You need to supply additional info. As far as I know E67 ECMs were only installed in ZR1 Corvettes. Most C6 Corvettes used the E38 ECM. The 2005 C6 Corvette was a one year only ECM. The GMPP harness uses E67 ECMs as well.
My 2009 ZR1 ECM pinout info states that pin 46 J3 isn't used.
Thanks for the reply KENS80V
I have an LS2 in a Kit application, so the normal rules don't quite apply, but at least this rules out Pin46 being an issue i think.
Cheers, Linkin
Cheers, Linkin
What OEM operating tune are you using or is it a GMPP harness and ecm?
