Back of my car is covered with black spots
Old 02-02-2017, 07:36 PM
Ali Simsek
7th Gear
Ali Simsek's Avatar
Default Back of my car is covered with black spots
2016 C7 Stingray.
2800 miles.
I visited 3 dealerships and they cannot find the way to fix it. Does anyone has the same problem?
I think the car is lemon.
The spots are covered all over my trunk. I tried different gas stations .Checked the oil. Nothing. My son is kind of mechanic and he thinks there is a serious issue. I am tired of cleaning the back of the car and I am afraid it will be more issues after the warranty.
Does anyone has any idea how to fix that or shall I continue talking with GM ?Please advise.
berk4422 (02-02-2017)
Popular Reply
02-03-2017, 11:24 AM
Widgeon5
Widgeon5's Avatar
Originally Posted by Ali Simsek
2016 C7 Stingray.
2800 miles.
There have been several gratuitously rude and mocking replies to this gentleman's post. He wants to know whether he even has an issue, including a legitimate concern about a possible engine fault that could cost him after his warranty expires. His treatment here will cause others to be reluctant to ask questions, and diminish the usefulness of the forum.
Old 02-02-2017, 07:44 PM
cwing85b
cwing85b's Avatar
If its coming from your car the bottom should have stuff all over it also. If you are not losing oil etc from the car I would suspect perhaps the road surface you are driving on?? Recent sealing of cracks in the road etc.
The following 2 users liked this post by cwing85b:
Art17 (07-14-2021), pdiddy972 (07-24-2018)
Old 02-02-2017, 07:45 PM
L8ter
L8ter's Avatar
Normal, If you’re a spirited driver, keep it in sport or track mode, and don’t like to wash your car.
Art17 (07-14-2021)
Old 02-02-2017, 07:48 PM
budgreen3564
Support Corvetteforum!
budgreen3564's Avatar
Do you have mass transit diesel busses running in your area. We used to get that pollution on the back of a white mustang due to bus smog
Old 02-02-2017, 07:49 PM
RicK T
RicK T's Avatar
What do the insides of the exhaust tips look like? Any pics?
Sounds like you are saying it's oil spots, yes?
Old 02-02-2017, 07:54 PM
WhiteDiamond!
WhiteDiamond!'s Avatar
Try taking a terry face cloth with a little gasoline on it and rub over the spots and see if they come off.
Old 02-02-2017, 07:57 PM
JC 2004
JC 2004's Avatar
I get a bit of soot from my pipes when I apply a generous amount of throttle over the course of a week or so. Mine washes right off. It can spot a bit overnight with moisture/dew.
vdavenp802 (05-22-2017)
Old 02-02-2017, 07:58 PM
vbdenny
vbdenny's Avatar
I bought a black car. No issues.
The following 3 users liked this post by vbdenny:
449er (07-23-2018), corvettezman (07-15-2021), MIKEZ51 (07-15-2021)
Old 02-02-2017, 08:16 PM
AmmoVet
AmmoVet's Avatar
2016 C7 Stingray.
2800 miles.
Looks like a normal Corvette Dirty Butt to me. Clay bar works great on the black spots! Get it real clean then use some Rejex on it to keep it clean.
The following 2 users liked this post by AmmoVet:
AttyVette (04-16-2019), TCRVETTES (02-02-2017)
Old 02-02-2017, 08:19 PM
John Micheal Henry
John Micheal Henry's Avatar
Rear diff leaking??
Old 02-02-2017, 08:23 PM
Ali Simsek
7th Gear
Ali Simsek's Avatar
Sometimes the car is throwing out smoke like black color. It has nothing to do with the road. I live in a decent area.
No.
Last edited by Steve Garrett; 02-02-2017 at 10:08 PM. Reason: Merged Posts-please use the Multi-Quote button (middle icon) in the lower right hand corner of each post to make your response look like this.
Old 02-02-2017, 08:24 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
I wouldn't think black exterior spots are enough to declare this car a "lemon" unless it is clearly a paint defect. More than likely there is an external cause.
