C4 Vendor for Sale Exclusive forum for vendors to list C4 products, services and promotions.
Now available from SCP: C4 Corvette Coupe 1984-96 Blockit Pre Cut Quick & Quiet Mats
Old 09-20-2016, 04:46 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default Now available from SCP: C4 Corvette Coupe 1984-96 Blockit Pre Cut Quick & Quiet Mats
Your driving experience matters!
Reduce irritating interior noise in SECONDS by simply placing the pre cut Blockit Quick & Quiet Sound Deadening System right over your existing carpet! This is NOT a thin single layer mat! The BLOCKIT is a unique 4 layer combination of real acoustical soundproofing. It absorbs and suppresses unpleasant sounds. It quickly helps quiet your interior in seconds.
It’s perfect for taking that annoying edge off tire, road noise (especially certain states with certain roads that make tires whine), stock & some aftermarket exhausts. NO need to rip out your carpet & interior! The precision pre cut BLOCKIT Sound Deadening System is placed right over your carpet! One large piece fits perfect in your cargo area (Trunk for convertibles). One piece goes behind each seat.
We put a slit to allow easy access to your cargo doors. The durable UV protected top layer looks great and allows you to still use your cargo area The BLOCKIT also helps keep your cargo area cooler by suppressing heat from underneath
Quiet down your Corvette interior in SECONDS!
• Pre - Cut & lays right over your factory carpet!
• 4 Layers of REAL acoustical soundproofing materials
• Great for exhaust, tire /road noise and long trips
• UV protected top layer is durable & looks great
• Has a slit for easy access to your cargo doors!
• 3 Piece system!
• Helps keep your cargo area cooler!
• No Adhesive. All pieces are removable & reusable!
• Manufactured under strict ISO 9001 regulations
• Made in the USA!
Order here:
Old 08-05-2019, 08:57 AM
southerncarparts
Supporting Vendor
Quick Reply: Now available from SCP: C4 Corvette Coupe 1984-96 Blockit Pre Cut Quick & Quiet Mats
