C6 Parts for Sale/Wanted C6 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible
Old 12-15-2016, 09:51 AM
PFYC
Platinum Supporting Vendor
PFYC's Avatar
Default Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible
="4"%Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible
This Wind Restrictor for the Chevrolet C6 Corvette Convertible is in a class of its own. After two years of intense development work, the manufacturer felt they'd come up with the perfect wind screen. Being solid and translucent, the Wind Restrictor will block as much wind (or more) than the factory windscreen. It's crystal clear, so you will not have any loss of visibility at night like some report with the black netted style screens. The 3D patent-pending glass design allows for full top movement while installed, and is the first C6 screen (and the only, to our knowledge) to have this feature. Installation requires no drilling or permanent modification at all.
The innovative bracket system is one of the most attractive features of the WR. Velcro-type straps don't belong on a car like the Corvette. This unique technology makes Wind Restrictor a leader in the industry. Thousands of satisfied customers will abundantly confirm this. They have developed a high-quality black powder-coated stainless steel bracket system that makes this product perhaps the most solid and rigid on the market. The screen is securely mounted into specially designed steel anchors that are inserted into slots on the frame of your car. The center "light bar-stability bracket" is constructed from high-quality black acrylic and has the CORVETTE text logo laser engraved into it.
Since this product is officially licensed by General Motors, you can choose from any of the available Corvette graphics to have laser engraved into your Wind Restrictor to personalize. If you want something unique, you can personalize your deflector with custom laser graphics for an additional charge. The manufacturer has a graphics artist that can help you with this after you order.
Finally, if you're looking for something else to help set your Corvette apart from the rest on the streets, the high-quality illumination system offered as an additional option can do just that. Choose from a fixed color or go with the Extreme Light Kit for a multitude of colors and color-changing options. The lighted windscreen also helps make your vehicle safer on the streets by allowing other drivers to more easily see you at night.
How does it work?
The Wind Restrictor is designed to significantly reduce back draft. Backdraft is created when wind pressure inside your car's cabin is less than the wind pressure outside the car. The cabin acts as a vacuum and gusty wind enters from behind the passengers, creating noise and buffeting. The WR will block this wind from entering the cabin at highway speeds. You can control the amount of wind by adjusting the side windows. The lower you put your side windows, the windier it will be inside your cabin. Put them up completely to reduce the wind as much as possible.
Features
Can remain in place and looks great with top up or down
Does not interfere with top movement; no need to remove it, EVER!
Very strong and rigid mounting system
Powdercoated stainless steel bracket system
No drilling or permanent modification required
3D glass design enables full seat travel while installed
Officially licensed laser engraved Corvette graphics available
Elegant illumination system available with multiple color options
Remote control lighting and dimming options available
Brake lamp hook up, running light hook up, or battery power available for car shows
Lifetime warranty
Made in the USA!
Benefits
Significantly reduces wind turbulence inside your convertible and
helps maintain cabin temperature while driving with the top down
Allows you to enjoy conversation without raising your voice
Gives better sound clarity from your stereo with reduced wind turbulence
Personalizes and sets your Corvette apart from the rest
Additional rear lighting (optional) for added safety on the road
Allows passengers to talk more clearly on cell phones
Some more details you might be interested in:
Made from double-sided AR Polycarbonate This very durable acrylic type material is also scratch resistant. Others are made out of much cheaper materials and dangerously breakable plastics. Some are Lexan; the disadvantage is that it scratches easily and won't emit illumination and may also discolor with etching.
Professionally and precisely designed and laser cut Others are produced at home using table routers and jigsaws leaving rough edges and defective shapes. Wind Restrictors are professionally produced from the finest materials using state-of-the-art equipment.
Illumination available The only wind-deflecting device on the market that has this patent pending feature! You can have the Wind Restrictor Light Kit hard wired to any 12-volt wire in the car. Most car audio/electronic shops or dealerships can wire it or you can do it yourself in less than 1 hour. A cigarette lighter plug adapter or AAA battery pack can be added for an easy, convenient connection.
Laser etching available Etched with a high-powered laser to really make your roadster unique and stand out. The engraving will also emit light and give off an awesome glowing effect with a light kit installed. Personalize your roadster with a custom logo or any of our standard graphics
Perfectly formed to the contours of your Corvette Others won't fit as nicely as this.
Attaches to your Corvette without permanent alteration or tacky fixtures No drilling or permanent modification is required.