Old 02-02-2017, 08:26 PM
Ali Simsek
7th Gear
Ali Simsek's Avatar
You cannot clean if that happens every time you drive!
The spots happen from the smoke coming out from exhaust pipes. Who wants to drive a car with carbon spots happening all the time.
I regret I bought that car.
Originally Posted by John Micheal Henry
Rear diff leaking??
Please check my complaint. It has been at the dealers 3 times. They would have found out if there was a differential issue.
Live in a nice area and do not drive in crappy roads.
You live in my area. Tell me if you have a C7 Corvette and if you have seen any spots on the trunk. There is no external cause for 2700 miles car.
Rear diff leaking??
The car has been checked and no leak or other leakage.
Last edited by Steve Garrett; 02-02-2017 at 10:09 PM. Reason: Merged Posts-please use the Multi-Quote button (middle icon) in the lower right hand corner of each post to make your response look like this.
Old 02-02-2017, 08:41 PM
2fastnow
2fastnow's Avatar
Then you have a tune problem running rich so the ECU floods with gas/fuel to your ratio if you say there is no leaks. Bring it to a tune shop just to see if it's out of whack. If it is don't fix it their bring the dyno sheet/receipt to dealer. Check your plugs too.
pdiddy972 (06-07-2017)
Aflyer
Aflyer's Avatar
Mine does not do that, or maybe it does, and I can't see it because it is Cyber Grey.
It looks like exhaust deposits to me, what kind of fuel are you using? Maybe try a few tanks of a top-tier gasoline, and see if that makes any difference.
Check this out:
http://www.toptiergas.com/licensedbrands/
Aflyer
Old 02-02-2017, 08:42 PM
Ali Simsek
7th Gear
Ali Simsek's Avatar
They are black carbon spots. They are not oily.
Check this out:
Aflyer
I always use Super 92 High Octane Gas. Don't go cheap on gas.
It cleans off right away when I apply detail spray. That is not my issue. The issue is that should NOT be happening.
Old 02-02-2017, 08:49 PM
BrunoTheMellow
BrunoTheMellow's Avatar
Received 1,396 Likes on 999 Posts
Have you just driven around a new area to see if it happens on any road? check the sections below the valence right behind the tires, is it more concentrated? Show us the exhaust pipes, is it more concentrated?
To Back of my car is covered with black spots
Old 02-02-2017, 08:50 PM
roadsterboy
roadsterboy's Avatar
I have seen that on my arctic white rear end and assumed it was just carbon deposits from the 4 pipes. It seemed to happen after being parked for several days to a week. Sometimes there are no spots. I'm not worried about it.
Mine's a 16 with about 4500 miles.
Old 02-02-2017, 08:51 PM
brooklync5
brooklync5's Avatar
Lol your car is not a lemon... if your driving with the exhaust on sport of track mode it lets out a lot more soot then when driving in tour mode because the flaps are open. Get a damp rag clean it off and stop crying about it. If you really regret buying the car because of this issue sell it. I doubt GM will take it back because you are to lazy to clean it once in a while lol.
The following 12 users liked this post by brooklync5:
bgspot (06-04-2017), BRussell (07-23-2018), ByRiver (07-24-2018), DSOMZ51 (04-12-2019), Dundon929 (04-10-2019), dvilin (06-03-2017), frankb (07-13-2021), John Micheal Henry (07-23-2018), RRC19966 (07-13-2021), SLOWRYDE (05-25-2017), Steve_R (07-23-2018), vdavenp802 (05-22-2017) and 7 others liked this post. (Show less...)
Old 02-02-2017, 08:52 PM
VY427
VY427's Avatar
Did you put any fuel system additives/cleaners in the tank? I put a bottle of Chevron Techron in a car I had (a VW Golf R, relatively new at the time) and I started getting little black spots on the back of the car. It lasted for a while, then eventually stopped. I figured it was carbon deposits that were cleaned and shot out of the exhaust pipes.
Quick Reply: Back of my car is covered with black spots
