Corvette won't crank; random error messages
The car works great in accessory mode, all lights, radio, A/C, etc. The battery is new.When I try to start the engine, I hear a click, but nothing else. No cranking, no startup, nothing. Instead, the gauges do their dance and a bunch of random error messages show up: Service Traction System, Service Anti-lock brakes, Service Fuel System, Fuel Low. Moreover, my fuel gauge is at empty, but I had put a couple gallons of 91 into the car. I watched this video (which basically mirrors my exact problem)
Has anyone had this problem during their time of ownership? I'm at a total lost on what to do.
Edit: The car was hit on the passenger side front fender. There don't appear to be any broken wiring, and ECM appears undamaged.
Once I got the electrical system PARTIALLY on line ( no engine nor ABS connections ) I got the EXACT series of messages in the DIC on "start". I would inspect ALL wiring very closely!
When you say cut do you mean physically? Also, Just to double check the engine harness is the wiring that connects to the ecm right? They grey and or black one? Thanks
https://www.corvetteforum.com/forums...c6-2005-a.html
Post #5.
Good luck!
I'm not too sure how they could've been misplugged on this car, but I'll definitely give it a look!
EDIT: So I went ahead and removed the harnesses, gave each a spray of electrical cleaner, and applied dielectric grease. I did this for the ECM as well. The harnesses were plugged properly, so no problems there. I still have the problem and my OBD2 is pulling a U0100 code "lost connection with ecm/pcm". I did notice that a "gill" on my ecm has been chipped off. Would this be a problem? All the electronic accessories work on the car still though.
About the battery, I just disconnect the negative and leave the positive connected. Will it still drain the battery? Thanks.Regarding the starter solenoid, if it is not working or the connection is bad, would the vette still throw up all these random error messages?
2. I do not believe so. It would not start, but I don't think it would throw all those messages. The problem needs to be addressed in a general way...looking for major communication issues. In my opinion the wrong way to to it is to start trying to diagnose one issue by one issue as they are all being caused together by a communication issue. This is one flaw in the whole OBDII system that affects all cars.
Good luck
Good luck
