C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 03-28-2017, 04:53 PM
managerman
managerman's Avatar
Default Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
I wanted to do a quick recap of my experience of having a Z06 Supercharger installed on my 2015 Z51 Stingray.
I bought the used and already ported LT4 supercharger "complete kit" (Blower, Heat Exchanger and Water pump, LT1 to LT4 adapter plates, Z06 balancer, Z06 tensioners) from a forum member who bought it from a Z06 owner who had a Procharger installed. The used blower was from a 2016 Z06 with 900 miles on it at the time of take off.
I took the car down to Weapon X Motorsports in Cincinnati, OH. They do so much work with C7 Corvettes, 6th Gen Camaros, and other LS type engines, it made sense to have them do the install. I was right! It was an awesome experience all throughout the entire process.
Here are some pictures taken during the install.
One of the main reasons I chose to go this route (vs. Procharger or Edelbrock) was to make it look as factory as possible...and I believe it does!
I wanted to change the wording on top of the supercharger to something other than "LT4 Corvette" So I contacted Emblempros.com and had custom cover plates made!!
Although I bought a "complete kit" that included the following parts....
1.) LT4 Blower,
2.) Heat Exchanger, Water pump and Reservoir
3.) LT1 to LT4 adapter plates
4.) Z06 balancer
5.) Z06 tensioners
The install needed a bunch more parts and accessories to complete the install...For all those contemplating going this route....Here are all the items that had to be purchased to make the install complete:
1.) Z06 air intake. I decided to go with a Halltech intake.
2.) New Brisk Sparkplugs
3.) LT4 MAP sensor
4.) Custom LT1 to LT4 MAP and IAT Sensor adapter harness
5.) Gates Supercharger drive belt
6.) Various fittings and bolts.
7.) Coolant for Heat Exchanger
8.) Rubber hoses for adapting to new PCV system
9.) Custom 12V relay and wiring harness for Z06 intercooler pump
10.) Supercharger oil
11.) Modified LT4 Valley Plate
The stock fuel system was not quite enough so....
12.) Z06 Fuel injectors
13.) Z06 High Pressure Fuel Pump
Final before and after Dyno numbers are quite impressive!!!
610 Tq / 570 Hp at the wheel! or around 732 Tq / 684 Hp at the crank
The car drives fantastic and has amazing power down low...It is a different car! I love it!!!
The total cost was very similar to having an Edelbrock Eforce installed....with far more power and a totally stock look!
All in all, I am very happy! Ben, Blake, and Jeremy from Weapon X Motorsports are fantastic!! I am sure I will be back down there for more upgrades later in the year....
-M
The following 16 users liked this post by managerman:
A320Flyer (09-05-2018), c7_joey (08-05-2021), dmaxx3500 (09-12-2019), edster75 (12-20-2023), Hate2Wait (10-09-2018), JerriVette (03-03-2018), Macs338 (05-27-2017), mdaniel (07-04-2020), MDmotorman (02-05-2021), RGT (09-10-2018), rsvette12 (07-27-2018), s n v f f (11-07-2021), simrokkzz (03-29-2021), slowhatch (06-28-2017), snow (04-04-2017), ya3coub (03-23-2019) and 11 others liked this post. (Show less...)
Old 03-28-2017, 05:23 PM
BooSSted
BooSSted's Avatar
Great write up! I still think this is the best solution for LT1 owners wanting more power.
2FAST4U (07-28-2022)
Old 03-28-2017, 05:33 PM
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,396 Likes on 999 Posts
That's sweet but I don't believe the 640 ft-lb tq figure by looking at that graph. There is a weird blip at ~2900 rpm but immediately drops 30 ft-lbs. 570 hp / 610 tq is more like it.
What else is done to the car? I've seen posts of X-pipe,catback and intake, was that it? 470 hp / 450 tq is much higher than stock (usual is 400 to 405 hp and tq).
