C5 Forced Induction/Nitrous C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth
Lightweight Battery
Old 03-25-2017, 03:50 PM
corvet786c
corvet786c's Avatar
Default Lightweight Battery
Searching and came up with few results. I have decided on Deka ETX14L 11.5 lbs or ETX18L 17 lbs.
I need to lesson the weight on the front end because of the procharger.
Any suggestions or others? What other parts I need?
Are these batteries good for daily driving.
Old 03-25-2017, 06:46 PM
corvet786c
corvet786c's Avatar
Bump, what about lithium batteries?
Old 03-26-2017, 03:40 PM
smokinstorm
smokinstorm's Avatar
That's what we have for the track. It was expensive but a 6 pound battery literally starts the car better than the 40+ pounds 1000CCA lead acid battery we keep in the car for everyday driving. I purchased it from Lithium Moto. http://www.lithiummoto.com/
It's not particularly user-friendly either but there's no denying its performance and the added performance it gives the car as a whole. Since we've got a C5 and it seems like all C5's kill batteries for whatever reason, I cannot recommend this battery for a daily driver unless you can easily disconnect it every time you stop the car and leave it parked for any length of time. If this battery discharges, it's toast. Don't ask me how I know.
winters97gt (05-23-2017)
Old 03-26-2017, 05:21 PM
Rob Petyo
Rob Petyo's Avatar
I've been using a Braile 17 lb. for years and use for a daily driver. My 98 has a slight current draw so it needs to be on a charger if I don't use the car after a couple of days but the 04 does not have any problem starting (stroked 382) even after sitting for a week. They are easy to kill if they drain. Just had the dealer change the oil and they checked the battery and it was a good 450 CCA.
Old 03-27-2017, 04:33 AM
corvet786c
corvet786c's Avatar
I just bought the 11.5 lb version, Tire rack had a sale $148.99 plus free shipping and it come with the plastic holder.
https://www.tirerack.com/accessories...&cat=Batteries
Everyone says to get a battery tender on it, thats next. SO I feel good about losing 20 lbs off the front on this beast.
Old 03-27-2017, 09:20 AM
glennd
glennd's Avatar
I had a 11# braile battery it worked fine. I did keep it on a trickle charger. I am in the process of relocating a full size battery to the trunk, as any bit of extra traction helps.
Old 03-27-2017, 10:48 AM
corvet786c
corvet786c's Avatar
Back to square 1, they are on back order, order cancelled.
Need to find something else lightweight, suggestions.
Old 03-28-2017, 10:00 PM
JT FRC 00
JT FRC 00's Avatar
Do a search for high end car audio batteries. There's quite a few out there that can be used for what your looking to do. Can't recall all the different one available but Braile is one of them.
corvet786c (03-29-2017)
Old 03-30-2017, 03:15 AM
inspector12
inspector12's Avatar
Just bought a Antigravity lithium battery 9.5lbs fit in the stock location almost same size, this is in a C6 Z06 but works like a champ has a low voltage cut off so if you leave your lights on or run it down pretty low. You can press a button on the back of it and it will still start your car and almost 1/3 of other comparable battery's I've found. GL!
NemesisC5 (01-23-2018)
Old 05-22-2017, 06:12 PM
corvet786c
corvet786c's Avatar
Finally had some time to take a photo of mine.
Old 05-22-2017, 07:20 PM
HardcoreABN
HardcoreABN's Avatar
interested in this myself. Leaning towards the Deka 11lb or 17lb battery in the trunk.
Old 05-23-2017, 02:57 AM
winters97gt
winters97gt's Avatar
It's a good weight savings idea, but remember the battery is behind the front wheels, so it's not going to move the weight transfer as much as other cars. We used dynabatts in our mustangs back in the day. I'd probably look at relocating the battery to the trunk to move it further back if weight transfer while launching is your main concern drag racing.
mowpow (08-25-2018)
Old 05-23-2017, 03:57 AM
romandian
romandian's Avatar
which one do you have? i saw one for $600. they dont give any wheights.
Old 05-23-2017, 04:02 AM
corvet786c
corvet786c's Avatar
The one I am using is from autozone made by deka. ETX18L 17 lbs. I was using the 15 lb ETX20L which I liked as well. I don't know if the ETX20L was a bad battery or what but it would drain fast. When this one gets bad, I want to go back to the etx20l. I can feel the weight difference up front from stopping better and accelerating better. Procharger adds alot of weight up front.
Old 05-23-2017, 10:08 AM
inspector12
The only have one for automotive platform currently
Old 05-23-2017, 12:46 PM
neverstop
neverstop's Avatar
Awesome. I had not heard of this battery and sounds perfect with the low power cut off switch built in.
Have you put a lot of miles on it so far? wondering how reliable it is when used a lot and getting drawn down etc
https://shop.antigravitybatteries.co...omotive/rs-20/
I swear with some of the cheaper lithium iron batteries could just carry two of them in the car and if ever have a problem use the backup, would still be out $400 for two of them and still save 40lbs vs normal batter
Old 05-24-2017, 12:42 AM
inspector12
Not sure as I've been fighting a fuel pressure gremlin and haven't gotten it worked out yet to put a ton of miles on my car, but its been pretty good. I ran all of TX2K with it and worked flawless, but I can't say its been on there for a ton of miles to know about longevity. But it does have a good warranty although those are usually crappy as you have to probably send it in and let them evaluate it while your car will be dead in the water LOL! One huge turn off has been the freaking European Battery posts! But nothing a little terminal modifications didn't fix. I was like who the F____ uses European posts in the USA? And these things screw on so why aren't you sending the battery with both or even have them for purchase etc... Just a few of the questions I had for them after receiving it. But it fits great in the rear of my C6 ZO6 so i'd guess yours would be just a easy to mount.
To Lightweight Battery
Old 05-24-2017, 01:36 PM
neverstop
neverstop's Avatar
good stuff. would be awesome to drop 40lbs that easily off the nose of the car. i like the way they built these so it sounds like you can never kill the battery since just turns itself off if gets too low
Old 05-24-2017, 05:31 PM
winters97gt
It's not actually the nose of the car. You're thinking too much in to old school cars. The battery is located behind the front tires. It does help, but not in weight transfer like our old hot rods. It doesn't have the same weight transfer effect you're thinking.
Old 06-02-2017, 09:21 AM
StrangelovesM6Vert
StrangelovesM6Vert's Avatar
I put my $600.00 AntiGravity battery in this morning.
The terminals are backwards so I had to make some short cables
and the bolt to hold it down was too short as the ledge on the battery is higher but nothing I couldn't do.
Also the threads on the top posts to mount side terminals are a different mystery thread that is smaller than the side terminal bolts but not 3/8 x 18 standard however those size
bolts at 3/4" long worked well with my Big 3 kit and monster stereo and such.
Goes in ok and threads about 1/4-3/8" then get stiff.
Quick Reply: Lightweight Battery
