C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Mamo Motorsports Build: MMS Heads, Solid Roller, MSD, Factory Shortblock
Old 09-25-2016, 01:21 PM
Josh B.
Josh B.'s Avatar
Default Mamo Motorsports Build: MMS Heads, Solid Roller, MSD, Factory Shortblock
Almost 2 years ago I made a build thread for my old WCCH/K501 topend. Well I thought it would be best to retire that thread and created an MMS specific one. Over the last year I have been reading up on the great work that Tony Mamo has been investing into the LS7 platform. This past March I contacted Tony to discuss a new top end package. Initially I asked about further porting my WCCH heads. Through discussion, Tony advised me that his new MMS TFS heads were the hot ticket through their clean sheet port design that he could perfect with hand porting. I left my deposit and Tony. I had to make a couple design changes along the way; for those who don't know Tony, he is absolutely customer service oriented, but he is absolutely dedicated to his craft, and that often requires bursting people's bubbles. I am hoping for great things from this build. No specific power goals, just trying to improve efficiencies from a hot-rodders stand point. Because race car
New Parts:
Factory Shortblock
    MMS TFS LS7 Cylinder Heads, additional exhaust porting, 60cc combustion chamber (412/265+ cfm), 13:1 static compression
      MMS Comp Cams Solid Roller Cam, 252/266, .703/.700, 114* (.014" lash)
        MSD Intake Manifold
          LG Super Ram Air Intake
          ARH 2" Headers, No Cats, Swaintech Coated
          Z06 Mufflers with 3" Muffler Mod
          GZ Motorsports Vacuum Pump System
          Flex Fuel
            Carryover Parts
            Monster LT1-S clutch, lightened flywheel
            Dewitts Radiator
            Meziere EWP
            Katech Belt Tensioner
            I'm removing the old parts now and will update with pictures as I install all the new parts over the next 10 days. Thanks for checking this stuff out. My PB on the local dynojet has been a very repeatable 594-596rwhp. I'll be posting dyno results for this new combo using the exact same dyno.
            Josh B. is offline
            The following 7 users liked this post by Josh B.:
            95rtturbo (12-02-2016), dmartens (09-25-2016), HC Mechanic (08-19-2017), meinersk (11-29-2016), MTPZ06 (09-26-2016), REDZED2 (09-25-2016), RGT (09-28-2016) and 2 others liked this post. (Show less...)
            Popular Reply
            06-20-2018, 01:08 PM
            FNBADAZ06
            FNBADAZ06's Avatar
            Honestly, IMHO I think that this thread should end right here with Josh's closing statement. There's so much great info in this thread that is worthwhile,regarding ancillary products used, methods of assembly, checking, measuring, and testing, that it would be a shame to let it be corrupted by the commentary that apparently will be the final chapter of this current build.
            Speculation won't solve the issues, and each prospective buyer should invest their time to research the product, the business, and it's practices for pre and post sales support.
            I think Josh has gone far enough in trying to explain the mechanical reasons for moving forward, and has been as transparent as one could possibly be given any other circumstances which may also play a part in the decisions he is making.
            It's time to be part of Team All-Pro and start writing the new chapter
            Old 09-25-2016, 01:44 PM
            Josh B.
            Josh B.'s Avatar
            Default Pictures. Lots of Pictures.
            Josh B. is offline
            Old 09-25-2016, 01:49 PM
            Josh B.
            Josh B.'s Avatar
            Josh B. is offline
            Old 09-25-2016, 01:55 PM
            Josh B.
            Josh B.'s Avatar
            Josh B. is offline
            Old 09-25-2016, 03:08 PM
            FSTFRC
            FSTFRC's Avatar
            Josh,
            Did you have a mechanical issue on your previous build? Are you going to run E85? That's a lot of nice parts going into that build! Looking forward to seeing the build and results.
            FSTFRC is offline
            Old 09-25-2016, 03:48 PM
            tdeweese
            tdeweese's Avatar
            Originally Posted by Josh B.
