Best 4 post lift for the C7??
Old 10-11-2016, 01:32 PM
ssidekickbp
ssidekickbp's Avatar
Received 1,005 Likes on 328 Posts
Default Best 4 post lift for the C7??
Need recommendations for a 4 post lift that's good for a standard 2 car garage. Please post pics and a small review if it works great for your C7. Thank you!
Old 10-11-2016, 01:56 PM
ersatz928
ersatz928's Avatar
Backyard Buddy
Old 10-11-2016, 02:07 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Get one that is wider than the standard are you will have to kick your side/ mirror's in on each side..
What ever CO you go thur should make a lift that is taller & wider then a what everyone calls a standard size in how wide they are.
I got the standard size and wish now I had paid a little more and got the wider one. Robert
ssidekickbp (10-11-2016)
Old 10-11-2016, 05:05 PM
Hopper12
Hopper12's Avatar
Received 2,063 Likes on 980 Posts
There are several good lifts. Did a lot of research and ended up buying a BendPak HD-7W for the C7. Liked it so well, I purchased another one when we picked up a C3. I like them because they're high quality, hidden cables, air lock stops, etc. Some like the lever type stops, but I prefer the air. You can get 110 or 220v. I got 220 because I already had it in both sides of the garages. The 'W' is for 'wide', and as already pointed out, I'm glad I got the wider ones. A little more expensive than some, but as my parents always said, "when you buy quality you only wince once".
Hope this helps!
The following 2 users liked this post by Hopper12:
DWS44 (05-24-2018), ssidekickbp (10-11-2016)
Old 10-11-2016, 09:42 PM
RealPilot
RealPilot's Avatar
Advantage lifts
The following 3 users liked this post by RealPilot:
Borntorun04/17 (05-25-2018), Gonzo (10-11-2016), ssidekickbp (10-11-2016)
Old 10-11-2016, 10:23 PM
///ADMAN
///ADMAN's Avatar
WW
Old 10-11-2016, 10:32 PM
FX VETTE
FX VETTE's Avatar
Received 1,679 Likes on 1,182 Posts
Subscribed.
Old 10-12-2016, 12:51 AM
Msbfdx
Support Corvetteforum!
Msbfdx's Avatar
Advantage lift for me as well.
ssidekickbp (10-12-2016)
Old 05-23-2018, 10:51 PM
Mike Mirarchi
1st Gear
Mike Mirarchi's Avatar
Default Atlas extra tall extra wide
Perfect for switching track and road tires at home
I got the Hydrolic jacks as well
The jeep has a 3.5” lift with 35” tires so lots of clearance
Old 05-23-2018, 11:01 PM
Big Lebowski
Big Lebowski's Avatar
Received 3,987 Likes on 1,675 Posts
Backyard buddy for 12+ years. Love it.
AL2015 (01-25-2021)
Old 05-23-2018, 11:22 PM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
What are you going to be doing with it ? I'm asking because a two post lift is superior in basically every way, except for the hassle of positioning the lift arms.
Old 05-23-2018, 11:38 PM
Big Lebowski
...and cost.
...and installation.
Old 05-23-2018, 11:45 PM
GroverDill
GroverDill's Avatar
I have both, the 4 post is for parking/storage. The 2 post is for everything else.
Both cost about the same around $2700 the 4 post is the extra tall and wider version as my shop has 14' walls.
Old 05-23-2018, 11:57 PM
PatternDayTrader
And that pretty much says it all …
Old 05-24-2018, 09:00 AM
proeagles
proeagles's Avatar
Received 2,156 Likes on 897 Posts
If you are storing the car, you want 4 post, working on the car, 2 post. Really can't go wrong with any of the recommendations. Having said that Bendpak is superior, commercial grade lift
Old 05-24-2018, 09:22 AM
DWS44
DWS44's Avatar
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
Originally Posted by Hopper12
There are several good lifts...
Very nice...if I could ask, how tall are the ceilings in your garage where you have the C3 over the Caddy? That looks similar to what I've wanted to do, but have a fairly low ceiling compared to some of the other garage pics in this thread that have plenty of overhead room.
Old 05-24-2018, 10:35 AM
ImpliedConsent
ImpliedConsent's Avatar
Good thread. What I've learned is there is a difference between a Lift and a Jack. I came in assuming the lift was the jack, but you guys actually have car lifts. I'm looking to get a good quick jack, but these lifts look awesome and useful. Not sure how to change tires with the lift though.
To Best 4 post lift for the C7??
Old 05-24-2018, 10:45 AM
PatternDayTrader
There are trolly jacks that can be added to most 4 post lifts, but yeah, your observation is correct. Wheel/suspension service on a four post isn't much easier than doing it on the ground.
Old 05-24-2018, 11:13 AM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
I'm more about service than storage, so I went with a 2-post. I took the extra time to run all the cables and lines underground so there is no overhead connection and nothing to drive over as well.
I have a Mohawk A7 (made in America for less crushing of me) and like it because they're OSHA certified and so on.
Just wish I could get someone to come out and service/check it, the local dealer is gone now.
Old 05-24-2018, 04:36 PM
glava2876
glava2876's Avatar
Default Many Manufacturers
There are many great 4 post lifts, I went with Direct Lift.
Best garage item that I have at $2,500.00 delivered and installed.
Rated 7k lbs and gives me a way to store and work on my 79Z/28 and 2019Z06.
My garage is about 4' deeper on that side and is 10'-8"high.
DWS44 (05-24-2018)
Quick Reply: Best 4 post lift for the C7??
