake Rotors for Corvette's provide better stopping than the stock rotors and the performance look of cross drilled and plated rotors is an outstanding visual upgrade. These rotors are designed to eliminate out-gassing while minimizing stress cracks. These rotors are made by Centric the owner and maker of $3000 Stoptech brake. We then have them custom slotted and drilled to our specs.
Motul DOT 5.1 Brake Fluid- 3 Pack
Non-silicone based, long life and 100% synthetic, Dot 5.1 brake fluid conforms to the highest standards in brake fluid performance. DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS). With a high dry boiling point of 270anddeg;C and a high wet boiling point of 185anddeg;C, DOT 5.1 delivers the best brake performance. Non-silicone based and 100% synthetic fluid. DOT 5.1 is specially designed for Anti-Locking Brake Systems. High dry boiling point of 270anddeg;C. Wet boiling point of 185anddeg;C. DOT 5.1 delivers the best brake performance.
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Old 09-16-2016, 08:39 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Best Big Brake Kit Deal for your C5 & C6!
-0% Financing for up to 1 year!
No better Big Brake kit out there for the money! ONLY other big brake kit in this price range is the C6 Z06 kit... why get stock when you can have an upgrade!
Old 10-12-2018, 04:15 PM
Mirek
Mirek's Avatar
This was a great deal.
Old 10-12-2018, 04:23 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Yes it is..
Old 10-12-2018, 05:43 PM
Mirek
Mirek's Avatar
Yes it WAS.
The link no longer works (FILE 404_) and the kit you suggested on-line is (now) only the 4 piston caliper (upfront).
If you can give me this FT/RR deal on a 13.06 w/ 6 Piston Superlite upfront and the 4piston in back I will go place an order right now.
Old 10-12-2018, 05:45 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Yes it WAS.
Unfortunately there is no option for a 6 piston caliper on a 13" rotor... 4 Piston is the best that is avaialalbe
Old 10-12-2018, 05:48 PM
Mirek
Mirek's Avatar
That is 100% incorrect I am afraid. This can be confusing enough.
Old 10-12-2018, 05:51 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Let me rephrase... this is the ONLY option available to use on stock wide and sized rotors. And yes I am correct
Old 10-12-2018, 09:25 PM
Mirek
Mirek's Avatar
Looks like the 6 piston Forged Narrow Superlite (120-11779) and 160-8166 rotors (13.06) coupled with the 4P calipers and rear disks can be had with fluid and braided lines on Amazon for under $3k. Looks like the best game/deal in town for my needs.......(13.06 to fit 17” application w/superlite will fit without issue on the Wilwood site). I almost hit ORDER until I looked at the pic on your site more closely !)
Old 10-12-2018, 09:47 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
The part numbers you picked won't fit your car... you can't just take ANY Wilwood 6 Piston Forged Narrow Superlite Calipers and ANY Wilwood 13.06" rotor and slap them on your car. Go ahead and buy those parts off Amazon and let me know how it works out
Old 05-16-2019, 04:04 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Bad ***!
To Wilwood C6 C5 Big Brake Front & Rear Upgrade kit w/ 14" Rotors-$2299-Free Shipping
Quick Reply: Wilwood C6 C5 Big Brake Front & Rear Upgrade kit w/ 14" Rotors-$2299-Free Shipping