            Dam!!! I like all of it!! Smart move on the Katech "Red" pump. I went with the "blue" pump and have oil pressure on the low side.
            tdeweese is offline
            Old 09-25-2016, 03:55 PM
            redc6z
            redc6z's Avatar
            awesome build man looking forward for the result
            redc6z is offline
            Old 09-25-2016, 04:31 PM
            Whis9
            Whis9's Avatar
            In for results
            Whis9 is offline
            Old 09-25-2016, 05:44 PM
            AzDave47
            Support Corvetteforum!
            AzDave47's Avatar
            Received 4,509 Likes on 2,598 Posts
            Looks like a beast of a build, Josh.
            AzDave47 is offline
            Old 09-25-2016, 05:50 PM
            c5racr1
            c5racr1's Avatar
            Same here with the blue pump.
            c5racr1 is offline
            Old 09-25-2016, 05:59 PM
            double06
            double06's Avatar
            Very nice lots of goodies - so when do you think the dyno test in about a month?
            double06 is offline
            Old 09-25-2016, 06:23 PM
            Josh B.
            Josh B.'s Avatar
            Originally Posted by FSTFRC
            Josh,
            I have had zero mechanical issues with my previous build. I am very happy with the WCCH/K501 combo, it is a real winner, but I feel that Tony has raised the bar for our engine platform.
            Yes, I'm going to be primarily on E85, flex fuel capable. The dynamic compression between the two combos is only .1 point off (so we will try and tune for 93 octane for when E85 is not available). Static compression is up almost 1 full point (11.8 vs 12.7), but the new cam has an IVC that is 9* later than the K501, so the DCR is almost the exact same.
            Thanks man, I'm excited about the results too.
            Josh B. is offline
            Old 09-25-2016, 06:29 PM
            REDZED2
            REDZED2's Avatar
            INSANE!!! Can't wait to see it run!
            REDZED2 is offline
            Old 09-25-2016, 06:35 PM
            Josh B.
            Josh B.'s Avatar
            Default LG Super Ram Air
            Josh B. is offline
            Old 09-25-2016, 06:40 PM
            RobGOV-DCZ
            RobGOV-DCZ's Avatar
            Awesome Josh. Keep us posted! Smart man running the solid roller! I love mine.
            RobGOV-DCZ is offline
            Old 09-25-2016, 07:58 PM
            Bad_AX
            Bad_AX's Avatar
            Josh,
            Did you have the LS7 Ti rods rebushed? I'm guessing you don't have those rocker arms bolted down as the rollers are way on the edge of the valve stems.
            Bad_AX is offline
            Old 09-25-2016, 08:10 PM
            Josh B.
            Josh B.'s Avatar
            Originally Posted by Bad_AX
            Josh,
            The rods are factory stock with ARP 2000 bolts. The shaft rockers were sitting on the half moon pedestal stands that TFS includes with the Gen X heads; so you're right, they're right on the edge in the picture because they are not at the correct pedestal height, it's a misleading picture really.
            Josh B. is offline
            Bad_AX (09-25-2016)
            To Mamo Motorsports Build: MMS Heads, Solid Roller, MSD, Factory Shortblock
            MikeOC
            MikeOC's Avatar
            Can't wait to see your results Josh!
            MikeOC is offline
            Old 09-25-2016, 08:17 PM
            Josh B.
            Josh B.'s Avatar
            Yes, at some point in October for sure. I have dozens of pulls on this particular dynojet (224x). For comparison sake, a stock C7Z laid down exactly 550rwhp on it. It's very repeatable, I've used it for before/after tests for the EWP, the Monster clutch, and the 3" muffler mod.
            Josh B. is offline
            Old 09-25-2016, 08:52 PM
            Unreal
            Unreal's Avatar
            Received 2,313 Likes on 1,793 Posts
            Looks good. Should be a beast.
            The "flex fuel kit" is a great option for people who need support, and a one stop plug and play solution. Just like most things, if you are mechanically able, know what to do, and source the parts yourself you can get things cheaper, but for most I still recommend just ordering Dave's kit.
            Unreal is offline
            Quick Reply: [Z06] Mamo Motorsports Build: MMS Heads, Solid Roller, MSD, Factory Shortblock
