Why do C7 Z06's pull to the right violently when breaking loose...WTF
Saw lots of videos/threads of people wrecking their new z06's so I am being careful. After my 500 mile oil change I got on it about 10 times today in 1, 2 and 3rd. Never rung it out as I will hold off on that untill about 2k miles.
In 1st the wheels break loose and the car just slides along straight as expected. In 2nd and 3rd, it violently jerks to the right. I let off it right way and the car jerks straight again.
My old supercharged c4 broke loose in 1st, 2nd and 3rd and I could floor it as much as I wanted and it continued to track straight while the wheels were slipping. It would get squirrelly at the top of 3rd at 100 mph but I could just correct with steering and stay on it. Done it a million times with the c4.
The c7 is asking to wrap itself around a tree. I am in touring mode it that matters
This is not right!!
Edit: I was on an empty private road.
This is not right!!
Kimonord (02-21-2017)
Popular Reply
10-28-2016, 11:21 PM
Received 8,928 Likes
When both rear wheels are spinning they have no lateral traction and the back end of the car will go in whatever direction the physics of the surface dictate. If you are on a crowned surface with the car on the right side of the crown the back end will go right, if you are on the left side it will go left. There can be other things on the surface or part of it that can affect which way the back end goes.
If you are on a low grip surface it can be possible to have the back end swing back and forth like a pendulum as the driver countersteers.
Bill
Bill
Check your alignment. Mine doesn't do that.
Flyingscot (11-01-2016)
The Snap Oversteer Monster will be along shortly to blame rear caster. Maybe it's even true - but do people who get that "fixed" no long have to worry about the rear end coming around? I'd pay for an alignment if I believed it made the car more stable in street scenarios (I have had no issues on the track, so maybe my car is randomly set up properly from the factory).
Why would the gear make a difference as to why the rear end steps out? Any theories? That part strikes me as odd, and I can't say I've experienced the same.
pdiddy972 (02-11-2017)
I did have a theory on that actually. In 1st, once they break loose they both spin so much that there is no traction on either wheel. In 2nd and third one wheel is still gripping.... With the c4 I always felt the wheels slipping together. Maybe the electronic diff has something to do with it.
Regardless, I strongly recommend you get a good feel for the split second you have before the car goes to potentially violently out of control - the other lane, ditch.... Shift, back out of it and don't end on YouTube.
This is not right!!
This is not right!!
BigBird440 (02-19-2017)
2017 C7 of the Year Finalist
Had a little scare with mine a 2 weeks ago. Slight throttle input at the same time I hit the hydroplane puddle at 65mph on the freeway. All of the sudden looking left looking at center wall, eased it back with a quick whip and sliding 2 lanes toward the rear wheels of the 18 wheeler's trailer, to the fishtail correction finally. No skill, just pure luck. No poop, very happy today. used weather mode on the rest of ride home.
Bad Dad (12-19-2016)
My c6z has 550 at the wheels NA and it doesn't slide right. Powers right through wheel spin straight ahead. Non run flat super sports, stock suspension.
RussC243 (10-30-2016)
Bill
Bill
The following 12 users liked this post by Bill Dearborn:
360Lemans (11-04-2016),
BigBird440 (02-19-2017),
BWFitz (08-08-2017),
furiousox (04-05-2018),
Harbgrogan (10-17-2018),
and 7 others liked this post.
Received 1,984 Likes
Bill
Bill
Lots of great answers. Thanks! Will study up on how alignment comes into play. I always only considered alignment when my daily drivers would not track straight hands off the wheel or the tire guy talks me into a badly needed alignment.
Don't really care to use more than about 200hp 99.9% of the time. Got the z over the base because I like fine machines but I do like to understand them and have them set up right. Sunny today...can't wait to try out the stack of new microfiber towels and wax.
Rear alighnment
If you only drive the car on the street have your rear camber adjusted to zero or as close as you can get it will more than double your traction in a straight line and you will double the life of the tires.
The following 2 users liked this post by marc0779:
SterlingDrive (12-07-2016)
It happens even on $200K AMG's when drivers run out of talent.
I was leaving a local cars and coffee event couple weeks ago and some dude captured this as I was leaving. I left gentlemanly, in order to try to troll in the GT to follow me for some "fun", but he turned the other way... check out the results.
Sorry....the stupid YouTube embed function REFUSES to work.
As a follow-up, this is how the Z crowd rolls (or should!)
The following 6 users liked this post by MindBend:
C5 Hardtop (12-21-2016),
cheapthrills (04-16-2018),
dmaxx3500 (12-07-2016),
snow (04-04-2018),
and 1 others liked this post.
I can relate. I can run the car hard at roadcourse trackdays with no issues at all.
But when on the getting on a freeway on ramp, the e-diff seams to hunt for traction between the left and right tires at times on uneven surfaces. A very different feel vs a normal "posi" limited slip diff.
Plstxmd (04-16-2018)
I can relate. My first Z ended up in a ditch I am more scared of this car than my old C5 that was making over 700 RWHP and I only ran Bridgestone all season 275 tires on that At least when that car spun it would track straight. Not sure if it is an alignment or a E-LSD issue but there is an issue for sure.
In my opinion it's because in 1st gear you have no traction all due to torque multiplication. 2nd and 3rd the gear tires start to gain traction due to less torque multiplication. This coupled with the fact that the tires can now spin up to 93 mph in 2nd and 124 mph in 3rd so whatever instantaneous traction the tires do catch thrust the car harder and further. With one tire gripping it makes the car yaw to either side.
tomtoro (04-14-2018)
