Now available from SCP: C7 Corvette Mild 2 Wild Exhaust On Demand Switch
Imagine having the ability to turn your Corvette C7 Z06, Grand Sport and Stingray NPP exhaust from MILD (exhaust ports closed) to WILD (exhaust ports open) using the supplied remote.
This revolutionary product lets you control your, 2014-Present Corvette Z06,Grand Sport, Stingray or NPP exhaust system on demand via a tiny wireless remote or the Homelink feature in your car . One of the coolest technologies on the new 2014-Present Corvette Z06,Grand Sport, Stingray NPP equipped Corvette is the “bi-mode” exhaust. Whisper quite up until 3500 RPM and then a wide open race car sound as the flaps located in the tips open. The problem is the inability to control this feature.
This patent pending product requires no drilling or running wires through your car. It’s a simple 5 min simple plug and play installation that anyone can do. Once installed, you will have full control over the exhaust mode, via a simple ON/OFF remote wireless controller. You also will get two sleek ON/OFF wireless controls that can be mounted anywhere and will control the exhaust up to 50’ away. The “OFF” mode gives you that race car sound 100% of the time. The “ON” mode works as the stock setting and is quiet to preset OEM 3,500 RPM so the system will work just like the stock system . The switch can be used anytime the car is running, allowing you to show your friends what a cool exhaust you have as you can use the remote and open and close the flaps on demand.
You will receive the professionally engineered plug and play wireless receiver, two miniature remotes (batteries included) and the necessary homelink programming instructions. Believe me you will be happy with the quality and fit of this Corvette exhaust controller.
Check them out here: C7 Corvette Mild 2 Wild Exhaust On Demand Switch