Not trying to rain on your parade but to compare to other kits, your kit yields a peak increase of 100 hp and 160 tq. Centrifugal kits and the E-Force yield 150-180 hp and 120-140 tq peak increase so something is off with those dyno graphs.
Old 03-28-2017, 08:10 PM
managerman
managerman's Avatar
^^^ I agree...570/610 is more accurate..the only mods I had on the car were Borla xpipe and Borla Atak exhaust..
Maybe the baseline dyno run graph is not right?cant imagine I was making 470/450 baseline...
-M
Old 03-28-2017, 08:33 PM
BrunoTheMellow
I also believe your baseline is wrong and would put you at identical hp gains with the other kits but the low rpm high levels of torque seen on lt4s.
managerman (03-28-2017)
Old 03-28-2017, 10:32 PM
kc stingray
kc stingray's Avatar
bad *** setup! I wish someone would make a complete kit for this conversion.
managerman (03-29-2017)
Old 03-28-2017, 10:50 PM
managerman
managerman's Avatar
Talk to Ben or Blake at Weapon X Motorsports. They will be making the kits.
-M
Old 03-29-2017, 07:34 AM
1rawTA
1rawTA's Avatar
Love this setup, i saw a few OE lt4 superchargers on ebay for 1500-3k range... If this can be done for 7-8k tuned with headers it can definatly be worth it
Old 04-04-2017, 07:45 AM
op z
op z's Avatar
Stock hood has adequate clearance?
Old 04-04-2017, 07:54 AM
snow
snow's Avatar
St. Jude Donor '10, '17-'18-'19
Great write up, I would go this route if a conversion kit were available. Since it's not going with the E-Force, but I love the OEM look.
Great job!
Old 04-04-2017, 08:16 AM
managerman
managerman's Avatar
I bought mine off a forum member for $2600.00 Adding all the additional needed parts and labor brought the install to right around 8K
Yep..it fits fine.
Great job!
Thanks! I love the OEM look too! Talk to Ben at Weapon X Motorsports...he can put the kit together for you!
-M
Tabester (05-02-2019)
Old 04-04-2017, 08:43 AM
ht_pro
ht_pro's Avatar
Thank you so much for sharing the graph, write-ups, and all of the information. Looks like you have a great set-up. I will continue to strive for this but may have to piece the parts together more slowly as I can't afford to drop $8k + on my C7 right now. 1st world problems....lol
managerman (04-04-2017)
Old 04-04-2017, 11:56 AM
BlueDevilZ51
BlueDevilZ51's Avatar
Looks great and makes about the same power as a stage 2 Edelbrock E Force.
Old 04-04-2017, 05:38 PM
0Cajun @ Edgyvette
Former Vendor
Cajun @ Edgyvette's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
those numbers on a Mustang dyno! Damn. Add 12% for dyno jet numbers. That is STRONG
Old 04-04-2017, 06:19 PM
SpartaGus
SpartaGus's Avatar
Subscribed
Old 04-04-2017, 09:14 PM
T/A KID
T/A KID's Avatar
Good results!!! The LT1 with the z06 blower will make more power then the lt4 with z06 blower...
The following 2 users liked this post by T/A KID:
2FAST4U (07-28-2022), managerman (04-05-2017)
Old 04-04-2017, 09:27 PM
walleyejack
walleyejack's Avatar
how so ?
may i ask, curious on this
To Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
Old 04-04-2017, 10:16 PM
T/A KID
T/A KID's Avatar
Originally Posted by walleyejack
how so ?
compression and intake duration of the cam
Old 04-04-2017, 10:23 PM
walleyejack
Am.leaning towards this over a centri
Old 04-04-2017, 10:24 PM
Drew27
Drew27's Avatar
Now if they can put the zo6 blower on my 17' silverado
The following 2 users liked this post by Drew27:
edster75 (12-20-2023), LuisZ51 (04-22-2019)
Quick Reply: Z06 LT4 Supercharger installed on my 2015 Z51 Stingray!!
