C5 Corvette Seat Foam Kits and pieces from RPI Designs
Platinum Supporting Vendor
1997-2004 C5 Corvette Sport Seat Foam 6 Piece Set
Item #
39123
Time and use have taken their toll on your seat foam. The key to great looks and ultimate comfort is all in the condition of your Corvette's Seat Foam! No Corvette restoration job is complete without this revitalizing foundation to make seat cover installation easier with that "like-new" look and fit. Our Corvette Seat Foam is molded exactly as your originals right here in the USA!
•Fits 1997-2004 Corvette With Sport Seats
•Full 6 Piece Set To Replace Both Seats
•Highest Quality Foam With Correct Density
•Fitment: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvette; Base, Coupe, Convertible, Z06
Website Link :
https://www.rpidesigns.com/shop/item...m-6-piece-set/
If you have a 1997 - 2004 C5 Corvette that the seat is starting to feel uncomfortable most likely your seat foam is deteriorating. With these pieces or kits below you will be able to restore your seat back to a brand new factory-like feel.
1997-2004 C5 Corvette Standard Seat Foam 4 Piece Set
•Fits 1997-2004 Corvette With Standard Seats
•4 Piece Standard Seat Foam Set
item # 39126
Website Link : https://www.rpidesigns.com/shop/item...m-4-piece-set/
1997-2004 C5 Corvette Standard Seat Foam Back
•1 Standard Seat Back Only
item # 39125
website link : https://www.rpidesigns.com/shop/item...eat-foam-back/
1997-2004 C5 Corvette Standard Seat Foam Bottom
•1 Standard Seat Bottom Only
item # 39124
Website link : https://www.rpidesigns.com/shop/item...t-foam-bottom/
1997-2004 C5 Corvette Sport Seat Foam Back Inner
•1 Seat Back Inner Only
item # 39121
website link : https://www.rpidesigns.com/shop/item...am-back-inner/
1997-2004 C5 Corvette Sport Seat Foam Back Outer
•1 Seat Back Outer Only
item # 39122
Website Link : https://www.rpidesigns.com/shop/item...am-back-outer/
1997-2004 C5 Corvette Sport Seat Foam Bottom
•1 Seat Bottom Only
item # 39120
website Link : https://www.rpidesigns.com/shop/item...t-foam-bottom/
__________________
This may be a stupid question, but is there a difference in the seat bottoms? Are they interchangeable?
They are listing it as a different part number so either the mounting or foam position of the pad is different. Bear in mind if you are re-using your existing seat cover you would need to get the correct seat foam so when you install the cover back on it fits correctly. Thanks, Don
66dts-v (01-31-2017)
Good question, I can only assume that GM used the same seat frame for both seat, if they do then yes by changing the foam and seat covers you can upgrade. I just do not know for sure if the seat frame is the same.
Received 1,227 Likes
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Modified
I'll be ordering a complete set of sport seat foam soon (I recently got new skins on a DEEP discount). After browsing and searching the forum, your price (with discount) is by far the best.
RPIDON (01-18-2019)
Received 3,812 Likes
St. Jude Donor '03-'04
I bought my seat foam from, RPI... it's cushy for my tushy
RPIDON (06-18-2019)
Use Coupon Code RPICHRIS5 for an Immediate Discount!!!
I completed my first interior/ seat rebuild project and the RPI foam fit so well that even I could handle the project . Great quality, Fast shipping and a perfect fit. Good stuff.
These make a great addition to any C5 Corvette!
If you would like to visit our Online Catalog and view all of the C5 Corvette Parts
and Merchandise that we have available for sale, just click the link below...
Website Link:
RPI Designs’ C5 Corvette Online Catalog
Cruising
I noticed that the left side bolster on my '99 vert seems to have broken. When I sit, it kind of lets me slide over it to the left. I assume the fiberglass piece didn't break, is there anything in there besides the fiberglass and the foam? If not, I'm guessing I need new foam. I assume you can use the old seat covers, they're not ripped or anything.
also I noticed you had a discount code above in the thread, I tried it and it saved $0.79. Is that what it's supposed to do?
Thanks
Ed
Thanks
Ed
Thanks
Ed
Thanks
Ed
Hi Ed,
The coupon code gives a specific percentage off of the website cost on eligible products. So, the higher the product cost goes, the dollar amount for the discount will also increase. I realize it is not much "off" the price of lower-priced items, but still offers some savings.
As for your seat, yes to both questions. Your issue should be solved with new seat foam, and you can easily reuse your seat covers.
Thanks,
Chris
Received 19,307 Likes
'20-'21-'22-'23-'24
Moved to C5 Vendor for Sale to comply with maximum number of vendor FS threads on first page of a two day directory.
Thank You for shopping at https://www.rpidesigns.com/shop/item...m-6-piece-set/
Please use Anuran5 code for additional savings