Extremely smooth crystal-clear edges Others are sometimes sharp and ridged; ours are laser cut smoothly to perfection and then flame polished so that the Wind Restrictor looks and feels like "a million bucks" as well as emitting the best quality illumination
Glow Module Add-On
The Glow Module will work perfectly with the extreme lighting kit offered above. There is no need for the dimmer control switch, the on/off switch, battery pack, or 12V adapter if you have the Glow Module. Below you'll find the six options provided by this new and improved module - there is nothing like this on the market anywhere! With five different functions (plus off) to choose from as well as a slider to set intensity, the drive and show possibilities are endless with this incredible option!
Glow Module Functions:
Light Mode: Allows you to have the Windrestrictor lit up at any desired intensity with vehicle or running light power. It is constant and the intensity is only determined by the slider on the module.
Show Mode: This is the perfect mode for evening car shows or showing your Windrestrictor off while parked. It will not drain the car battery in any way. Intensity is determined by the slider.
Ghost Mode: No lighting while driving, but whenever the brake pedal is activated and then released, the Windrestrictor will produce a bloom in full 12V power and then fade out in a ghost effect. This patented lighting effect is a must see!
Brake Mode: The intensity while driving is determined by the slider. (We recommend having the slider set to a mid level). When the brake pedal is activated, Windrestrictor lighting will kick up to FULL brightness along with your brake lights turning the Windrestrictor into a third brake light. When the brake pedal is released, the intensity will go back down to the slider setting. If you set the slider to zero, no light will be present when driving, only when you brake.
Ghost PLUS Mode: While driving, the slider determines the lighting intensity. (We recommend having the slider set to a mid level.) When brakes are applied, lighting will kick up to FULL brightness with your brake lights. When the pedal is released, the ghost function allows the intensity to slowly fade all the way off, then slowly fade back to the slider setting.
OFF: Windrestrictor will produce no lighting at any time.
To see instructions for the Glow Module and Extreme Lighting Kit, please click here.
Extreme Lighting Kit: With our new Extreme Lighting Kit, you can choose which color you want your Wind Restrictor to light up in - no longer do you have to choose a pre-defined color. Choose from red, white, blue, pink, yellow, green or cyan any time you wish. The unit comes with a remote control that you can use to turn the lights on or off or change the color. The controller features a cool "fade" option and also a "blink" option for use at car shows or gatherings. Requires a 12V plug and can be either hardwired or used with a 12V outlet in your car for maximum flexibility.
Click HERE for additional photos and some customer testimonials on this great product.
__________________
PFYC.COM - Proudly Serving You For Over 20 Years! Call Us Toll Free: 866.695.PFYC (7392)
www.pfyc.com info@pfyc.com .."we're here to help"
Old 01-19-2017, 12:26 PM
PFYC
PFYC's Avatar
Old 01-30-2018, 01:33 PM
Hrdtop00
Hrdtop00's Avatar
Do you have any pictures/video with the Wind Restrictor in smoked glass?
Originally Posted by PFYC
Old 01-30-2018, 01:55 PM
PFYC
PFYC's Avatar
Here is the plate that is smoked.
Old 02-22-2018, 02:27 PM
Jazzmann320
Jazzmann320's Avatar
PM Sent with questions
PFYC (02-26-2018)
Old 03-17-2018, 09:47 AM
Vette_Fan
Vette_Fan's Avatar
Multi-color with dimmer?
Old 03-19-2018, 09:20 AM
PFYC
PFYC's Avatar
Yes you can order the multi-color and on the controller there is a dimmer
Old 03-19-2018, 03:32 PM
Vette_Fan
Vette_Fan's Avatar
Is that a function included in this, or is that extra....How does that work? I have a C6 Vert?
Old 12-20-2018, 09:10 AM
PFYC
PFYC's Avatar
Order yours today!
Old 08-23-2019, 11:11 AM
PFYC
PFYC's Avatar
Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible $399.00
How does it work?
Features
Lifetime warranty
Made in the USA!
Benefits
Glow Module Add-On
Old 08-28-2020, 08:16 AM
PFYC
PFYC's Avatar
Order yours today!
Old 08-28-2020, 10:40 PM
jol
jol's Avatar
Link is not opening. Trying to find price and order.
To Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible
Quick Reply: Wind Restrictor Logo Wind Screen for 2006-2013 C6 Corvette Convertible
