FS: 1996 Base Coupe Black
1996 Corvette Base Coupe. Black with tan interior. 140k miles. LT1, 4L60E, 2.59 posi D36 rear. Power sports seats. AM/FM cassette (cassette player does not work - stereo is fine). All stock as far as I know except for Granatelli MAF, 160 degree thermostat (with fans adjusted accordingly), and VBP rear camber strut rods. It might have some sort of upgraded cam, but I've never been able to verify that. I've had it since 2014, I've done water pump, alternator, intake manifold gaskets, rear tie rod end, new Bilstein shocks all around, and poly bushings in the rear suspension dog bones. Passes emissions test with no problems. With owner's manual, factory service manuals, Chilton's manual.
It's not a show car, but runs and drives well. I couldn't find a Carfax on it, but the seller told me it had front end body panel damage early in its life that was repaired. Paint is so-so, passenger seat bottom cushion has torn seam stitching. Could use new weather stripping. Front tires are fairly new Contentials, rears are new Nittos. The Low Tire Pressure Warning System (LTPWS) light is on because there weren't any pressure senders on the rims when I got it. I have a pair of rear rims that will go with it if you want them.
Asking $4900. As is/where is (Littleton, CO). Respond here, or via message.
Last edited by five7kid; 08-23-2017 at 12:10 PM. Reason: New information on tires and price
